Old 01-29-2014, 08:51 PM   #26
NEWFISHER
NEWFISHER's Avatar
Re: 64 Chev C10 Slam (Noob Style)
Each corner (bag) is run separately to each paddle switch or electric valve. It inflates and exhausts on its own. 4 bags, 4 lines. That way you don't get cross contamination, especially if you go drive it and in the first corner it will feel like its rolling over!
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 01-29-2014, 10:27 PM   #27
64chevtruck
Ok thank you I will go buy 2 more paddle switches, I have only 2 now and both fronts are on one and both backs on the other, '
Another question if you have time, How do you guys know if your truck is level or not if each bag is separate><>? Mount up a bubble level like in a motorhome>?
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438
70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983
76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612
79 GMC 3500 Fleetside LB 454/400
90 Suburban Silverado 4x4 350/700R4
97 1500 Cheyenne Short Fleet 350/5sp
64chevtruck is offline   Reply With Quote
Old 01-29-2014, 11:05 PM   #28
NEWFISHER
NEWFISHER's Avatar
2 gauges. Each gauge has 2 needles , a red and a black
GOD BLESS AMERICA!
Old 02-05-2014, 05:26 AM   #29
64chevtruck
Thank you Newfisher, I have 2 more switches now and one dual needle gauge, Ill get one more asap, Thank you for your time.
Old 02-05-2014, 10:57 AM   #30
NEWFISHER
NEWFISHER's Avatar
No worries. Post up some pics!
GOD BLESS AMERICA!
Old 02-05-2014, 02:34 PM   #31
Ta2Don
Ta2Don's Avatar
Just found your build...
I'm in for the ride!!!
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 02-18-2014, 11:35 PM   #32
RoadRat
RoadRat's Avatar
Awesome build! Do you have any pics of where you mounted your rearbags?
RoadRat is offline   Reply With Quote
Old 02-19-2014, 10:57 PM   #33
64chevtruck
Hi, Thanks for the interest and help guys,
I had more trouble with my front bags rubbing on my LCAs so I broke down and bought new tube upper and lower ones, At that point I had no choice but to pancake my crossmember, Most of the stuff was already unbolted, and doing it will keep my new LCAs off the pavement.
a question I have is, should I move the crossmember forward an inch to center my tires in the wells>?
Pancake is almost done now,
Old 02-19-2014, 11:42 PM   #34
NEWFISHER
NEWFISHER's Avatar
There is a thread in the suspension forum regarding the crossmember movement. 5/8ths is the magic number without issues if I remember correctly. Ill try to find it and post a link
GOD BLESS AMERICA!
Old 02-20-2014, 12:00 AM   #35
64chevtruck
Oops I forgot the pics.... what a noob... :0)
Got a front swaybar too.
Thank you Newfisher I will look for that info,
Old 02-20-2014, 12:09 AM   #36
64chevtruck
pancake, I ended up dropping it 2 inches.
Old 02-20-2014, 12:19 AM   #37
64chevtruck
My Pappy gave me these dash clusters years ago, I just re found em the other day, Im pleased. Ill mount the tack and air gauge in my truck.
Oops I missed your question Roadrat. I dont have pics at this time of the rear bags, but I mounted them about in the center of my drag links/trailing arms. Same as Coulter and Jdoisher did in their builds.
Old 02-20-2014, 12:19 AM   #38
NEWFISHER
NEWFISHER's Avatar
Here it is. The 5/8 was another member doing the mod on page 2. Its a lower arm forward vs. Entire crossmember forward mod
http://www.67-72chevytrucks.com/vboa...ght=caster+mod
GOD BLESS AMERICA!
Old 02-20-2014, 12:20 AM   #39
NEWFISHER
NEWFISHER's Avatar
What wheels are you running and Are you using adapters on all 4 corners?
GOD BLESS AMERICA!
Old 02-20-2014, 03:08 PM   #40
64chevtruck
Thanks Newfisher, Hey I just read one of your threads. Nice Suburban and camp setup. Subs are hard to find in those years, My pappy had a 49 chev panel when I was a kid I rode around in the back of, Windows would have been nice!
I was going to run red rims with caps and rings but my buddy sold me a set of 5 aluminum 20 inch rims, and 8 20 inch tires for 200 dollars, I dont love the look of large rims on older things, but I did notice they do look nice if you tuck em waaaay up inside the fender wells so you cant see most of em.
Im also real interested in seeing what that does for my gear ratio on the freeway, my 6 sounds angry at 75 right now.
But to answer your question directly, Im not sure what brand the rims are, and I put disks on the front so the rims fit there ok as soon as I pull out my inner fenderwells, and the spacers are for the back so the ridges on the axles dont hit the small holes in the back of the rims, So spacers on the back only,
Thanks for your time
Andy
Old 02-21-2014, 02:09 PM   #41
64chevtruck
Heres the rims Im running and heres a pic of my bags for Roadrat, You can see where I welded the stock upper shock mounts to the crossbar to re use them. I need to add support under my rear bags still I see,..,...
Old 02-21-2014, 03:23 PM   #42
tinydb84
tinydb84's Avatar
You will probably want to remount those bags. They should be centered on the arm or they will cause the arms to twist and bend then likely break the mount in the front.
David
Instagram: myfabguy
Old 02-24-2014, 02:40 AM   #43
64chevtruck
I hear ya for sure, I had planned to build the insides of the arms out under the bags but never got to it yet. I will be on it right after I get my front end put back together. I need to raise my steering box I think, so Im off to research how much is good to move it,
Old 02-24-2014, 04:16 AM   #44
64chevtruck
Ok I just read everything I could find on raising the steering box. I went 2 inches on my pancake so Ill have to move all the steering now from what Ive read,
One thing I am not sure on is.. Will I need to get a steering shaft with a U joint in it if I raise the steering>?
Thanks in advance for your time,
Old 02-25-2014, 08:05 PM   #45
tinydb84
tinydb84's Avatar
The problem with the bags isn't the supporting of them on the arms but the twisting motion of them being offset. There are a couple of treads on here that cover it in detail.
My crossmember on my 66 was raised 2 inches as well. I will take some pics of the steering set up. I forgot if there is a u-joint in there or not (I got it that way). You will have to notch the frame to clear the steering though.
David
Instagram: myfabguy
Old 03-05-2014, 02:45 PM   #46
64chevtruck
I made a bracket to mount the new switches I got thanks to Newfishers info, Im in the middle of switching all my lines out to stainless braided and putting my new sideplates on also, Cuz im waiting on Performance Online to get my lower front bag adapters shipped to me to finish my front end.
The last pics was just me seeing how much fun stuff I could get in one pic hehe,
Ok im headed out to finish running the air lines now have a good day.
Old 03-05-2014, 03:17 PM   #47
NEWFISHER
NEWFISHER's Avatar
" The last pics was just me seeing how much fun stuff I could get in one pic hehe, :"
You did a good job with that pic!
GOD BLESS AMERICA!
Old 03-05-2014, 03:20 PM   #48
1963c-10
1963c-10's Avatar
Looking good
1964 Short bed trailer
Old 03-05-2014, 06:53 PM   #49
Skywalker1210
Nice custom build. Like the ideas!
Skywalker1210 is offline   Reply With Quote
Old 03-06-2014, 03:28 AM   #50
64chevtruck
Thanks alot guys!
Newfisher I got the back 2 bags plumbed up today, I assumed each bag gets its own feed straight from the tanks yes?
Or do some people run a single large feed line up behind the switches and split it 4 times?
Have a good week
