Old 01-25-2014, 03:55 PM   #1
NEWFISHER
NEWFISHER's Avatar
65 V8 long water pump, FAN SHROUD ideas?
A stock one won't fit and I don't want to cut up the perfect oe one that I purchased to make it fit. An aftermarket plastic one won't work and if cut down will have too large of fan opening by the time it fits ( 4" from rad to center blade)
Anyone run into this? Solution?
My thoughts are fab up a nice sheet metal shroud or ditch all of the LWP stuff from the front of the engine and go with Short Water Pump stuff.
Hoping someone says " oh yeah, just get a shroud from a ______and trim it
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 01-26-2014, 02:47 AM   #2
Captainfab
60-66 Nut
Re: 65 V8 long water pump, FAN SHROUD ideas?
That's why I typically stick with short water pumps on the vehicles that originally came with them. Is your engine in the original location? I have seen other members run the long pump with a stock fan shroud, but when I tried it once, it didn't work. Not sure what the difference was.
Old 01-27-2014, 10:00 PM   #3
duallyjams
duallyjams's Avatar
post 33 stock fan shroud long water pump with a clutch fan
http://67-72chevytrucks.com/vboard/s...=502124&page=2
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 01-27-2014, 11:16 PM   #4
NEWFISHER
NEWFISHER's Avatar
^^^^^^ NICE! Now how good are you at shoving small cameras into tight spaces and getting a few pics? I would love to see which fan and clutch they are. My fan is flat and bolts to the backside of a fairly small clutch. Does the end of the taper area of the shroud land about half way through the fan blade if you dropped a plumb bob?
Thanks James!
GOD BLESS AMERICA!
Old 01-28-2014, 10:21 AM   #5
64shortbox
64shortbox's Avatar
I doubt you want to go electric fan but if you do I used a Lincoln Mark VIII fan. I had to trim a little off the top of the shroud to clear the radiator tanks and the radiator hoses and fab up brackets t mount it but I think it looks like it belongs there. While I was at it I installed a Radiator Overflow/Windshield Washer combo off a Ford Exploder.
64shortbox is offline   Reply With Quote
Old 01-28-2014, 01:37 PM   #6
61K10
61K10's Avatar
ck out a chevelle big block 66/67 shroud. they are a little wider and bolt on flat but real short. can take a pic and measure if you want.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 01-28-2014, 04:41 PM   #7
NEWFISHER
NEWFISHER's Avatar
That would be great. Measurements too if it's not too much to ask.
Thanks!
GOD BLESS AMERICA!
Old 01-28-2014, 04:43 PM   #8
NEWFISHER
NEWFISHER's Avatar
That's a nice looking engine compartment! Thanks for the idea , but trying to stick with the parts I have ( cheap ). I like the washer/res you came up with too. Hopefully you ground off the blue oval! hehehe
GOD BLESS AMERICA!
Old 01-28-2014, 06:24 PM   #9
duallyjams
duallyjams's Avatar
Thanks James!
I'm off on Thursday, will take plenty of pics and info.
here's one pic I have from before
James
IG duallyjams
Old 01-28-2014, 09:05 PM   #10
NEWFISHER
NEWFISHER's Avatar
Attachment 1207195
Thanks James, that fan clutch looks identical to what I have and that fan looks aftermarket??
GOD BLESS AMERICA!
Old 01-28-2014, 10:48 PM   #11
duallyjams
duallyjams's Avatar
The fan is off of a GM truck, I got it from board member teeitup he deals in 67-72.
James
IG duallyjams
Old 01-28-2014, 11:32 PM   #12
Rich 5150 69
Rich 5150 69's Avatar
Newfisher, do you realy need the thermostatic fan, if you just bolted on a 5 blade stock fan it would put it right where uou need it..?
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 01-29-2014, 01:21 AM   #13
NEWFISHER
NEWFISHER's Avatar
I have had an aftermarket one mounted without the clutch and bought a few stock choices to play around with. Do I need one? Probobly not ,but its the little projects now that the truck is pretty much done, that keep me from buying another truck! I'm looking to change the MPG's on this thing with a fan clutch, some rear gears that work with the 700r4 and the 235/75/15s and either use my Holley projection or a quadrajet etc to maximize the economy side. In the end I will have spent more time and money farting with the little projects than it would take to drop an LS engine in it and at that point this thread is mute with the electric fan set up it keeps me off the couch and not wasting cash on 401k plans or house remodels lol
GOD BLESS AMERICA!
Old 01-29-2014, 01:23 AM   #14
NEWFISHER
NEWFISHER's Avatar
I have found that a 86 suburban 350 fan and an aftermarket fan clutch with NO shroud runs cooler indicated on the gauge than an aftermarket fan bolted direct drive to the pump without a shroud.
GOD BLESS AMERICA!
Old 01-29-2014, 02:04 PM   #15
61K10
61K10's Avatar
here is some pic's of the BB shroud--could be modded to work i think
27 1/2 wide
16 3/4 high
2 1/2 thick
19 1/4 fan opening
1961 chevy K10
Old 01-29-2014, 02:08 PM   #16
NEWFISHER
NEWFISHER's Avatar
Thanks, I will measure mine tonight!
GOD BLESS AMERICA!
Old 01-30-2014, 02:35 PM   #17
duallyjams
duallyjams's Avatar
The fan shroud is a repo ( bowtie bits ) 70-72 7 blade clutch fan from board member Teeitup
James
IG duallyjams
Old 01-30-2014, 02:38 PM   #18
duallyjams
duallyjams's Avatar
plumb bob, hope these help, if you need more just let me know
James
IG duallyjams
Old 01-30-2014, 06:08 PM   #19
Mikemelton
Not factory looking but I've run an aftermarket chrome one for the past 15 years or so like this https://www.google.com/search?q=chro...90825447058319
Mikemelton is offline   Reply With Quote
Old 01-30-2014, 07:44 PM   #20
NEWFISHER
NEWFISHER's Avatar
Attachment 1208276
Attachment 1208277
Attachment 1208278
Attachment 1208279
Attachment 1208280
That's puuuuuurfect. Thanks James
GOD BLESS AMERICA!
Old 01-30-2014, 09:33 PM   #21
Rich 5150 69
I`m running the short pump, engine mounts in the rear hole of crossmember, with fan shroud and 2.5 inch fan spacer, so theoretically I can change to a long water pump if I decided to change everything else, biggest issue is what holes the owners are using in the mount/crossmember..
