Old 06-18-2011, 04:00 PM   #51
Teck
Teck's Avatar
Re: M1009 with LQ9
Just read through your thread. Nice build.
I'm look at putting LS 6.2 in my 86 blazer. Any advise would be helpful. Looks like I will need motor mounts, a new crossmember, new fuel tank and sending unit for 87-91 blazer.
Which fuel pump are you using, is it an in tank pump?
I have a 700r4 so will I need an adapter to bolt it to the motor?
1986 K5 Blazer
Teck is offline   Reply With Quote
Old 01-10-2012, 06:44 PM   #52
jkade
jkade's Avatar
Re: M1009 with LQ9
Sorry, I just now read this. Let me know if you still have questions. I am fixing to pull the LQ9 and put a 5.3 in it and go back to 1/2 ton running gear.
jkade is offline   Reply With Quote
Old 01-10-2012, 07:07 PM   #53
Teck
Teck's Avatar
Re: M1009 with LQ9
No problem.
Things have changed some here too.
Put an '07 5.3L/4L60E in it, almost have it done.
1986 K5 Blazer
Old 01-11-2012, 10:36 PM   #54
68Timber
I know the pieces fit
68Timber's Avatar
Re: M1009 with LQ9
Super clean, looks great. Are the dual shock mounts factory?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 01-11-2012, 11:53 PM   #55
Teck
Teck's Avatar
Re: M1009 with LQ9
Thanks and yes
1986 K5 Blazer
Old 01-12-2012, 02:54 AM   #56
MTCK
MTCK's Avatar
Re: M1009 with LQ9
Nice truck, Teck! You should start up a build thread. Why the change of plans, jkade? Putting this drivetrain in another rig?
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 01-12-2012, 08:51 AM   #57
Teck
Teck's Avatar
Re: M1009 with LQ9
Changed because at the the time I could find a 6.2 I wanted, so I did the 5.3 just to get the swap worked out. As for the 4L60E I went with it because of the DBW, didn't want to change to cable gory to make the 700r4 work.
Here is a link to my build at CK5. http://coloradok5.com/forums/showthread.php?t=253165
Sometime I guess I should do one here.
1986 K5 Blazer
Old 01-12-2012, 04:43 PM   #58
jkade
jkade's Avatar
Re: M1009 with LQ9
Yes, I am putting the 6.0 in a 2wd s10 blazer with a 6 speed. I am putting a 5.3 with a tr220 cam back in the k5.
Old 01-12-2012, 04:44 PM   #59
jkade
jkade's Avatar
Re: M1009 with LQ9
That blazer is awesome!!!!! Clean as hell!!!!
Old 01-18-2012, 11:53 AM   #60
jkade
jkade's Avatar
Re: M1009 with LQ9
Anyone wanna buy it before I demod it? Fixing to pull motor and axles. I will take $7000 for it.
Old 01-18-2012, 01:20 PM   #61
MTCK
MTCK's Avatar
Re: M1009 with LQ9
That's a decent price with all the trimmings. The road trip home would be a little long. Throw it up in the classifieds with some pics and a link to this thread.
-Marcus
Project Plow Truck
Old 02-02-2014, 02:46 AM   #62
khan1369
khan1369's Avatar
Re: M1009 with LQ9
i know this is old... but i have a question about the tank and the pump... can you explain what tank you are using and what pump setup? I am trying to get a 5.3L swap together on an almost non-existent budget....
"Live, Love, Build cool s***"
Jesse Chapman, 2013
My Truck..
http://67-72chevytrucks.com/vboard/s...d.php?t=567219
khan1369 is offline   Reply With Quote
Old 02-04-2014, 10:58 AM   #63
Cherub
Cherub's Avatar
Re: M1009 with LQ9
tank and pump and sending unit from an 87 and after will work on a budget. If you arnt planning on putting any mods on it.
Cherub is offline   Reply With Quote
Old 02-04-2014, 11:09 AM   #64
68Timber
68Timber's Avatar
Re: M1009 with LQ9
I thought the newer stuff ran at much higher fuel psi than the old TBI?
John
74 Honda Z50 build
Old 02-04-2014, 12:45 PM   #65
Cherub
Cherub's Avatar
Re: M1009 with LQ9
it will suffice if you dont plan on any mods. which i figure he isnt since he is looking for a budget build.
