Old 01-03-2011, 10:39 AM   #1
jkade
jkade's Avatar
M1009 with LQ9
Getting closer... I hope to have it running by the weekend. I know there are other people out there that have questions about doing this in a 4x4 so let me know if you have any questions.
Motor is from a 02 Caddy, comp xr275hr-12 cam, ford 30lb car injectors, 98 fbody harness, using the flexplate that came on the motor with the gm spacer between the flexplate and the converter. The converter is a hughes gm25hd (2200-2500), running a np241 from a 91 burb with the vss. The motor mount adapters are from car shop inc and are the one for the 1" set back. The motor mounts are in the factory holes. I am using a cluster from a 91 burb, gas tank and sending unit are from a 91 burb with a 96 vortec pump. The fans are from late 90's early 00 ford windstar fan. The headers are Mac Mid Lengths for a 98-02 camaro/firebird.
This is my woods/hunting truck so I was not worried about clean and paint. If it was a show truck I would have painted the motor etc
Hopefully this will help others out. Let me know if you have any questions.
jkade is offline   Reply With Quote
Old 01-03-2011, 10:43 AM   #2
jkade
jkade's Avatar
Re: M1009 with LQ9
Old 01-03-2011, 10:44 AM   #3
jkade
jkade's Avatar
Re: M1009 with LQ9
More pics to come and a maybe a video by the end of the week.
Old 01-03-2011, 05:33 PM   #4
Gemp
Gemp's Avatar
Re: M1009 with LQ9
Cool build, What did you have to change on harness to make it work in an K5.....
06' GMC 1500 Crew cab.....
Gemp is offline   Reply With Quote
Old 01-03-2011, 05:56 PM   #5
jkade
jkade's Avatar
Re: M1009 with LQ9
On the camaro harness I just cut out the wire's that need constant 12v, switched 12v, ground, etc. There is a pretty good diagram on ls1 tech for the harness... about makes it too easy. Next time I would probably just spend the extra $200 for a harness already done. It is very time consuming if you do the electric fans ( I probably have 6 hours in my harness).
Old 01-09-2011, 04:30 PM   #6
jkade
jkade's Avatar
Re: M1009 with LQ9
It runs and drives again. The IAC was giving me fits and it would crank and die. I thought the guy that tuned my computer forgot to turn the vats off but it ended up being the IAC. Only thing giving me fits right now is the speedo, it is pegged running 30mph. I am glad I didn't go with a 5.3 becasue I don't think it would have been enough motor. It runs good about like a stock Z71 i guess but this thing weighs a ton with the dana 60, 14 bolt and the h1's and 38's. I bet the is a min of 100hp loss through the drivetrain on this thing.
We are expecting some snow so when it warms back up I will get some pics and a running video. I got the stock exhaust hooked up right now but in the next week or 2 I am going to take it and get some new exhaust with h pipe and mufflers, that should free up a few ponies.
Old 01-11-2011, 01:56 PM   #7
HarrisonTX
Re: M1009 with LQ9
Very impressive bud.
The first picture in post number 2 is just a filter?
Your new vortec fuel pump just slides into the factory blazer tank?
'69 custom/camper
'74 260z 302 chevy/tko500 swap in progrss
'79 Malibu 355 all forged 4 speed car.
'86 k5 blazer
'06 Duramax
HarrisonTX is offline   Reply With Quote
Old 01-12-2011, 11:00 AM   #8
jkade
jkade's Avatar
Re: M1009 with LQ9
Thanks!!
It is a filter/regulator for say a 99 corvette. That keeps you from having to run a return all the way from your intake. Even if you intake has a return you can pick up a returnless rail cheap.
Yes, the vortec pump is a direct swap. The pig tail and everything plugged right in. They say it will even work on the non efi tanks with a efi sending unit but I wanted the baffles so I bought a efi tank and sender.
Old 01-16-2011, 09:35 PM   #9
Mr. 250r
Mr. 250r's Avatar
Re: M1009 with LQ9
this the exact same swap i want to do in my suburban, nice swap and for some power alot of people run the l92 heads on those motors as a future upgrade
Mr. 250r is offline   Reply With Quote
Old 01-17-2011, 03:27 PM   #10
jkade
jkade's Avatar
Re: M1009 with LQ9
It has way more power than the 6.2 diesel.... this thing will not be getting any more upgrades I have over $3500 in this swap with the cost of the trans rebuild. I want to put a 5.3 or a 6.0 in my 86 k10 next but I also have 2 more that will get this swap as well.... I need to hit the lottery
Old 01-17-2011, 03:44 PM   #11
Mr. 250r
Mr. 250r's Avatar
Re: M1009 with LQ9
the ls motors are getting so cheap i really don't see a point for old small blocks i mean i like my tbi 350 but its not enough for 38.5s and 4.10s luckily my tranny is good to go hopefully i get mine started soon
Old 01-17-2011, 03:49 PM   #12
jkade
jkade's Avatar
Re: M1009 with LQ9
I agree 100%, it would be hard to build a SBC or a BBC that makes this kind of power and gets as good of mileage for a lot less that what I spent on the LQ9 swap. It is nice to get in it when it is 12 degrees outside and it fire right up!! My 86 K10 has a 305, 465, 3:08's and 31x10.50's and gets probably 5mpg less than the blazer with dana 60, 14bolt, 4:56's and 37x12.50's with the runflats installed (heavy as hell).
Old 01-18-2011, 01:22 AM   #13
Mr. 250r
Mr. 250r's Avatar
Re: M1009 with LQ9
did you have any problem with the headers i was wanting some long tubes but just out of curiosity and does the vortec pump hold the right fuel pressure i see a lot of people using vette stuff but this helps me out a lot
Old 01-18-2011, 10:13 AM   #14
jkade
jkade's Avatar
Re: M1009 with LQ9
The headers are a tight fit, the drivers side frame rail had to have about 3/16" ground off it and it had to be notched about 1/4 on the bottom for the collector flange. A set of 99 up truck headers might work better but the mac's is what I had on hand. I have not checked the fuel pressure, a bunch of people use the vortec pump with no problems, if I had to do it over again I would have used the walbro 255 pump that is a upgrade to the vortec pump.
Old 03-06-2011, 05:33 PM   #15
jkade
jkade's Avatar
Re: M1009 with LQ9
It has been running for about 2 months now with no problems. I have installed a cage, shackle flip, and I am going to order my new rear drive shaft tomorrow from Denny's. Here are a few pics, the shackle flip is a deal for less than $100 bucks and I got it from http://www.gatsbycars.com/chevy.html
The magnaflows are gonna get change for some knock off flowmasters... these things are way to loud with the 6.0, they were not that loud on my 67 with the ls1 but this thing is moving a lot more air.
Old 03-06-2011, 09:55 PM   #16
68Timber
I know the pieces fit
68Timber's Avatar
Re: M1009 with LQ9
Nice! How much lift does the shackle lift give? It looks like you have around 6" of lift over 37" tires.
The Magnaflows aren't to blame, the 6.0 is. I've been going to the same muffler shop for many a year now and know the owner pretty well, he told me once the 6.0 was loud with aftermarket mufflers. If you want to tone it down, buy the biggest pair of Dynomax Super Turbos you can in the diameter you like.
The M1009 looks great, nice work.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 03-06-2011, 10:03 PM   #17
Shaun1162
Shaun1162's Avatar
Re: M1009 with LQ9
Very nice work... I certainly wish I had that for a "woods truck"
Shaun1162 is offline   Reply With Quote
Old 03-07-2011, 10:23 AM   #18
jkade
jkade's Avatar
Re: M1009 with LQ9
I am gonna say the lift is between 4-5". I should have measured it with the 4" blocks but I never thought about it. It sits a little higher in the back with the flip. I do have the zero rate blocks on all 4 corners so in theory I have a 5" lift.
I have the 4" round magnaflows so that doesn't help any. It sounds good at an idle but when you get on it all hell breaks loose
Old 03-07-2011, 11:52 AM   #19
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: M1009 with LQ9
That a cool project! I like it..
tvblazer78 is offline   Reply With Quote
Old 03-08-2011, 12:36 AM   #20
jkade
jkade's Avatar
Re: M1009 with LQ9
Appreciate it!
I "was" going to order a rear driveshaft today but it was going to be over $500 for a slip yoke double cardin... cough... cough. Before I drop that kind of dollar I am going to do a SYE. What a money pit!!!!
Old 03-08-2011, 06:19 PM   #21
LiveAnimals
LiveAnimals's Avatar
Re: M1009 with LQ9
What size tires are on the HMMWV wheels
Kameron
YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY
I'm a Middle ClASS HOLE
07.5 Dodge 3500 CTD -- Daily
73 C10 Factory BB SWB 2WD
LiveAnimals is offline   Reply With Quote
Old 03-08-2011, 10:46 PM   #22
jkade
jkade's Avatar
Re: M1009 with LQ9
37x12.50 but the measure 36"... I have another set of h1's with 38" swampers but they ride like crap!!
Old 03-15-2011, 12:45 AM   #23
MTCK
MTCK's Avatar
Re: M1009 with LQ9
Awesome build! That thing is pretty loud - you're not going to be sneaking up on any critters.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 03-15-2011, 11:43 AM   #24
jkade
jkade's Avatar
Re: M1009 with LQ9
I am going to have some different mufflers put on it soon, it is obnoxious
Old 03-15-2011, 11:54 AM   #25
LiveAnimals
Re: M1009 with LQ9
Did you reposition the axles with the zero rates? Do you have a side shot of the CUCV.
Kameron
