Old 02-01-2014, 10:07 AM   #51
bigguy69
dazed and confused
bigguy69's Avatar
Re: My 4/6" ECE lowering install thread - 72 Shorty
Looking good
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 02-02-2014, 02:49 PM   #52
original-71
///Relaxed Atmosphere
original-71's Avatar
Graham when you put the blocks on take that 1/4"block on drivers side and switch it to passanger side that should make you even on both sides thats what i did on mine.
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R)
87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R)
hector
_________________________________
1971 Chevrolet Cheyenne Super
1987 Chevrolet Silverado
2006 Ford Mustang GT
2012 Toyota 4-Runner
2014 Dodge Ram 1500 Sport Crew Cab
original-71 is offline   Reply With Quote
Old 02-02-2014, 03:02 PM   #53
Ekliptix
Ekliptix's Avatar
Hector, brilliant. And thanks a ton for giving me those 1/2 blocks this morning. Your truck looks AMAZING. So nice.
Ekliptix is offline   Reply With Quote
Old 02-02-2014, 03:08 PM   #54
WIDESIDE72
WIDESIDE72's Avatar
Originally Posted by Tx Firefighter View Post
The hardest part of the whole job is removing the four rivets that hold the stock upper shock mounts in place.
When i did mine i did not have the bedwood in yet. I just drilled the heads off the ribets first then whacked the old brcket with a hammer. Then i heated up the area around the rivet with a torch and drive the rivet out with a punch and hammer.
WIDESIDE72 is offline   Reply With Quote
Old 02-03-2014, 10:00 AM   #55
original-71
your welcome, thank you for the compliment.
hector
Old 02-10-2014, 05:41 PM   #56
robozride
Any update? you must be done by now?
robozride is offline   Reply With Quote
Old 02-18-2014, 07:37 PM   #57
TexasLS1
TexasLS1's Avatar
Have you been able to finish the drop yet? We're getting anxious here!!
TexasLS1 is offline   Reply With Quote
Old 02-23-2014, 10:37 PM   #58
Ekliptix
Ekliptix's Avatar
I'm waiting for front coils back from Early Classic. The 1.5" coils included in their kit arrived at their shop over 2 weeks ago after I did 3 day shipping. But they only opened the package to read my note late last week after I contacted them asking if they were sending me back the 2" coils they promised....a free exchange for the 0.5" lower coils, but 2 weeks wasted since they didn't attend to my package until I reminded them it was there haha. Oh well, I should get the 2" drop front coils on Wednesday and hopefully put some more hours in getting the front done and the rear aligned.
Old 03-04-2014, 09:16 PM   #59
Ekliptix
Ekliptix's Avatar
Question: I'm putting the front brakes back on but I'm having trouble slipping the caliper back on the rotor with the pads. It feels way too tight. Is the correct way to:
1) With the caliper off the rotor, place the inner and outer brake pad in the caliper.
2) keeping the pads in place against the walls of the caliper with my fingers, slip the caliper onto the rotor.
If so, when I try this, there is no space for the caliper & pads to slip on to the rotor. In the photo, I got it started then lightly tapped the caliper with a hammer but this seems wrong and I don't want to ruin the pads. You can see in the photo the pads have a pronounced ridge running down their face. This fits in to a matching groove in the rotor. Already (removing or trying to place) these ridges on the pads are less then perfect. Not sure how critical this is. Rotors are not expensive but if it's no biggie, great.
Input?
Also, I'm installing a new poly transmission mount. What is the factor torque spec when I'm tightening it up?
Old 03-04-2014, 09:22 PM   #60
Lee H
Lee H's Avatar
Doesn't look like the piston is all the way in, the inside pad backing should be up against the caliper like the outside one. Looks like the inside pad is pretty mangled up.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 03-04-2014, 09:30 PM   #61
Ekliptix
Ekliptix's Avatar
How do I move the piston in to add clearance? Yea, I'll go get some new pads.
Also, I bought new bearings planning to install them but discovered neither the inner bearing or the outer bearing seat fall out of the rotor easily. I suspect I'd need to bring the rotors somewhere that has a press?
Old 03-04-2014, 11:49 PM   #62
WIDESIDE72
WIDESIDE72's Avatar
A purpose built spreader is a available at most parts stores but i just use a big C clamp. Put the pad in up against the piston before compressing.
Old 03-04-2014, 11:52 PM   #63
WIDESIDE72
WIDESIDE72's Avatar
I use a brass drift punch to remove the races. Are you sure the bearings need replacing? You can clean them in solvent and check for pitting wear discoloration or anything out of the ordinary. If they pass just repack them. For years i packed them by hand but recently bought a cone shaped bearing packer that speeds the process dramatically.
Old 03-04-2014, 11:54 PM   #64
WIDESIDE72
WIDESIDE72's Avatar
http://www.etrailer.com/Tools/LubriM...FUVo7AodpDEAOA
Or
http://www.toolsource.com/wheel-bear...rceid=googleps
Old 03-05-2014, 11:45 AM   #65
Ekliptix
Ekliptix's Avatar
I'm presuming the piston will extend back once I remove the c clamp or spreader, right? If so, how do I get the pads + caliper all the way in position on the roter with the spreader/c clamp in the way?
The ECE directions strongly recommended replacing the bearings and packing the new ones with high temp grease. Since I can't remove the existing bearings easily, I'm just reusing them. I think they're fine anyway. Rotor rotates freely. No wiggle.
Old 03-05-2014, 12:19 PM   #66
steelhorse
steelhorse's Avatar
The piston will stay in till you pump the brake pedal. Make sure you pump up the brakes before you try to drive it or you will have no brakes.
steelhorse is offline   Reply With Quote
Old 03-05-2014, 01:05 PM   #67
67ChevyRedneck
67ChevyRedneck's Avatar
First thing I would do is have your rotors resurfaced. Based on the looks of that back pad, there's probably a big groove that will ruin the new pads as well.
If the rotors can not be resurface you will need to buy new ones.
To compress the caliper, open the bleeder valve and push in. You should be able to do it by had using the old brake shoe once the valve is open.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-05-2014, 01:18 PM   #68
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
That stripe in the brake pad is from the factory groove in 71-72 rotors. They are not smooth like 73-87 rotors (and aftermarket replacements) are. That's one way you can spot a 71-2 with original rotors.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-05-2014, 01:23 PM   #69
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
It kind of looks like to me that the raised line in his pad is created by the stock groove in his rotor. If his rotor were gouged bad enough to make a mark like that, it would be too bad to turn. The pads look good otherwise. I would put it back together as is, just depress the caliper so it will go back onto the rotor. I wouldn't even change the pads. They have lots of life left in them. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 03-05-2014, 02:20 PM   #70
WIDESIDE72
WIDESIDE72's Avatar
X2
Fyi a lot of this is covered elsewhere on the board and internet in general under "how to change front disc brake pads".
Old 03-05-2014, 02:22 PM   #71
67ChevyRedneck
Never knew that! That means the suspension I took off a 71 for my 67 had had the rotors replaced at least once then.
Jesse James
Project "On a Dime"
Old 03-05-2014, 02:48 PM   #72
Ekliptix
Ekliptix's Avatar
These suggestions sound conflicting but I'll first try moving the piston without bleading the valve and hoping the piston stays depressed after I remove the spreader (on order 2 day Amazon).
This sounds accurate. I'm 100% sure the groove on the rotors is OEM. The ridge on the pads seems to be there to align them with the rotors. I think I busted some of the ridge off on the pads removing them originally, but 99% of the surface area for stopping is the flat part of the pads.
Old 03-05-2014, 02:55 PM   #73
Lee H
Lee H's Avatar
Don't open the bleeder, just compress slowly, just enough to slip the pads over the rotor. The piston will stay in until you depress the brake pedal.
Old 03-05-2014, 06:16 PM   #74
Tx Firefighter
Open the bleeder or don't. It doesn't make much difference in the big picture. There are no special tools required. Most guys use large Channellocks or a C clamp.
Personally, I open the bleeder. Over time, the dirty muck in the system migrates to the lowest point, which is the calipers. I like to open the bleeder so it flushes the dirty fluid out and new fluid replaces it. There are also good arguments to definitely open the bleeders on later model vehicles. If you don't, the contaminated fluid can get pushed back up into the uber expensive ABS controller. Not good...
Old 03-06-2014, 12:04 AM   #75
Ekliptix
Ekliptix's Avatar
Good input. I will likely go back in and do that now that I'm comfortable with taking apart the front suspension.
Aaaaaand, the front is done! So much easier then the rear. Got a $5 caliper spreader on the way home. Didn't need to bleed the brakes. I'll write up the front suspension process details later. All that's left is the install some 1/2 drop blocks on the rear and center the rear with the adjustable rear panhard bar.
I'm super happy with the front height. Slight tire tuck. It'll likely get a bit lower after settling. I don't mind the slight rake, but the 1/2" rear blocks will make it perfect for me.
