Old 02-11-2014, 11:15 AM   #1
BrentRS1985
BrentRS1985's Avatar
Can I lay frame with 26" tall tires, 2.5" drop spindles and porterbuilt state 1 air
I have a 69 c10 sb. I have already decided to purchase the extreme drop member for the rear, but I'm wondering if it would be necessary for me to spend all of this money on the front if I don't plan on running a big wheel combo. For the foreseeable future I will be running 15" wheels with 26" tall tires on the front and rear. This made me wonder just how low the truck can go with just air and 2.5" drop spindles on the front. Thanks!
1969 C-10 Short Bed
BrentRS1985 is offline   Reply With Quote
Old 02-11-2014, 11:43 AM   #2
broey
Square
broey's Avatar
Re: Can I lay frame with 26" tall tires, 2.5" drop spindles and porterbuilt state 1 a
you will lay crossmember, so your frame will be off the ground about 2 inches in the front and with the extreme in the back your back will lay all the way out. so when you air out your front will sit higher than the rear.
Squarebody Syndicate
broey is offline   Reply With Quote
Old 02-11-2014, 12:19 PM   #3
BrentRS1985
Cool, thanks, it looks like if I want to do it right, I should just go for broke.
1969 C-10 Short Bed
Old 02-11-2014, 01:18 PM   #4
Pro Performance
Pro Performance's Avatar
Plus you will get the advantages of the rack and pinion steering and the low ride height.
Pro Performance is offline   Reply With Quote
Old 02-14-2014, 12:19 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
<<<<This! You can get low with out the PB front suspension kit. You cant ride low with loosing a tooth.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
