Old 02-24-2014, 12:00 AM   #151
TJ's Chevy
TJ's Chevy's Avatar
Re: My 63 Project
Progress=
Nice goin!
Old 02-25-2014, 08:53 PM   #152
ZouchaR
Re: My 63 Project
Little bit of paint on the trailing arms.
ZouchaR is offline   Reply With Quote
Old 02-25-2014, 08:55 PM   #153
ZouchaR
Re: My 63 Project
And of course new bushings.
Old 02-25-2014, 08:56 PM   #154
ZouchaR
Re: My 63 Project
And boy howdy getting this cross member out is a *****!!
Old 02-25-2014, 09:03 PM   #155
TJ's Chevy
TJ's Chevy's Avatar
Re: My 63 Project
Hmmm....That means I ain't gonna even attempt to pull mine! LOL!
Old 02-25-2014, 09:53 PM   #156
ZouchaR
Re: My 63 Project
I won't lie, it sucked, but mostly because I was by myself, trying to get the rivets out laying on my back. If you have a really good air chisel, it shouldn't be as bad. And I had to pull mine as the PO had welded that angle iron piece in for the carrier bearing. And by pulling it, I was able to get it all cleaned up and now I can flip it which will help with the pinion angle and also to give me more play for the driveline.
Old 02-28-2014, 11:15 PM   #157
ZouchaR
Re: My 63 Project
Ok, so some grinding, clean up and a coat of paint. Trailing arm cross member ready to go back in.
Old 02-28-2014, 11:16 PM   #158
ZouchaR
Re: My 63 Project
Finished up the back of the cab, for the most part. I have a couple of small spots to address.
Old 03-01-2014, 12:05 PM   #159
NEWFISHER
NEWFISHER's Avatar
Re: My 63 Project
"flip it" do tell...I thought moving the trailing arm mounts was the hidden secret. Did you pull the whole enchilada to clean it up and paint it vs. flipping the brackets?
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 03-01-2014, 06:13 PM   #160
ZouchaR
Re: My 63 Project
This picture is about the best way to really show. The clearance from the frame to the top of the driveline opening is about .5 inches stock. As seen in in this picture.
Old 03-01-2014, 06:14 PM   #161
ZouchaR
Re: My 63 Project
Close up.
Old 03-01-2014, 06:19 PM   #162
ZouchaR
Re: My 63 Project
Now the bottom side, stock has more clearance for the driveline. About 2 inches.
So, I pulled the entire crossmember, first to pull out that angle iron that the PO welded in. And since I now have it out, I can bolt it back in, upside down if you will. This will give me more driveline clearance on the top side of the crossmember. And since I have dropped the rear end four inches, it should be better for driveline clearance. Make sense?? If it doesn't work out, I can flip it back over without much work.
Old 03-01-2014, 11:14 PM   #163
TJ's Chevy
TJ's Chevy's Avatar
Re: My 63 Project
Trailing arms look good! Nice work!
Old 05-12-2014, 11:24 PM   #164
ZouchaR
Re: My 63 Project
So I have been working a ton, and saving some money so I could get a new rear end as mine will not work. So I called Moser today, and they told me that they couldn't make a rear end that would work with my disc brakes. I called a local company, pretty much the same thing. So I was pretty bummed out.
I happened to check out craigslist today..... JACKPOT!!!!
12 Bolt, trailing arm suspension and 30 Spline!!!
Old 05-12-2014, 11:26 PM   #165
ZouchaR
Re: My 63 Project
After a little cleaning, it's ready to go to the machine shop to get checked out, new bearings and posi unit!
And it has 3.73 gears already.
Old 05-21-2014, 07:00 PM   #166
ZouchaR
Re: My 63 Project
Rear frame before.
Old 05-21-2014, 07:00 PM   #167
ZouchaR
Re: My 63 Project
And after!!!
Old 05-21-2014, 07:01 PM   #168
ZouchaR
Re: My 63 Project
And now the cross member flipped over and back in.
Old 05-22-2014, 01:47 PM   #169
1963c-10
1963c-10's Avatar
Re: My 63 Project
Coming along nicely!!
1964 Short bed trailer
Old 05-22-2014, 06:33 PM   #170
ZouchaR
Re: My 63 Project
Look what I picked up today.
Old 05-23-2014, 10:42 PM   #171
ZouchaR
Re: My 63 Project
So we had a very productive day... Started off with the brake booster and master cylinder. That's my son helping out.
Old 05-23-2014, 10:43 PM   #172
ZouchaR
Re: My 63 Project
And here is an after picture.
Old 05-23-2014, 10:44 PM   #173
ZouchaR
Re: My 63 Project
Then we moved on to the power steering gear box. And the steering linkage.
Old 05-23-2014, 10:45 PM   #174
ZouchaR
Re: My 63 Project
And the steering column.
Old 05-23-2014, 10:46 PM   #175
ZouchaR
Re: My 63 Project
Then I went to the shop and picked up the rearend.
