#26 |
Re: Project Cannonball C10
Any updates?
68 Short step!! |
#27 |
Well quite a bit has happened over the last couple of months, mainly the truck has been stripped and sent out for blasting, and the chassis arrived a few weeks back. I've been holding off on posting any more until the build really gets underway. I'm hoping to get things moving around mid-April.
Perhaps until then I'll throw up a few photos from over the winter. |
#28 |
I spent most of December stripping down the truck and bagging everything up. Once it was gutted I towed it up to Sacramento to get blasted and primed.
It left as a rolling hulk... ![]() ...and came back squished into a Uhaul ![]() ![]() Both the cab and bed were as clean as I was hoping for. Only some minor pinhole rust through the firewall. Front panel on the bed is trashed so we're just going to replace it. ![]() While doing the teardown I realized the doors that came on the truck are the newer ones which accept the full width door panels. I really want the period style so it was a chore to find clean 73-76 small inner panel doors, but after a month of calls and searching I found both driver and passenger doors. |
#29 |
#30 |
damn....whole new level!
What shop is doing the work?
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
#31 |
Wes @ One Off Customs in Santa Clara, CA.
He's got a wild Camaro project finishing up right now before we can really get started on the truck. I'm hoping for April ![]() |
#32 |
Having this time has given me a chance to find/paint/rebuild a bunch of stuff...
Grabbed a non-column shift steering column out of a '76 on Thanksgiving day for $20. ![]() Pulled the whole column apart, sanded and sprayed it in semi-gloss black, put in fresh bearings and fitted with new ignition/turn signal switches. Also topped it with a "GM Comfort Grip" wheel in 14" diameter. I took a guess on the size, which matches the diameter in my M3. I put in a Dakota Digital turn signal lever with 4 wire cruise control (HND-3). This lever really looks like it came with the truck, but I'll be able to wire it into the ECU for modern cruise control. ![]() |
#33 |
Over the holiday break I rebuilt the vent window assemblies. What a nightmare project that was! Funny thing is I have no photos from any of that...guess I didn't want to remember.
I also ordered a bunch of Eastwood paint supplies and freshened up lots of the small parts. Turn signal/parking light housings ![]() Horns ![]() ![]() Inner door brackets ![]() |
#34 |
And, of course, the delivery guys have been showing up a lot lately
![]() Vintage Air Gen IV ![]() Totally Stainless Bolt Kit ![]() A giant box with a reproduction hood that I'm not going to use now ![]() An E-Stopp parking brake kit. I didn't want to try hooking the ebrake pedal up to the Wilwood setup, and I'll hide the button on this kit for a bit of theft deterrence. ![]() |
#35 |
Slots go on anything!
Looking good Mike! This is going to be unreal when it gets together. Digging the Mini, too.
1974 Jimmy- 5.3/4L80e/NP241 |
#36 |
![]() Join Date: Oct 2011
Subscribed. This is going to be good.
1998 GMC Suburban 2500 454 4X4 1984 GMC Jimmy - 3/4 ton axles, 5.7TBI 1990 GMC Suburban (Parts Donor) scrapped 1965 Buick Riviera - (Sold) 1999 Mercury Grand Marquis 1965 GMC SBSS (Sold) |
#37 |
wrd
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) |
#38 |
With a pile of parts like that, it's gotta be good!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#39 |
Thanks guys. Its coming together one part at a time. I'm trying to do something every day on it, big or small. This morning was sanding and spraying the rear window channels inside the doors. Last week I was focused on wiring, and put together my own headlight relay upgrade integrated into the factory style forward lamp harness.
BTW, after many months of waiting, all my wiring harnesses showed up from M&H Electric. They turned out awesome! They did such an exact job of matching the factory colors and plugs. I went with their classic auto fuse series which comes with an ATO style fuse block and some extra circuits for electric fans and fuel pumps. I highly recommend their setup for anybody doing a restoration on one of these trucks. ![]() |
#40 |
Second Chance Program
Subscribed!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
#41 |
#42 |
cool!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
#43 |
Damn, nice build
#44 |
Bretzke Racing Inc.
![]() <--- Impatiently waiting for more progress! ![]()
1982 Chevy Silverado C-10 RCLWB - IN PAINT - Inferno Orange Metallic Lowered 4.5/6 - 358 SBC 10.5:1, Comp XE268H cam, Aluminum heads, 650 Double pumper Holley carb, 2400 Holeshot Converter, upgraded T/h350 Trans. Stock Rear end for now (3.08 gear) ![]() 2004 Chevy Silverado 1500 LS RCSWB - Dark Spiral Gray Metallic Lowered 2/4 - 4.8L V8 4L60E 10-bolt. some goodies --- NEW DD 11/9/12 ![]() ![]() "Expect the Un-expected" "Gas, Grass, Or Ass...No one rides for FREE!" ![]() |
#45 |
Still need to go through the photos but you might enjoy this teaser video...
http://vimeo.com/89818376 |
#46 |
#47 |
that chassis tho!!!!!
#48 |
nice!
#49 |
Boosted Member
Yowzer, this is gonna be sweet.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
#50 |
Hot Stuff! Can't wait to see the next step.
