Old 03-06-2014, 12:40 AM   #76
Tillik
Tillik's Avatar
Re: My 4/6" ECE lowering install thread - 72 Shorty
Very good job!
James B.
1967 Chevy Fleetside Shortbed 4X2 (Black & Beautiful)
1971 Chevy Fleetside Shortbed 4X4 (White & Rough)
Tillik is offline   Reply With Quote
Old 03-06-2014, 10:42 AM   #77
c10Dream'n
c10Dream'n's Avatar
what a difference a stance will make. lookin good.
c10Dream'n is offline   Reply With Quote
Old 03-06-2014, 11:23 AM   #78
TexasLS1
TexasLS1's Avatar
That makes an awesome truck look more awesome! Nice work!!
TexasLS1 is offline   Reply With Quote
Old 03-06-2014, 02:28 PM   #79
brawley
Easy Does It
brawley's Avatar
Love ECE parts, perfect for these trucks, did this on my 63' and went together sweet, looking Good!! nice truck
brawley is offline   Reply With Quote
Old 03-06-2014, 03:07 PM   #80
Shocks
Shocks's Avatar
I love everything about this truck.
Shocks is offline   Reply With Quote
Old 08-25-2014, 11:25 AM   #81
cericd
cericd's Avatar
Now that you've had some time to drive it around, do you plan to add a c-notch? Any bottoming out? Do you still have the factory bump stops in the rear or did you trim/remove them?
Also, have you had any issues with the drop spindles or a-arms rubbing the inside edge of your rims?
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 08-25-2014, 12:02 PM   #82
Ekliptix
Ekliptix's Avatar
I've put some good miles on it since the drop. I don't plan to install a c-notch. I've never heard or felt the rear axle hitting. I did cut 1/2 off the rear bump stops for some additional clearance.
In the front, I have not looked to see if there is any rubbing inside the rim against the spindle or a-arm. There is certainly no noise. The only rubbing that occurs is the tires touch the inner fender over some bumps. I've come to the conclusion that it's because I'm running 275 tires all around. Less wide tires up front would likely resolve this.
With the springs and new swaybar, the truck corners much better and flatter. In general, it feels much tighter.
Ekliptix is offline   Reply With Quote
Old 08-25-2014, 01:05 PM   #83
Elliot949
Elliot949's Avatar
Truck looks GREAT!!!! Perfect Stance...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD
Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847
Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD
B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210
Elliot949 is offline   Reply With Quote
Old 08-25-2014, 08:25 PM   #84
Mike C
Mike C's Avatar
Truck looks awesome! I've got 2 1/2" ECE spindles and 2" springs for the front of my '69 short step. I'm going to do an axle flip on the leafs in the rear, and would be STOKED if it sits as well as yours. Nice work.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 08-25-2014, 10:44 PM   #85
tommyd241
tommyd241's Avatar
Spot on!!!!
'68 SWB Fleetside
'98 K1500 Silverado
tommyd241 is offline   Reply With Quote
Old 01-08-2015, 11:16 AM   #86
Coursey
Coursey's Avatar
I am getting ready to do the same install in about a week.
Any pre-advice?
Truck looks awesome.
Coursey is offline   Reply With Quote
Old 01-08-2015, 02:19 PM   #87
big_al_71
big_al_71's Avatar
That's the best kit from ece
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 01-08-2015, 11:32 PM   #88
zicc1835
zicc1835's Avatar
interesting that this thread got reserected today ...because i was talking to a freind TODAY about installing my ECE kit actually i bought a bag set up recently ( from another board member)so in the rear at least I'm gonna use bags instead of the 6 inch drop springs any advice on this would be appreciated. Can someone also tell me do the top ECE shock relocater brackets bolt into the rivet wholes that the originals where in....i should mention i bought my kit from another board member about 2 years ago and have not even opened those boxes to look for directions
zicc1835 is offline   Reply With Quote
Old 01-09-2015, 07:19 PM   #89
OregonNed
OregonNed's Avatar
Looks awesome! Would love to make my '68 the same
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 01-09-2015, 07:55 PM   #90
Malamute
Malamute's Avatar
It turned out great. What size tires are you running?
Malamute is offline   Reply With Quote
Old 01-10-2015, 06:05 PM   #91
Ekliptix
Ekliptix's Avatar
Any pre-advice?
I've already forgotten some of the heartaches of the install. Grinding off the rear rivets to install the new upper shock mount was by far the step that required the most patience. Once you've done that, the rest seems easy. Getting the brake caliper spreader is another tool you'll need. I took the install on leaving a lot of time for myself and without a ton of mechanical experience.
If you get stuck or find the instructions leaving out details, feel free to post here and I'll share my input.
Yes, you use the original rivet holes in the frame to mount the ECE upper shock relocate bracket. Photo on page 2. PM me your email if you want a copy of the install directions.
BFG 275/60/15. I believe the front tires are a bit too wide and rub on the inner fender over some bumps. I'd go a bit more narrow on the fronts next time.
Old 01-18-2015, 06:35 PM   #92
GeirJB
GeirJB's Avatar
Nice Stance you got there now!
Think I will do the same with my -67! I have drop spindels in the front and some 5" CPP springs in the Rear. No shock relocations!
So ECE kit with 2" front springs, 6" rear and all the other stuff will be great for mine truck! Just have to check if that kit is possible to get without drop-spindels!
How is the ride now with this kit?
MY -67 Chevrolet C-10, http://67-72chevytrucks.com/vboard/s...d.php?t=622636
Other Cars -69 VW 1600 Variant, 82 VW Polo G40, - 96 Subaru Impreza GT Turbo, -01 BMW 316ti
GeirJB is offline   Reply With Quote
Old 01-18-2015, 11:14 PM   #93
Ekliptix
Ekliptix's Avatar
It's firm. I've used bilstein shocks on sports cars in the past with great results, but I think the shocks with the ECE kit are on the lower end. A higher end set of shocks intended for short shock travel may provide a less firm ride.
Old 02-01-2015, 02:25 PM   #94
Coursey
Coursey's Avatar
Which way is up on the sway bar?
Old 02-01-2015, 02:30 PM   #95
Mike C
Mike C's Avatar
Like bottom pic on my truck. See your thread...
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 02-01-2015, 02:41 PM   #96
lolife99
67-72 parts collector,…
lolife99's Avatar
I think it depends on the amount lowered and if you still have the stock frame stand, lowered ECE style frame stands or no frame stands at all.
I always just look at ride height and see how it would fit the best.
I've long forgot which direction the factory installed them. Ha
Keith
Convert to disc brakes.
Old 02-01-2015, 02:50 PM   #97
BHyatt
I have found that an air chisel makes short work of those pesky factory rivets.
BHyatt is offline   Reply With Quote
Old 02-01-2015, 06:03 PM   #98
No8Easy2
No8Easy2's Avatar
yes yes indeed! its spot on man, now put the tools down and don't touch it again!
"They Don't write songs about Hondas "
1972 C10 "Ole Red--blood, sweet & beers"
USMC 1989-1997 1st Anglico
No8Easy2 is offline   Reply With Quote
Old 02-16-2015, 05:19 PM   #99
hdff
hdff's Avatar
I am fixing to put the shock relocators and super panhard bar, how was the alighnment of the panhard bar? Also what are the shocks you used, are they shorter for a lowered truck?
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 02-16-2015, 06:14 PM   #100
Ekliptix
Ekliptix's Avatar
The alignment of the panhard bar was easy. I installed it, measured the distance from the rear drum to the fender on each side, it wasn't even so I adjusted the panhard bar via the threads that make up its ends until the rear axle was centered.
For shocks I'm using the ones included in the ECE kit, KYB shocks. They are ok but if they had an upgrade option for the shocks, I'd get them.
