Closed Thread
Old 03-16-2014, 01:47 AM   #376
BlacklandCamper
Re: What did you do to your truck today? Chapter II
Got my new coolant hoses installed, along with a new thermostat, and outlet. Pulled the old exhaust off the manifolds, and fired it up. Open rams horns are LOUD!!
Managed to get the old mufflers cut off the pipe I am reusing, and got the driver side ready to weld up to the muffler before the thunderstorms hit. Since I was using my buddies welder (and he took it home with him), I will be taking a different approach to finishing the exhaust. Instead of welding (too easy to burn through), I will fall back on my old technique, and braze it together with a torch and wire. Hoping to make more progress next time I have a day or so off work.
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast!
Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun.
1st BN 3rd MAR. '00-'04
BlacklandCamper is offline
Old 03-16-2014, 04:42 PM   #377
Ridgeclimber
I got the right rear cab corner and right outer rocker welded on today. I'm done welding, finally.
Ridgeclimber is offline
Old 03-16-2014, 09:47 PM   #378
ole dollor
ole dollor's Avatar
you did a great job ... looks good. wish I could still weld.
ole dollor is offline
Old 03-16-2014, 10:32 PM   #379
OregonNed
OregonNed's Avatar
Pulled the grill trims off my truck to polish up and replace a few broken clips.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 03-16-2014, 10:58 PM   #380
zicc1835
zicc1835's Avatar
off to finish body work and get some paint on her
zicc1835 is offline
Old 03-16-2014, 11:00 PM   #381
zicc1835
zicc1835's Avatar
her ride
zicc1835 is offline
Old 03-16-2014, 11:59 PM   #382
Ridgeclimber
Thanks. Learning as I go. A buddy of mine is the body man that's helping me and needs the credit for helping me get this job done.
Old 03-17-2014, 12:12 AM   #383
tcoop68
tcoop68
tcoop68's Avatar
Replaced ,rotors bearings calipers pads coil springs upper and lower ball joints , upper and lower a arm pivot rods, basically rebuilt the front end on my 72 sw.
tcoop68 is offline
Old 03-17-2014, 12:15 AM   #384
tcoop68
tcoop68
tcoop68's Avatar
Do you have to use a different motor mounts when you put a late model in , just wondering, if so where can you get them.
tcoop68 is offline
Old 03-17-2014, 12:20 AM   #385
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Pulled (rolled up) the tonneau, stashed the "bows", and drove the 20 mile round trip to collect 18- 8 ft. 1-1/2" boards,
2- 10' 2 x 10's, 2- 8' 2 x10's, and three rolls of wire for the next round of squirrel fighting/gardening.
The Boss () bought lunch, watched the garden supplies on the way home, and helped extract them from the bed without
a scratch (on the bed) when we got to Casa de Magwa.
On the trip, three people asked me the year of the truck. The guys at the lumber yard were respectful of my wanting to be
careful loading.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 03-17-2014, 12:23 AM   #386
Motoxrrar
These are what I used. However I have a gen 4 ly2 4.8L
http://www.earlyclassic.com/catalog....ry=New%20Items
Motoxrrar is offline
Old 03-17-2014, 12:28 AM   #387
68anthony
68anthony's Avatar
Finished cleaning up the cab and got it all sealed up in PPG DP-90LF.
Check out my build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=606231
68anthony is offline
Old 03-17-2014, 12:29 AM   #388
tcoop68
tcoop68
tcoop68's Avatar
Originally Posted by Lees68GMC View Post
Ready to Start for first time just waiting on the 'puter, any day now
Originally Posted by muckyp View Post
Got my new seat installed!
What are they out of they look nice.
tcoop68 is offline
Old 03-17-2014, 12:42 AM   #389
Motoxrrar
Originally Posted by 88fordf150 View Post
Did this last night. Powder coated my glove box door chrome & wrinkle black.
I am offended by your name. But I love your glove box door. Beautiful combo!
Old 03-17-2014, 05:52 AM   #390
ivanuf2
ivanuf2's Avatar
Installed core support filler panel. I had to make an opening for the A/C and re-paint it with SEM hot rod black. It looks really good and cleans up the engine bay.
ivanuf2 is offline
Old 03-17-2014, 07:39 AM   #391
csfields
csfields's Avatar
Put my Radio, Dash Speaker, Hidden Antenna, Glove box Door and Liner in. Beautiful day on Satuday - 73 degrees. Also got lots of wiring done, Been a long build, but slow and steady wins the race....
Thanks,
Casey
71 Chevy C-10 SWB 350/400 PS, PB
The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045
The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699
csfields is offline
Old 03-17-2014, 07:41 AM   #392
csfields
csfields's Avatar
I use DP90 on all my stuff. Love it.
Thanks,
Casey
csfields is offline
Old 03-17-2014, 07:43 AM   #393
csfields
csfields's Avatar
Originally Posted by Mike_The_Grad View Post
Just got my package from member tkorinek, Thanx again by the way. This should keep me busy for a while...
I purchased the same kit and it has been wonderful to install, not complicated.
Thanks,
Casey
csfields is offline
Old 03-17-2014, 09:07 AM   #394
Ridgeclimber
What did you do for a hidden antenna? I have to install one myself shortly.
Old 03-17-2014, 09:44 AM   #395
csfields
csfields's Avatar
They have a hidden antenna that sticks under dash and plugs in the back of the radio as always, then you hook up the pwr antenna lead to it for power. Not sure about reception yet, but we'll see.
Thanks,
Casey
csfields is offline
Old 03-17-2014, 11:18 AM   #396
texjake
texjake's Avatar
Where did you get your radio from & is it the USA-230?
"Now all I need is a shop to go with my shop vac!"
texjake is offline
Old 03-17-2014, 11:35 AM   #397
slowcpe
slowcpe's Avatar
I've just keep taking parts off and painting. I'm really wanting a sand blaster as I'm awfully tired of sanding only to find its not perfect. I'm also just awfully tired of sanding.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline
Old 03-17-2014, 12:35 PM   #398
csfields
csfields's Avatar
Yes its the 230. I got it from Classic Car Stereos.com It's the am/fm radio with ipod port. The knobs came with it and it looks pretty stock.
Thanks,
Casey
csfields is offline
Old 03-18-2014, 01:33 PM   #399
In The Ten Ring
Last night I came up with an idea of how to remove, store, and reattach my custom bed cover and fix it so that it's a one man job!
I just now paid for the grill guard....the latest of neat things my truck doesn't need to regain the road but will be cool to have when she does!
In The Ten Ring is offline
Old 03-18-2014, 02:17 PM   #400
BugzC10
BugzC10's Avatar
Installed pinion angle shims...1.5 deg.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Closed Thread
