Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 03-12-2014, 01:28 AM   #1
Captainfab
60-66 Nut
HD Carrier Bearing Mount
I will be making more of these in the future but as of now I have just this one. If you currently have the light duty driveshaft and carrier bearing that hangs from the top of the trailing arm crossmember and you want to upgrade to the HD driveshaft and carrier bearing, you will need this bracket. This mount bolts to the bottom of the trailing arm crossmember and the carrier bearing bolts to it.
The mount I am selling is shown in the first two pics. The rusty one in the third pic is an original mount. The price on this new mount is $47.50 plus shipping of $9.20.This pricing is always current and up to date. As always, I will combine shipping when you purchase two or more of my products. To make a purchase, post in this thread, send me a PM or send an email to captainfab454@hotmail.com, and I will give you the ordering and payment instructions and current lead time.
Old 03-15-2014, 09:30 PM   #2
theredmeadow
Re: HD Carrier Bearing Mount
Will this work for the regular 70 c10 U-shaped carrier bearing?
theredmeadow is offline   Reply With Quote
Old 03-16-2014, 12:19 AM   #3
Captainfab
60-66 Nut
If you are referring to the HD carrier braring, yes it will work, That is what this mount is made for, the '63-'72 HD carrier bearing.
Old 03-16-2014, 01:29 AM   #4
theredmeadow
are you still selling these?
Old 03-16-2014, 01:35 AM   #5
Captainfab
60-66 Nut
I have only 1 of these right now.
I am hoping to make more, but that depends on the interest in them.
Old 03-16-2014, 01:49 AM   #6
theredmeadow
Sorry I'm a noob.
Does it line up for this part? for the hole to hole measurement?
http://www.oreillyauto.com/site/c/de...upport+bearing
Old 03-16-2014, 01:57 AM   #7
Captainfab
60-66 Nut
Yes it should. My mount is a duplicate of the original mount.
Old 03-16-2014, 02:03 AM   #8
theredmeadow
sweet! that's what I need
Old 03-16-2014, 11:47 PM   #9
Captainfab
60-66 Nut
I'll send you a PM with payment info.
Old 03-18-2014, 12:10 AM   #10
66 C10 383
I'm definitely interested in one if this is still available.
Doug
Old Build Thread - 383/T56
http://www.67-72chevytrucks.com/vboa...d.php?t=540838
Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua
5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital
http://67-72chevytrucks.com/vboard/s...d.php?t=778784
66 C10 383 is offline   Reply With Quote
Old 03-18-2014, 01:06 AM   #11
Captainfab
60-66 Nut
This one is sold to 66 C10 383.
I guess I'll see about making up some more.
Old 08-09-2014, 12:48 AM   #12
Captainfab
60-66 Nut
I do have more of these available. They are $35.00 plus $5.50 for shipping.
Here are a couple pics of the HD driveshaft for those not familar with how it compares to the light duty driveshaft assembly.
The front half:
The rear half:
Old 09-09-2014, 10:54 AM   #13
crakarjax
crakarjax's Avatar
Is that rear shaft a slip shaft? Going to have to inspect my C-20 to see if I have the HD bearing in there...
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 09-09-2014, 08:57 PM   #14
crakarjax
crakarjax's Avatar
Hmmm ok I don't have the HD bearing. I don't see how this bracket would work for me though -- the support bearing hangs down on the backside of the crossmember while this one would mount to the front side -- I'd need new driveshafts to make this work for me, correct?
Old 09-09-2014, 09:37 PM   #15
crakarjax
crakarjax's Avatar
Not sure why I can't edit my posts, that is super annoying... sorry to TC. To answer myself, yes I would need a new driveshaft to make the conversion. I think there might be a market for a simple conversion bracket to adapt from donut style to horseshoe, either like the stock rear-top horeshoe mount or a bolt-on converter bracket.
Old 07-06-2015, 04:46 PM   #16
PLYONS11
Captain
Do you still make/have any of these brackets?
I may need one. Not sure yet if its going to work with my crossmember though.
My 3/4 - 1/2 ton conversion is fighting me at every turn. I thought I did all the research before I bought the new drop xmember and coil spring set up, but I did not at that time know about the different carrier bearings and drive shaft combos.
Basically if I could find the 1/2 ton HD carrier bearing with the 1.378" ID bearing that would be great and would work perfectly with the parts I already have. But I have found nothing like that.
My thought is that I could use your bracket but bent the tabs back down to flat, then drill holes in my xmember. My xmember is flat on the bottom side, unlike the stock one.
PLYONS11 is offline   Reply With Quote
Old 07-06-2015, 10:57 PM   #17
Captainfab
60-66 Nut
Yes I still make these carrier bearing mounts as well as all of my other products.
I can weld the mounting tabs on, flat instead of angled to fit the original crossmember.
I was not aware of a difference in the HD carrier bearing between the C10 and C20's.
Old 07-07-2015, 12:28 AM   #18
Captainfab
60-66 Nut
You might PM or email me the center to center dimension of your carrier bearing mounting bracket. I will check it against my mounting bracket.
Old 07-07-2015, 01:00 AM   #19
PLYONS11
I can't exactly say that I know this to be fact. I gathered this through my research and comparing parts. The bearing I have has an inside dia of 1.378. And the bolt holes measure 6.624 center to center. There is also another bearing of the same style that has an ID of 1.1811 and the bolt holes measure slightly less. Don't have a measurement at this point. The CPP adapter bracket uses this bearing, unfortunately it is to small for my driveshaft. It also mounts rearward of the crossmember which is to far back for my current shaft length. I believe this part is for use with the slip style trans output shaft. I have a flange style that bolts to the trans.
I'm going to do some more thinking, but I may take you up on your offer to make a bracket with the tabs welded on flat. I'm trying to avoid drilling into my new powder coated crossmember if at all possible. This is a temporary solution to get the truck mobile. I am moving to Alabama soon and the relo company will only transport the truck running and driving, otherwise it's my responsibility and expense. When I do the engine/trans swap I will obviously have to buy a new driveshaft.
Old 08-08-2016, 01:02 AM   #20
Captainfab
60-66 Nut
I will be on vacation from 08-08-16 thru 08-25-16. If you wish to make a purchase you can post here in this for sale thread, send me a PM or an email to captainfab454@hotmail.com. I will reply to your inquiry when I return on the 25th. I do currently have a list of orders to build and ship when I return but I will add your name to the list in order of when received. Thanks for your understanding.
Old 06-06-2017, 11:21 AM   #21
Hart_Rod
Hart_Rod's Avatar
Are these still for sale? I need one ASAP. Thanks,
Rob
Hart_Rod is offline   Reply With Quote
Old 06-06-2017, 11:39 PM   #22
Captainfab
60-66 Nut
All of my products are for sale everyday. I replied to your email earlier today.
Rob
Old 06-07-2017, 08:24 AM   #23
Hart_Rod
Hart_Rod's Avatar
Payment sent. Thanks John!
Old 06-08-2017, 12:44 AM   #24
Captainfab
60-66 Nut
Payment received......thanks
Old 01-10-2018, 01:12 AM   #25
Captainfab
60-66 Nut
I am officially notifying everyone that I will be on vacation from 02-05-18 thru 02-13-18. I will do my best to get all orders built and shipped before I leave, if placed by 01-31-18. Orders placed while I am gone will be built and shipped in order of receipt of payment once I return. Thanks for understanding.
