#401 |
Re: What did you do to your truck today? Chapter II
I finished painting the steering column (no more orange column, yahoo!) after I repacked the upper bearing. After doing some research on the shift indicator that I have, it looks as if someone changed out the '68 column with a '70-'72, I don't know for sure because the harness coming out of the column is different than what it plugs into under the dash (but it still works) and the fact that it was factory orange and the rest of the trim of the truck is red. And yes, I masked off the shift indicator clear lens for the fiber optic light, it just looks like I painted over it and that's not a botched paint job, its a reflection in the paint.
"Now all I need is a shop to go with my shop vac!" ![]() |
#402 |
Got bed and bumper on today
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
#403 | |
![]() Join Date: May 2012
#404 |
RAT1968 '68 Cab/'71 Parts
Nice set up all the way. Really like the script on the gate.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#405 |
yep, as long as the dirt will stop blowing....lol
#406 |
![]() Join Date: Oct 2013
Finally the day has arrived! Two separate pieces became one once again. It feels good to see your ideas,time,hard earned money and hard work all come together. At least everything from here on out is just bolt it up the way it used to be!
1972 C/10 LWB - Mine 1964 C/10 LWB - My Dad's Instagram: Mike_The_Grad |
#407 | |
JG |
#408 | |
Thanks. And, by the way, "congrats".
#409 |
![]() Join Date: Jul 2013
That's a big block or "heavy duty" (C/30 and up) pump. I ran one on my 69 back in the day.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
#410 |
Magwakeenercew2jh, the fuel pump I have has one inlet and two outlets. One for the carb,which is a threaded flare fitting. And a smaller barb type, which is a vapor return line, that runs back to the fuel tank. My guess is that its part of the emissions control system. Also maybe to help reduce vapor lock?
#411 |
I was finally after over a month able to get a weather break, borrow a truck, and get help to unloadthe fender I had shipped to a body shop. 148 pounds all told the weight of the crate and fender. I hope to uncrate it in the coming weeks and then store it away for when the hardcore restoration comes.
#412 |
![]() Join Date: Feb 2011
Picked up my "new" Vortec heads from the machine shop and dropped off my new crank, rods, pistons, rings, balancer and flywheel to be balanced.
#413 |
#414 |
After about 2 years recovering from surgery, the need for the truck to be running is coming soon. I drove it around a few times but the trans was slipping, shifting hard. I found a place that will switch the turbo 350 with a 700r4. I was on my way down, not even out of my work's parking lot, I stopped for a second and blewie, no gears, fluid everywhere. The shop is about 30 miles away and I called my roadside assistance company, they wanted to tow it to a Chevy dealership 5 miles away because that's what's stipulated in the contract. I tried to explain the trans isn't going to be repaired, it's getting replaced and she tried to tell me they could only authorize the closest shop. I said the place I was going to was the closest place that will do the work I needed. After a couple times being put on hold they did come back with a wrecker that would take it there. They're going to do the work after hours and with luck it should be done Monday! They said the only issue will be there isn't 4 indents on the column so first won't have a slot. No biggie for now.
#415 |
In the last two days I got the roof, back of the cab stripped. Started the filler work. I'm tired of sanding now.
#416 |
#417 | |
Good arms. It must have been good General paint, huh?
#418 |
#419 |
Looking sweet! Dakattack7, hard work pays off. Inspires me to remove all the oxidation from mine also.
#420 |
![]() Join Date: Mar 2010
Dackattack7 good job! The truck looks great! It also looks pretty original, I encourage you to keep it that way. Not many originals left around.
#421 |
There's a great trick RV'ers use to keep that shined up original paint looking great : commercial floor wax ! you put it on several coats and it makes the trig look amazing , keeps the tin worms at bay too .
Once a year does it . Your rig looks very nice now .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#422 |
Sorry, double post
#423 |
Thanks everyone. Yea I'm definitely in to the original look, here's how it looked when I got it. I've been putting it back to original. You can't really see in the pictures, but it has 8 screws in the door where a sign or something was, there's some kind of antitheft system that has an extra door lock on the driver side. I haven't even pulled the doorpanel to see whats up, but a wire goes in to the door panel. The seat has been recovered at some point, the engine isn't original, the paint on the roof is brushed on house paint and the box for the bedside toolbox is replaced by an aux tank. So, it's not as original as I would like, but overall I like it!
#424 |
![]() Join Date: Mar 2011
had some fun this weekend clip off motor/ trans out ........
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#425 |
Who Changed This?
![]() Join Date: Jan 2013
I had to work both days; the old boy has been parked around the corner for a couple of weeks without being driven. I have a '68 Skylark California GS. I bought a donor car to bring it back to stock over a month ago, and I haven't had time to work on that either. In the last three months, I've had one weekend "free", most of which time ended up being "honey-dos". Good thing the old boy runs well. I was going to at least drive it today to slosh the fluids around, but didn't get to it.
