03-26-2014, 08:15 PM | #26 | |
The Older Generation
Re: Shift Indicator adjustment
Looks like someone has replaced your stock parts with a Heim joint at that location.... The adjustment instructions in this thread will not work for that. LockDoc
03-26-2014, 09:14 PM | #27 |
You could try to tighten the he in down. If you can't go any further then you can probably cut the threads off some. Let us know how it goes
03-26-2014, 09:50 PM | #28 | |
Thanks for the help. Would this solve my issue or is it something completely different: http://www.speedwaymotors.com/E-Z-Sh...-Kit,1926.html |
03-26-2014, 10:30 PM | #29 | |
LockDoc
03-26-2014, 11:25 PM | #30 |
after browsing YouTube for a few hours I found a video that shows how to adjust the shift indicator spacing using a Lokar Shift Linkage (which I believe is what the PO installed).
Might be helpful if anyone needs in the future: |
03-27-2014, 12:37 AM | #31 |
Location: Sassafras. Victoria. The beautiful Mount Dandenong Ranges
Is it possible that the collar the that the letters are mounted to has moved to the right slightly? Just a thought.
CLASSIC 1970 C20 WITH A RUMBLIN' V8. IT'S MY MID-LIFE CRISIS ONLY IT AIN'T A LITTLE RED SPORTS CAR OR A HARLEY! IF YOU'RE GUNNA SKATE ON THIN ICE, YOU MAY AS WELL TAP DANCE! |
03-27-2014, 12:39 AM | #32 |
03-27-2014, 01:07 AM | #33 |
OK, but the collar itself, have you tried grabbing it with both hands and try to rotate it a little back and forth? It wouldn't need to move much.
