Old 03-28-2014, 08:24 AM   #1
Posted
Posted's Avatar
Mouting my alternator pic needed!!!!!
Guys, I am just abouot done with the motor and tranny build/swap. I am mounting my alternator and it just does not seem quite right. I do not remember if I mount off of the water pump or just the block. If I go off the block I seem too far back. Any pics of someone out there showing the alternator with brackets on a 350?? driver side mounted above the power steering.
I would appreciate any help!!
thanks!!!!!!!
Posted is offline   Reply With Quote
Old 03-28-2014, 10:03 AM   #2
1972SUPERSB
1972SUPERSB's Avatar
Re: Mouting my alternator pic needed!!!!!
Here is a decent pic of mine. Not sure it will help much or not. It mounts off the block with 2 brackets
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline   Reply With Quote
Old 03-28-2014, 10:07 AM   #3
Posted
Posted's Avatar
thank you sir! That helps!!
Old 03-28-2014, 10:09 AM   #4
Posted
Posted's Avatar
I have a new water pump and chrome pulleys. You think the depth of stock pulleys is the same as the new chrome? Should be I would think?
Old 03-28-2014, 10:12 AM   #5
1972SUPERSB
Should be but put them together before you mount them to compare and check to make sure
Jeff
Old 03-29-2014, 06:18 PM   #6
Posted
Posted's Avatar
are you guys using a short water pump? I'm out today long water pump and now all of my alternator and other items seem to be out of alignment.
Old 03-29-2014, 06:22 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Short pump is posted above by 1972SuperSB. That is the original configuration for these trucks. Alternator mounts on the driver side.
Long pump became standard on trucks in 1973 and newer. They mount the alternator on the passenger side.
If you're using long pump, you need all of the long pump stuff, brackets, pulleys and everything. It's an all or nothing deal. One or the other....
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-29-2014, 06:32 PM   #8
Posted
Posted's Avatar
This explains a lot! I was told I needed a long pump! What a mess! Thanks! Any idea what pulled I need? LLol.jegs sent me the wrong short pulleys last week and that is what started this
Old 03-29-2014, 06:44 PM   #9
Tx Firefighter
I can't help you with the pulleys. I got burned years ago by aftermarket pulleys and have stuck to original GM ones ever since.
If your alternator is driver side mounted like the fellow posted above, you need to take your long pump back and swap it for a short one. Then its a matter of sorting through pulleys to line them up.
Old 03-29-2014, 08:44 PM   #10
Posted
Posted's Avatar
Weird, if you call anywhere on what water pump goes on this truck, all listed as long. I am mounting to steering pump tomorrow, that will show me too. Thanks for the help!
Old 03-29-2014, 08:48 PM   #11
litew8
litew8's Avatar
What info are you giving them to look up? It isn't the truck they should be looking up, but rather the engine/year you have.
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 03-29-2014, 10:37 PM   #12
Legolas894
Chemist under the hood...
Legolas894's Avatar
This brings back memories. I went to every swap meet trying to get a set for my '67 283 set up. Then someone on here told me there was an exhaust manifold that had a boss on it for another mounting bracket!. Here's some pics of that in case you get some pulleys.
I agree with TX firefighter-You have to use all the same pulleys and brackets or the belts will just not line up. Here's some pics but might not be what you are looking for.
Current fleet:
2013 GMC Sierra, 5.3L, 4x4
1988 GMC Sierra, 305, Auto
1984 Jeep Grand Wagoneer, 360 V8
1997 VW Cabrio, 2.0L
2017 Toyota Rav4, 2.5L
Stuff I wish I still had:
2013 Toyota Matrix [RIP]
1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD]
1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD}
1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD]
1995 Chevrolet Astro AWD, 4.3L V6 (RIP)
1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD]
Legolas894 is offline   Reply With Quote
