Old 03-30-2014, 06:12 PM   #1
SourTooth307
SourTooth307's Avatar
84 K10, Battery? Starter? Ignition Switch?
I changed the fuel pump today, after going to start the truck I ran into a couple problems. I couldn't get it to start, I cranked it many times, pumped the gas a bit then all of a sudden nothing.
I'm not sure what happened but it was cranking fine then all of a sudden I got zero response from the ignition. I still had lights and the voltage gauge was reading something close to 11 or 12 volts but no starter reaction. I left it alone for a while thinking I may have overworked the starter but when I came back I noticed turning the key would kill the power in the truck for a few minutes, I noticed this when the dome light cut out and kicked back on after a few minutes. So, did I kill the battery, starter, or is there a short in the ignition switch, and how do I figure out what's wrong?
My truck is stuck in my apartment complex's lot and I can't have a disabled vehicle parked here for too long so I would appreciate any help to get me mobile as soon as possible. Thanks.
My Wheels:
1984 Chevrolet K/10 Scottsdale 350cid *SOLD*
1989 Cadillac Fleetwood Brougham d'Elegance 307cid
2015 Chevrolet Silverado 1500 LT Texas Edition 5.3L 4x4
SourTooth307 is offline   Reply With Quote
Old 03-30-2014, 06:26 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: 84 K10, Battery? Starter? Ignition Switch?
check the fusible link
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 03-30-2014, 07:25 PM   #3
buddy_1
buddy_1's Avatar
Sounds like a bad battery connection. Check for corrosion and being tight.
I know the "VOICES" aren't real but they have some great ideas.
1978 GMC Sierra Classic C25
1983 Datsun 280ZX Turbo
1997 Chevy Cheyenne K2500
1999 Polaris Sport 400
buddy_1 is offline   Reply With Quote
Old 03-30-2014, 09:46 PM   #4
SourTooth307
I did mess with the positive cable in order to get the fuel pump in. I'll check to see if I knocked it loose. Thanks.
Always a good place to start. Which fuse is for the ignition? I don't have an owners manual.
My Wheels:
Old 04-01-2014, 09:57 PM   #5
WyattEarp18
WyattEarp18's Avatar
I had the same problem about a month ago. Check your battery cables and also the cables running to and from your starter. Somehow my starter cables developed a bad connection. Good luck
'79 K20 Camper Deluxe
'99 F-250 PowerStroke
'98 Z71 4x4
Some people are like slinkies, good for nothing but make you laugh when tossed down a flight of stairs.
WyattEarp18 is offline   Reply With Quote
Old 04-02-2014, 07:47 PM   #6
SourTooth307
I tried to look but had trouble seeing the cables. Do I need to drop the starter to make sure?
My Wheels:
Old 04-02-2014, 07:59 PM   #7
WyattEarp18
The cables will run right from from the side of the starter. You'll probably have to crawl under neath to get to them. Also check your fuses. The cover should have a diagram showing what fuses go where.
'98 Z71 4x4
Old 04-02-2014, 08:59 PM   #8
SourTooth307
The only fuse box I know of is under the driver's footwell and I didn't see any fuses pertaining to the starter or ignition switch. Is there one under the hood too?
My Wheels:
Old 04-02-2014, 09:28 PM   #9
WyattEarp18
I know in my 79 there is
'98 Z71 4x4
