Old 03-27-2014, 02:23 PM   #101
sambudo
sambudo's Avatar
Re: Converting to Power Steering 68 c10 6cyl
Well it looks like I will be rebuilding my steering column. Call it coincidence!
Since I was never able to turn my steering wheel freely, I guess I’ve probably had issues before and didn't know it!
It seems that something is binding up in there. I found that my blinking assembly looks and feels like it should be replaced. Most likely the upper bearing and lower one as well. I’ll know more once I get it all taken apart. Hopefully the horn parts also, since it hasn't work since I purchased it. I’ll post some pic’s later once I get it torn apart.
1968 C10, 250, L6 4spd OTF, Fleetside
Upgrades: Power Steering
.......................____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
sambudo is offline   Reply With Quote
Old 04-16-2014, 03:02 PM   #102
sambudo
sambudo's Avatar
I'm still waiting on some parts for my steering column, I hope to receive this week so I can start reassembly. Can you tell me if on the ps hose ends do i need to put teflon tape around the fittings before assembly? Or do I just screw them in?
Old 04-16-2014, 03:16 PM   #103
NC67Chev
NC67Chev's Avatar
No Teflon tape. Those are flared fittings. Just tighten them up.
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside
Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar
NC67Chev is offline   Reply With Quote
Old 04-17-2014, 12:37 PM   #104
sambudo
sambudo's Avatar
Can you tell me how do you put in the pitman arm to the tie rod end? Do you need a special tool for this? thank you
Old 04-17-2014, 03:37 PM   #105
NC67Chev
NC67Chev's Avatar
No special tool. Just tighten to 60 ft/lbs.
Old 04-18-2014, 02:40 PM   #106
sambudo
sambudo's Avatar
Well I hope to have time and finish up on this project. Last night I pulled the steering column and plan on cleaning replacing bearings and painting ait and reassemble. Hoping to get the rag joint on the pa gear add the hoses and tighten everything back up. If I get the free time needed I think I can finish and start a new project. Thanks for yous help. Scott
Old 04-18-2014, 07:01 PM   #107
NC67Chev
NC67Chev's Avatar
You will have a big smile on your face when you drive your truck the first time once power steering is installed.
Old 05-02-2014, 11:48 AM   #108
sambudo
sambudo's Avatar
I am hoping to be able to test ps tonight. I still have a couple of things to do like.
1.ebrake the bolt holes aren't lining up. I need to get this done.
2.put steering wheel back on.
3.fill ps fluid in pump. ( how much is needed to fill this?) turn lock to lock to work the air bubbles out of the system.
4.Radiator fill
5.tighten pitman arm /tie rod nut to 60ft lbs. Then test drive!!
I guess if I spent longer than 1 hr in the garage I could be already enjoying the ps.
Old 05-02-2014, 12:29 PM   #109
NC67Chev
NC67Chev's Avatar
I honestly can't remember how much fluid it took. I bet a quart would be enough though.
Old 05-02-2014, 10:03 PM   #110
veedubshafer
I'm doing a PS swap on my. '67 250 right now. Almost done tonight. Tomorrow morning I have to put the power steering hoses on and fill up the system and tighten up the 2 rag joint bolts and I'm done. Can't wait!
veedubshafer is offline   Reply With Quote
Old 05-03-2014, 07:35 AM   #111
NC67Chev
NC67Chev's Avatar
I know the feeling about not having much time.
Old 05-03-2014, 07:38 AM   #112
NC67Chev
NC67Chev's Avatar
That's awesome! I've really enjoyed having power steering on my truck.
Old 05-03-2014, 08:51 AM   #113
veedubshafer
All done! So much nicer to drive :-)
Old 05-06-2014, 02:40 PM   #114
sambudo
sambudo's Avatar
Nice job. I completed mine finally, it drives or should I say steers nice. Now I think I have to decide what to do about the steering column. I pushed mine in about 3 " and the wheel is done touching my legs. So need to decide do I want a different steering wheel, or do I want to put in a tilt column.
But overall the ps conversion came out good. I am very happy with the results.
Old 05-06-2014, 02:42 PM   #115
sambudo
sambudo's Avatar
Whats a 30 TH? is that your transmission? I am thinking of swapping mine for something different.
Old 05-06-2014, 06:18 PM   #116
veedubshafer
3OTF....3 on the floor. I'd like to put an automatic in it someday.
Old 05-06-2014, 06:56 PM   #117
sambudo
sambudo's Avatar
I have the 4OTF then ! Thanks
Old 05-06-2014, 08:16 PM   #118
NC67Chev
NC67Chev's Avatar
Congrats on finishing the install!
Old 05-07-2014, 12:38 AM   #119
sambudo
sambudo's Avatar
Thank you it feels good to be finished. Now onto the next project, the brakes.
