1985 k10 cooling question
My 1985 k10 has a fully rebuilt 1975 chevy 350 bored to a 355 with about 8,000 miles on it. Recently the engine temp when running has been around 200 degrees. However before it was around 185. I replaced the thermostat to a 180 and now it runs at 180 degrees all the time is this fine??? Should the engine be running a little warmer?? Let me know
Re: 1985 k10 cooling question
We'll if you swapped your t-stat for a 180 degree one it's not going to get any hotter since that's when it's opening up and cooling down. U should be fine.
The 350 in my k2500 runs at 180, if you're working something hard you want it to stay cool.
1991 R3500 3+3 C+C 6.2/4l80e/14ff Fleetside Dually 1992 K2500 ECLB 5.7/4l80e/14sf(g80) 8600gvwr 1991 CR500 (95 Burb wouldn't stop catching fire ![]() |
Tags |
cooling, k10, thermostat |
