Old 04-20-2014, 10:13 PM   #51
Curtm220
Curtm220's Avatar
Re: Overheating issue
Wholly thermostat Batman! I wonder why the L6s that never had the drilled thermostat never had this issue all those years
That's a good question. I had an inline 6 and never had an issue until I had to replace the radiator. After that the temp gauge would nearly peg before resting at its normal temp. After a new thermostat and still seeing e problem, Air under the thermostats was the only thing that made sense. Drilled the base and never saw it again.
71 Cheyenne 4X4 SWB
383/350
Curtm220 is offline   Reply With Quote
Old 04-20-2014, 10:21 PM   #52
litew8
litew8's Avatar
What radiator did you replace with?
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 04-20-2014, 10:53 PM   #53
Curtm220
Curtm220's Avatar
I replaced it with a stock one out of another truck that I bought from a buddy who had done a swap to a small block.
71 Cheyenne 4X4 SWB
383/350
Old 04-21-2014, 02:38 AM   #54
litew8
litew8's Avatar
@sjburk Don't know why, but when looking at radiator caps for your engine I find both 13 and 16 psi. You mentioned having a 13, guessing that is what was originally on the 2 core. Looking at your picture it doesn't look like you have an overflow tank. If true, try sourcing one to catch that fluid and see if makes any difference (keeping hose submerged the tank's fluid when it fills).
Having too low psi rad cap can have an effect on how the system coordinates and increases the boiling point, so if it [cap] isn't faulty and is the correct psi, that should be ok and not interfering.
Old 04-21-2014, 06:51 AM   #55
Togan66
Togan66's Avatar
When I drilled mine, I really thought I had an air pocket issue, so I was hoping to remedy that issue. It did the trick.
Togan66 is offline   Reply With Quote
Old 04-21-2014, 07:23 AM   #56
I guess what I'm saying is this drilled thermostat is a great remedy,but only gets around whatever the real issue is. Nothing wrong with that. I'm a whatever it takes kind of guy,but still would want to find out the actual cause at some pint.
Also,these trucks were never designed to run a closed coolant system utilizing an overflow tank,so just another band aid.
These are well designed trucks which have functioned reliably from factory. There were no design issues with cooling,so as built is still all you should ever need.
Old 04-21-2014, 10:44 AM   #57
litew8
litew8's Avatar
Yeah, and the 6 cylinder was never designed to use a thick three core radiator either without a shroud. They made 6-cylinder radiators specific.
Old 04-22-2014, 03:36 PM   #58
68 IRON
68 IRON's Avatar
If you bought the laser thermometer, give us your readings (about 6 or so) from t-stat to engine again. It should read roughly what your t-stat is set at to gradually cooling across radiator.
68 IRON is offline   Reply With Quote
Old 04-22-2014, 11:22 PM   #59
Z10
Z10's Avatar
Originally Posted by 67 chevelle View Post
Picture is worth a thousand words , YOU NEED A SHROUD , will solve your problem
You need a shroud. You're only pulling air through the radiator in front of the fan. A shroud will pull air through all of the radiator.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 05-30-2014, 07:22 PM   #60
sjburk
Sorry, I had my truck in the shop welding in some new panels for quite some time. I got it back yesterday and bought an IR thermometer. I let the truck idle in the driveway, the needle went all the way to the hot side, I revved it up and it went back down and leveled at about 3/4 of the way at a steady idle. When the tsat got to around 185 the hose going to the radiator did get hotter. My temps when everything leveled out were, sending unit in head 250, head 250, block 225, tstat housing 230, tstat rad hose 175, water pump rad hose 150, incoming side of radiator 180, rest of radiator 100. That actually sounds reasonable to me, but please tell me your thoughts. Now I'm thinking the gauge or sending unit is off on readings. Thanks for your patience.
1967 GMC C1500 1/2 ton I6 250ci
sjburk is offline   Reply With Quote
Old 05-31-2014, 02:15 AM   #61
litew8
litew8's Avatar
Old 06-01-2014, 01:35 PM   #62
68 IRON
68 IRON's Avatar
The lower and upper tstat housings should be about the same (180F) and through hose, radiator inlet slightly lower if not the same. You should have a 30 to 50F drop across the radiator depending on outside temp. Your tstat temp concerns me (should be closer to the tstat opening temp)...it shouldn't be 230F
Old 06-01-2014, 04:22 PM   #63
sjburk
Well last night my friend had a get together so I decided to take old yellow, and I drove 60mph for 10 minutes there and 60 for 10 minutes back. On the way there the gauge never got up to halfway, on the way home it went all the way up for a moment but then went back down and again never got past half, I don't know what's up with that although neither times did I get out the IR thermometer.
