Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 11-22-2013, 06:18 PM   #126
1tonwannabe
Re: 1972 GMC Using 2003 Chevy 2500HD duramax Chassis
Then I removed the new pedal, and used a torch to heat it up, and bend it until it was in the right location of the old pedal.
1tonwannabe is offline   Reply With Quote
Old 11-28-2013, 10:46 AM   #127
bufmatmuslepants
Junior Member
You should tack a couple guessets in the bends of the brake petal, after heating, bending and cooling youve compromised the strength a little, and since brakes are kinda important, it would probably be worth the 10 minutes to tack in a little extra support. Are you gonna have to do the same with the gas petal?
1979 K10 reg cab short bed 33x12.50s - GONE
1988 4x4 reg cab long bed 337k miles - GONE
1995 Z71 GU6 G80 F44 ext cab short bed 149k 305/70/16s - GONE
1995 NZZ GT4 2dr Tahoe 3" lift 14 bolt sf 155k 305/70/16s - GONE
1994 Z28 M6
1995 Z71 GT4 G80 ext cab short bed 215k GONE
1997 GT4 G80 Yukon 4 door leather, sunroof 168k miles GONE
2003 Avalanche Z71 GT4 G80 165k miles
bufmatmuslepants is offline   Reply With Quote
Old 03-20-2014, 08:26 PM   #128
70chevy10
70chevy10's Avatar
Hey any updates on the build?
1970 c10 LWB (BIG BUILD UNDERWAY) SEMA 19?
1969 GMC K2500 V6 Step Side Long Bed
2008 F250 650hp CUMMINS SWAPPED Daily Driver + too much to list
LAST DROP GARAGE, LLC.
Check the Shop out!
http://www.lastdropgarage.com
70chevy10 is offline   Reply With Quote
Old 03-24-2014, 10:25 PM   #129
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
subscribed!
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 04-15-2014, 05:30 AM   #130
1tonwannabe
Working on the front wheel wells now. I'll post some pics later today hopefully.
Old 04-15-2014, 09:26 AM   #131
Lazzardkng
Good luck on the inner fenders. Those were the biggest pain of my build so far. Trying to make room for 2 batteries, fuse block, surge tank and air box. What I would have given for an English wheel
1970 Chevrolet + 2003 GMC Duramax 4x4 = Awesome
Lazzardkng is offline   Reply With Quote
Old 04-23-2014, 06:37 PM   #132
1tonwannabe
The frame on the 2003 is a lot wider than the 1972 frame. I had to cut out the inner part of the inner fender, and make a piece to fit the 2003 frame.
Old 04-23-2014, 06:40 PM   #133
1tonwannabe
I needed a spot to put all the computers on the inner fender. I cut off the top and welded in a flat spot to mount them to. This idea is still in the works.
Old 04-23-2014, 06:42 PM   #134
1tonwannabe
I have about a 1/4" clearance for the turbo piping. I think I might need a little more, not sure.
Old 04-23-2014, 06:44 PM   #135
1tonwannabe
Here's what it looks like on the passenger side so far. I got the inner fender to follow the frame pretty good. Still needs some smoothing out, but it works. Sorry for the blurry pic.
Old 04-23-2014, 06:48 PM   #136
1tonwannabe
I never would have thought making inner fenders would take this long, and they still need work. After I get that and the computers mounted, I think I am ready to give the cab to the painter to shoot the firewall, and interior. That was our plan. I would weld everything up, and mount everything. Then I would take it apart and give the painter the cab. After he shoots the firewall, and interior, I would get it running, and he would finish painting it.
Old 04-24-2014, 03:24 PM   #137
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Sounds like a good plan. Those inner fenders look nice. I had a lot of time in putting mine in and pulling them out trimming for all the piping. Later I plan to redo them do there is more area covering the engine. Keep up the great work!
Ryan
1969 Chevy milk truck
Old 05-30-2014, 04:24 PM   #138
Lazzardkng
Any new progress. I just updated my thread
http://67-72chevytrucks.com/vboard/s...=1#post6699722
Moving into primer then tear down to paint jams and firewall before final assembly
Old 06-05-2014, 11:24 AM   #139
NastyBuzzard
NastyBuzzard's Avatar
Wow!!! Watching this. I have a 87 gmc v1500 single cab longbed 4x4 I am doing an ls swap in and i bought a donor 01 ext cab short bed 4x4 silverado.. I am wanting to do frame swap but am a little intimidated by it..
Love to hear how using all the wiring works, I definitely plan to do that!
NastyBuzzard is offline   Reply With Quote
Old 08-21-2014, 12:00 AM   #140
jkade
jkade's Avatar
Did I miss who is doing your harness? You keeping the abs?
jkade is offline   Reply With Quote
Old 10-29-2014, 07:30 PM   #141
Stryker67
Stryker67's Avatar
Originally Posted by 1tonwannabe View Post
The 2003 chassis is 16.5 inches too long. The way this frame is built, they slid the front part of the frame into the rear. So all they had to do was make one front frame that fits everything, and GM could slide in a longbed frame, or a shortbed, or a crewcab etc. in the rear. All I did was remove the factory weld where the front and rear frames join and sepperated it.
I will starting a similar project, but with a 2500HD extended cab long bed. I plan to make mine a 68 GMC and an 8 stake bed. Did you just cut off 16.5 inches from the front and slide it back together? Or was yours not a long bed chassis?
[FONT=Georgia]
If nothing else, we can all serve as a bad example.
We don't know what we don't know.
The world needs ditch-diggers too.
Stryker67 is offline   Reply With Quote
Old 11-08-2014, 06:49 AM   #142
1tonwannabe
I removed it from the rear part of the frame.
Old 03-13-2015, 03:56 PM   #143
Stryker67
Stryker67's Avatar
Ok. I assume this truck has torsion bars? Did you just relocate the crossmember?
[FONT=Georgia]
Old 05-06-2015, 02:19 PM   #144
Farm Shop
Farm Shop's Avatar
Awesome project!
1970 SWB 2wd C10, Vortec 454/80e, CPP 3/5, slotted mags, patina
1972 K20 Super Cheyenne, Short bed, EFI 396, NV4500, NP208
1970 GTO Judge, heads/cam LS1 & stalled 4L60e
Farm Shop is offline   Reply With Quote
Old 05-06-2015, 07:20 PM   #145
Bladeboy1998
Sweet! I hope your wife is doing good as well, keep up the good work.
Bladeboy1998 is offline   Reply With Quote
Old 08-11-2015, 06:30 PM   #146
1tonwannabe
I just drilled new holes for the cross member. My wife is doing great. Thanks for asking. Just hit the 2 year mark that she has been in remission. I am working on the interior now. Trying to decide if I want to use the 1972 light switch, or all the 2003 switches.
Old 08-12-2015, 04:48 AM   #147
DWilbur
Use the 2003 switches so I can copy your hard work. I'm thinking of using the 2004 stuff I have. I started cutting up my 71 instrument cluster to fit 2004 in to it. having issues with the steering column.
DWilbur is offline   Reply With Quote
Old 08-15-2015, 12:56 AM   #148
1tonwannabe
Look at Lazzardkng's build. He did a good job using the newer switches.
Old 08-15-2015, 01:38 AM   #149
DWilbur
I tried to search for Lazzardkng and did not find anything.
Old 01-05-2016, 07:41 PM   #150
lsjrl07
lsjrl07's Avatar
I have the opportunity to pick up an LBZ truck to swap into my C20. These might be similar builds... except mine is going to be bagged.
lsjrl07 is offline   Reply With Quote
