Old 05-01-2014, 11:09 PM   #1
kelsfine69
18 Till I Die
kelsfine69's Avatar
Gas tank strap repair question?
On a 87 the gas tank straps are broken. I need a new tank anyway so I picked up new straps with the new tank. The old ones are riveted on and from searching it seems that everyone just drills them out and uses 1/4" bolts and lock nuts to reassemble. Now the brackets have the mounting for the plastic tank shield which I don't plan on putting back on. Do you drill right thru the rivits and the bracket. The rivits are only on the first bracket and dont go thru the second layer which is factory welded overtop..
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 05-02-2014, 06:39 AM   #2
Pano
Re: Gas tank strap repair question?
I cant remember but must have drilled or Ground off the rivets and drilled through. What I do remember is the straps were slightly different lengths. Be sure to put them in the correct spots.
My truck has dual tanks.
Pano is offline   Reply With Quote
Old 05-02-2014, 09:12 AM   #3
rich weyand
rich weyand's Avatar
Can't help on the rivet; the garage did that. But I used sidewalk bolts to put the straps back on. Very low and wide heads, with one layer of anti-squeak with holes in it for the bolt heads, then another layer over the top. This so that the heads wouldn't rub on the tank. The rivets are very low profile, but most bolt heads are taller, and I though that was asking for trouble. And stainless, of course, so they wouldn't rust.
http://www.mcmaster.com/#90015a414/=rsg0c8
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 05-02-2014, 12:05 PM   #4
willett
Another Day, Another Dollar
willett's Avatar
I was in the bush when I did mine and I ended up making rivets out of 3" nails. Cut em down to 1/4" or so and then pounded them in place on a vice
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 09-24-2014, 05:07 AM   #5
Tuff 1986
Tuff 1986's Avatar
I'm in this exact predicament.. Did you end up drilling through the rivet and bracket or just the rivet? And what bolts did you use...
Will I ever finish my 1986 stepper..
Tuff 1986 is offline   Reply With Quote
Old 09-28-2014, 12:35 AM   #6
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
When I replaced mine, I just drilled the rivet off and used a carrage bolt and then insulated the strap with a rubber strip .
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
