72 Step - Rust elimination = driver
The day I brought 'er home:
![]() Did some digging and found that the PO had a crappy paint job done over crappy body work. Not sure what some people think... So I scheduled it to have the inner/outer rockers, cab supports, and cab corners fixed. So off comes the bed: ![]() Don't want a garage queen with this just want to have a fun toy that's solid! This is my first "project" that isn't a motorcycle so I have alooooot of learning to do. Great forum great people! Thanks in advance for any help I may recieve! My $100 Ford Super Duty rear seat: ![]() Even though it's coming apart already I'm definitely in love! Sorry for the crappy pics.
72 C10 - Multicolor, 4.8 ls, NV3500. Sold 72 K5 - Under Construction |
Re: 72 Step - Rust elimination = driver
Bed off, wire wheeling done, first coat of rusty metal primer on!
A lot has happened since last updated... I'm not good with taking pictures and keeping things updated.
Hood stripes: ![]() Hauled my ls 4.8 home: ![]() Put it in: ![]() 4" drop in rear and put a fleetside on: ![]() And that's where we're at! Really lovin this thing and you guys are amazing with the wealth of knowledge! Thanks for everyone's help! ![]()
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Nice work. Great choice on the LS swap.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
Looks good. Try to update more though! Those are big project leaps!
Rob 1971 c10 - ground up in progress Tripp's Speed Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=589750 |
Thanks guys I'll try to stay updated a little more!
Time for ball joints, tie rod ends, and more low
![]() ![]() Little paint ![]() Now waiting on parts and the dreaming continues...
Lurky lurky
Looking good, love the polished slots!
Thank you! Should I keep them? I can't seem to find lug nuts. I tried pep boys (supposedly good selection) and even online but none seem to be the same as what's on it now. The nuts on there are half stripped and all rusty. I was considering going to rallies for this reason but I kind of like the slots!
#11 | |
https://www.google.com/search?q=ET+l...w=1600&bih=796 If they are the flat washer type they are available too.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
try summit for the lug nuts
that's where I bought mine and they are holding up well to the weather btw nice progress on the truck
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
#13 | |
Lurky lurky
Rally wheels are also in my top choices though, if I had my way I'd keep a set of both and swap out when I started getting a bit bored. |
Thanks for the input! They are the washer type nuts. I'll have to check summit but yea I may have to do the "2 sets and swap em out"
#15 |
![]() Join Date: Mar 2014
Have you checked mileage with the 4.8? How did you do the fuel system? Tank relocation? Truck is looking good. Are you ditching the step bed all together?
#16 | |
Fuel system I did with fuel injection rated hose and fuel injection clamps, external pump, stock tank. Step bed is gone for good ![]()
#17 |
wish my ls went in that quick/easy....
#18 |
Haha it was not easy by any stretch of the imagination! But I'm very glad I did it!
#19 |
Have any pics of how you did your fuel system? I want to use the stock tank with my 5.3 as well!
#20 |
No pics on that. Feed - pump - filter - fuel rail - return (I have the return style rail). Used walbro pump, fuel injection hose and clamps. If money allows it go for the an fittings and hard line or braided stainless IMO.
#21 |
I was having problems staying motivated, so I tore it apart
![]() ![]() ![]() Should've done that in the beginning would've made the swap easier!
#22 |
Ya got a shop so go for it.
#23 |
Trim holes welded shut, flap disked, ready for filler! I think this is how you do it...
![]() ![]() Plan on using white epoxy primer and just drive it like that for a while. Any input on that approach?
#24 |
Looking great. Moving along quickly, good call on the fleet swap
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly ![]() |
#25 |
Cool build. I seem to remember looking at your build awhile back. I've looked at sooooooo many builds. Killer looking truck and I like the Ls. I'm curious about the mileage and power.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
