05-17-2014, 08:58 PM | #26 |
Re: c20 towing capacity
Your truck will handle that set up just fine,Its not much different than what I tow and have since 1989.
Mark 67 c20 custom camper 55 Olds 2dr hardtop 96 mustang 11 dodge nitro |
05-18-2014, 01:04 AM | #27 |
Agreed. Truck is more than capable, design and weight capability of current hitch is questionable. A new bumper / receiver is a (relatively) cheap way to get right.
Josh '70 Custom Camper / 20 |
05-18-2014, 02:32 AM | #28 | |
I'm not a towing expert but that setup looks more the reasonable for that pickup. Nice truck by the way!! |
05-18-2014, 09:10 AM | #29 | |
thanks, paul |
05-18-2014, 09:42 AM | #30 |
I'd say you'll be fine, but I'll post up a pic of my set-up which is similar to yours with just a bit more bracing when I get home from work.
05-18-2014, 11:02 AM | #31 | |
You don't necessarily need a new bumper if you cut all the hitch components off your existing bumper before mounting a receiver. Your bumper appears to be in excellent shape. Curt Manufacturing makes nice receivers that appear to be powder coated. For your application, they have 2 versions. One is for use "with 10" step bumper" the other is "except 10" step bumper". The step bumper version is #13099. The other is #13028. I'd probably opt for the step version even if your bumper is less than 10". It is more substantial and may drop lower to clear the bumper. Their website is http://www.curtmfg.com/ Google "Curt 13099" and "Curt 13028" and you'll find all sorts of online sellers at lower prices. Good luck, relax and have fun! |
05-18-2014, 12:35 PM | #32 |
Paul, you are clearly approaching this in a fairly conservative way and you might be overthinking things a bit.
Your truck is more capable of hauling than you think...and probably quite a bit more than the data plates says for at least 2 reasons: -Its true that every manufacture adds a factor of safety to every system in their truck capacity rating to compensate for what is often called 'the fool factor' in engineering terms. This allows for the guys who are always overloading everything they own whilst running it into the ground....you have to cover off for these fools when establishing ratings capacities. so if its says: 3000lbs max as an example...the capacity before probable failure will often be at least 50% more than that. This is off the record info...but I work in engineering so I know this. -Next...one thing about the 'period ratings' for our trucks is that much of the rating is/was based on the tires provided and available for the trucks. The tires from this era were very poor by todays standards. Today the capacity ratings on tires are substantially higher and the generally all around quality and capability make hauling and driving so much better as you probably know. An example is the 15" 1/2 ton truck tires from 1970...which had a capacity of about 1500lbs...and that was a truck tire. Today a 15" truck tire has a capacity well over 2000 lbs....sometimes reaching above 2500 lbs. This is one of the reasons that GM would not list high GVW ratings on the 1/2 ton trucks over 5400 lbs....the tires would push the limit of the upper rating...ie: 4x1500lbs = 6000lbs....too close so 'down list/grade' the rating. If they had todays tires well.....4x2300 lbs = 9200 lbs....WOW, big jump in the theoretical numbers which would have made the engineering group more comfortable. With the tire technology upgrade alone...there is a 'hidden' capacity advantage on all the trucks 1/2 ton (15") or the 3/4 ton (16"). This is my opinion and I do not have any data or testing information to justify this.....full disclosure. If you are concerned about how the current hitch is mounted to the frame then...yes, go order high capacity Grade 8 bolts from a local fastener supplier and change them all out. Great looking rig and good luck!! Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 Last edited by Coley; 05-18-2014 at 12:43 PM. |
05-18-2014, 01:07 PM | #33 |
how do i know what grade bolts I have now? maybe they are already grade 8? i did not install them.
thanks |
05-18-2014, 01:18 PM | #34 |
ok, sorry to ask a question that i can answer myself using a google search. grade 8 bolts have 6 radial lines. I checked my hitch and it has grade 8 bolts. each one has the 6 radial lines.
paul |
05-18-2014, 02:01 PM | #35 | |
http://www.reeseprod.com/content/pro...042&part=37087 And a step bumper that you could probably pull out of most wrecking yards for a few bucks. Probably less than $300 start to finish.
05-18-2014, 02:13 PM | #36 | |
It's not a huge, hairy issue to deal with. Total install time would probably be a Saturday afternoon, if you take a pop break every now and then.
05-18-2014, 03:09 PM | #37 | |
paul |
05-18-2014, 03:40 PM | #38 | |
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
05-18-2014, 04:02 PM | #39 | |
I don't agree that there is a ton of extra capacity engineered in. It's there for things like road conditions, etc. These trucks will drag way over their limits on smooth, flat, dry pavement, but potholes, rain, cars that believe they need 2" clearance before they come across your hood and age degrade the capabilities. I'd upgrade to front discs. I'm also upgrading to hydra-boost in the near future. Good luck! Jeff
05-18-2014, 04:18 PM | #40 | |
05-18-2014, 04:24 PM | #41 |
This is what mine came with and looks like it has many heavy miles on it.
05-18-2014, 05:17 PM | #42 |
05-18-2014, 06:29 PM | #43 | |
Your step bumper was originally attached to the frame with the two "S" shaped side bars and the four closely spaced bolts. That works pretty good and most I have even found a rating for were about 2500/250Lb. On yours they added a lot but most of it is to keep the bumper itself from folding up and really does not address the frame loads. While you pointed out it has foru additional bolts, they go into the lower flange and are not even supported fully where they contact the frame. As it sits your hitch is very much like a spring board if that helps you picture the loads. As far as making it better, there may be ways and as I suggested earlier a good shop might be your best start. You stated in you other thread a coulpe of shops agreed it would be ok for a 5,000lb trailer. But I must ask did you tell them it was an equalizer rig or did they offer to "certify" it for you as a paid service? My views became very strong on the subject of hitches and mirrors due to hauling a lot of horses in and around California. Live loads are a true test of a vehicle system as a whole. You should experience having a pair of quarter horses who are swaying in unison inside a trailer just for the fun of it. In fact on my prime truck we did not even run a rear bumper. Just had a receiver hitch and the frame exposed so they could be inspected easily, along with the spare. Since you admitted to being new to this, a review of "Trailer Life" trailering guides might give you a lot of background, verbage and some reassurance. http://www.trailerlife.com/trailer-towing-guides/
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
05-18-2014, 06:40 PM | #44 |
Personally, I'd would feel a lot more comfortable with a class V hitch. Other than that, I wouldn't hesitate pulling that trailer with that truck assuming it's in good mechanical condition ( which it sounds like it is).
1995 GMC 4x4 1/2 ton 1999 Jeep Wrangler w/ 33's 68 camaro 350/350 1987 Chevy 3/4 ton 4x4 Suzuki DRZ 400s Dual Sport 1971 chevy long bed 2x4 194? Dodge 2.5 ton 1980 Chevy Cheyenne 4x4 1/2 ton I6/sm455 1989 Chevy V30 crewcab dually 454/TH400 |
05-18-2014, 08:26 PM | #45 | |
ill post what I find out. |
05-19-2014, 01:52 PM | #46 |
I went this morning to orange trailer and hitch. The owner looked at my hitch and said 5000lbs is no problem. He said it would be advisable to use a weight distribution system which I am using.
This was the second opinion from a trailer and hitch installer. I think im done worrying about this. Thanks to all for their input. paul |
05-19-2014, 02:37 PM | #47 |
Weight dist hitch will work great. I use one on my 4runner pulling a trailer your size.
05-19-2014, 02:50 PM | #48 | |
I know this is not a ford forum but any opinions on towing a 16 foot toy hauler with my ranger? Paul |
05-19-2014, 02:55 PM | #49 |
I know I have towed a 16 foot flatbed trailer with a Ford 8N tractor and a 5ft mow deck behind my Nissan.
Its a '93 2wd D21, with a 2.4L 4cyl, and 3.53 gears. It wasn't fast, but it pulled it without an issue. The Nissan has a GVWR of 4400lbs.
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast! Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun. 1st BN 3rd MAR. '00-'04 |
05-19-2014, 10:51 PM | #50 |
Just keep an eye on it, my opinion is it may bend but not fail in a catastrophic way, if you notice it is starting to bend or distort then think about a frame mounted receiver.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
