Old 06-06-2014, 09:40 AM   #101
A1971Blazer
A1971Blazer's Avatar
Re: What did you do to your Blazer/Jimmy today?
Originally Posted by freakshow108 View Post
One more
Name:  bed floor.jpg
where did you get that bed floor?
A1971Blazer is offline   Reply With Quote
Old 06-06-2014, 03:50 PM   #102
freakshow108
freakshow108's Avatar
Originally Posted by A1971Blazer View Post
Attachment 1262944
It is the original, I just frankinsteined the patches in😜
freakshow108 is offline   Reply With Quote
Old 06-06-2014, 06:47 PM   #103
asolde
asolde's Avatar
I put the seat belts in, seats and console. Still need to install the shifter boot, door weather strips, door sills and the radio speaker.
1972 cheverolet K5 CST Blazer
350/auto/AC/PS/PB/Aux Batt
From Medford, Oregon
asolde is offline   Reply With Quote
Old 06-07-2014, 08:31 AM   #104
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Really really sweet!
Tom Vogel is offline   Reply With Quote
Old 06-07-2014, 10:37 AM   #105
jaros44sr
jaros44sr's Avatar
Asolde, nice work! That looks like something you would climb into at the dealership......
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 06-07-2014, 12:45 PM   #106
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Nice work! Any tips for trimming holes in the carpet? I've always just hacked away as meticulously as possible but there must be a better technique. I recently had to re-glue (3M weatherstrip adhesive) a portion of a door weatherstrip and used several large metal paper clip/clamps to hold the glued section in place - worked well.
Old 06-07-2014, 03:25 PM   #107
asolde
asolde's Avatar
No good tips on cutting holes in the carpet just a good razor blade and a sharp knife, cut an X where you want the hole. Alot of holes I went under the truck and poke a all up through the carpet. I had to feel for a lot of the holes and poke a hole with a all. I need to get motivated and get back out there to do my weatherstrips,and shifter boot.
Old 06-07-2014, 05:23 PM   #108
67Steven
67Steven's Avatar
When I did my carpet in the suburban, I used an old soldering iron. I sharpened the point a little, got it up to temp and poked it up through the floor where I could and down from the top for the remainder. It melted or I say 'cauterized' the holes for a nice, sealed edge. Very permanent, so make sure the carpet is in the right spot.
I have done a few this way and it works pretty well. Just don't lay a hot soldering iron on your new carpet.
1972 Blazer build: http://67-72chevytrucks.com/vboard/s...d.php?t=615744
67Steven is offline   Reply With Quote
Old 06-08-2014, 09:41 AM   #109
A1971Blazer
Working to get my body jig completed
Main rails frame assembly actually setting up on edge
This will lay down flat and attach to the cross members
on the body mount holes
Cross members...one at the front floor, one in the middle, and one at the rear
all are adjustable with all thread and nuts
One of the main uprights nearly finished.....got to drill some holes up the side of the vertical tube for adjusting up and down.
Here's the rough design...doesn't show the cross members but they will weld to the main frame rails on some standoffs to allow me to
1. keep the body straight and square
2. turn it upside down for easier access to work on the underside.
Old 06-08-2014, 10:43 AM   #110
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Would like to see more pics of the jig in use once complete
Old 06-08-2014, 07:07 PM   #111
asolde
asolde's Avatar
I did my door weatherstrips today. I lifted the roof off enough to get at the top of the seals. It was rock solid no rust clean along the windshield frame. I cleaned everything up and installed my seals.When I was pulling the roof off the two front LT/RT hold down bolts broke off. I could not get them to easy out so I stepped drill the bolts out and ran a tap back though the nut plates. I put the roof back on and finished off the seals. I did not like the way the drip deflectors fit so I put the stock ones back on until I get it fiqured out. I got a few more things to do on the interior like the rear pnls, shifter boot, radio speaker.
Old 06-08-2014, 08:59 PM   #112
A1971Blazer
Definitely....
Old 06-08-2014, 10:04 PM   #113
67Steven
67Steven's Avatar
I made some light switch/wiper knobs out of a hunk of scrap aluminum:
I tried to match the basic design of my door lock knobs I made earlier:
And then I finished my tilt/turn signal knobs:
Old 06-09-2014, 09:48 PM   #114
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Got my Parkerized parts back today - here are some representative shots: hood hinge, pitman arm, 72 hooks, underside of a door striker plate, upper hood latch. The bolts are the unique 12-pointers used to attach the hood latch at the rad support. They come coated with a fine layer of gun oil.
Old 06-09-2014, 10:41 PM   #115
67Steven
67Steven's Avatar
Those are so nice, I wish I had thought to do that when I had mine apart. Looks like a durable, no nonsense finish.
Old 06-09-2014, 11:54 PM   #116
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks - it's the original finish that GM applied to these parts and really durable (relatively cheap too). For example, you can wrench on the bolts and they stay black with an intact finish
Old 06-10-2014, 12:16 AM   #117
Moreyel
Active Member
Moreyel's Avatar
Looks great. Who does that in Alb.?
Colors available?
72 Blazer, 70 El Camino SS, Anniversary HD FatBoy, 2012 Ram 3500 4WD Dually, 17 Dodge Challenger, 80 Vette, 65 Chevy 3/4 Ton 4 W/D Pickup and some more.
Wife: 06 GMC Duramax 3500 4WD Single Wheel, 2016 BMW X3.
Next: Rust removal on my Blazer.
Thinking of putting a 50 Chevy cab on a 76 Chev 4 WD pickup.
Members Met: Aldtime, DeadheadNM
Moreyel is offline   Reply With Quote
Old 06-10-2014, 12:24 AM   #118
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Colors available?
http://www.kaehr.com/
They have a minimum order ($100) that does a lot of parts. Colors aren't an option per se - there's zinc or manganese that impart either a really dark gray or black. Ask the folks at Kehr. More on Parkerizing here: http://en.wikipedia.org/wiki/Parkerizing
The local shop here in MT did a really good job.
Old 06-10-2014, 01:30 AM   #119
sierragrande71
sierragrande71's Avatar
Ripped out the front axle of my '69 getting closer to converting it to 2wd form
sierragrande71 is offline   Reply With Quote
Old 06-10-2014, 01:34 AM   #120
sierragrande71
Man '67steven those knobs are bad a$$!
Old 06-10-2014, 07:00 AM   #121
DaHos
DaHos's Avatar
Well it runs and stops now !
Time to get rid of the gas can......tonights project. Yuck !!!!!
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 06-10-2014, 08:28 AM   #122
Dirt's72
Those came out much darker than the stuff you showed me from down here. Nice man!
Dirt's72 is offline   Reply With Quote
Old 06-10-2014, 01:19 PM   #123
rwhite692
Well, I didn't really "Do" anything today, except pick these up from my local upholstery shop.
He did a great job with the Utility Buckets, and the rear seat. He also upholstered the armrests for the rear seat and filled in the ashtray locations. I just need to paint the rear seat arms, and the metal seat backs for the front seats, clean up and paint the seat tracks...then bolt them in (after I get done fixing my rusty floor, LOL)...It will be nice to finally have seats, since I bought this truck with no seats in it!
My 72 Blazer Project:
http://www.67-72chevytrucks.com/vboa...d.php?t=621724
rwhite692 is offline   Reply With Quote
Old 06-10-2014, 01:44 PM   #124
sierragrande71
Awesome!
Old 06-10-2014, 05:43 PM   #125
asolde
asolde's Avatar
Seats look great!
