![]() Join Date: Oct 2009
Highlander interior before and after
Been workin on this turd for quite a while. But it's time to move, so I needed to button it up for the trip. Still awaiting seat belt retractor parts, but that's about it. Still need to bolt in the seat also (a little off center in the pic).
The previously mentioned noticeable gap in the driver's (and passenger) side outer cushion area where the back and bottom met turned out to be nothing more than a new seat foam issue. Took it all apart and examined it compared to the original GM foam and it was just not quite right in the lower seat back areas on the outer edges. Ended up going back to my original 72 foam and it took care of the issue. No visible gaps between the back/bottom now. Glad that got resolved. Found it a bit of a challenge to get all the plaid to line up in straight lines, but I'll live with what it ended up as. Because of the pending move, had to put off the door rehab project - so, will fill the speaker holes and paint the doors at some point in the future, just wanted to make them semi-presentable for now. Redid the dash, added a tach and vac , and finally resolved my temp gauge/sender issues. All the gauges work, which is kinda nice for a change. And added in a factory am/fm that sounds pretty darn good through a single factory speaker. Nice and tinny, just like I like it ![]() Now if I could just get my doors to shut after the new seal install... Ha. They're coming along. Hopeful they will loosen up a bit after sitting in the sun still. Anyway, a special thanks to Tim at Truckseats - this was no easy task to get the highlander plaid with the scrollwork, appreciate your perseverance. Also thanks to Tom for the tach/vac tin and Brian Mac for his HUGE help on the temp sender issue I had. Also Wes over at Classic Heartbeat - thanks for several small parts and the dash bezel and lens and the perfect carpet - they are top quality, very pleased. LedZepp - Scott, was a pleasure to meet you, you probably wondered what ever became of the dash pad I bought from you when I picked up the green door... And Pete, thanks so much for reproducing the Main/Aux fuel tanks selector sticker - that made my day. |
![]() Join Date: Feb 2001
Re: Highlander interior before and after
Very nice job.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
![]() Join Date: Jul 2007
I love it!
Chuck 68 ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
Looks clean...love the plaid!
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
![]() Join Date: May 2010
Beautiful!
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Looks great Jocko....did I miss something, where you moving to....
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
THAT'S a great question - don't know for sure yet! But my time workin for uncle sam is comin to a close. Gotta go find a job. Trying to find something near Phoenix/Mesa, but pretty wide open for now.
Looking great! I just can't get enough of these interiors, it really finishes the trucks off nicely.
That's a good look!
Moderator
![]() Join Date: May 2007
Mark- It was very nice meeting you as well. That interior is awesome! The seat just steals the show. Congrats on getting to move where you want and best of luck in finding a new job.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#11 | |
ha, no, just round 1 of retiring. which really just means a career change nowadays.
now that is show quality!
Carpe manana
![]() ![]() Join Date: Dec 2010
Awesome work Mark! Glad you put the decal to use. How did you get the door panels clean - plain old elbow grease?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#15 |
Very nice! Question for you, any special reason you went with parchment VS black belts? I wrestled with that when I redid mine.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#16 |
E.H.F.D Engine #2
That looks very nice. That scroll in the center really makes the difference. I wasn't up for jumping through the hoops to get that done on mine, and kind of wish i had. Quite the improvement!
-NICK '72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation '89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205 '15 Chevy 2500HD CCSB High Country Duramax '22 Tahoe Premier Duramax |
#17 |
![]() Join Date: Sep 2010
Location: Formerly MD and San Diego, now loving life in Arizona
Really like the clean lines and look of that interior. Great job on bringing back to life.
Alan 2012 Ram 3500 Dually Crew Cab 6.7 Cummins 2014 Palomino Columbus 340RK 5th wheel '69 Chevy C10 396BB |
#18 |
72 GMC
It really is amazing what a seat can do !
KEL Members I have met : 2014.02.01: bruceman1968, Mr Handy, colgad, RenoKeene, CaptRMW |
#19 |
![]() Join Date: Dec 2013
Just installed mine this weekend, Loving me some 70's Plaid! Dog matches perfect!
#20 | |
#21 |
Lee, I went with parchment because it had the original parchment belts still on it when I bought it from the original owner. I've occasionally seen parchment with black, but have always thought that parchment belts were the norm with a parchment highlander seat. Hope I didn't screw the pooch, but that is what was on it and they were very "original" (i.e. pretty trashed)
#22 | |
#23 |
I think your belts look great in black Lee - parchment buckets with black houndstooth - a great look. I had to go double check my "highlander files" - here's what I found from original sales brochures for the highlander, but who knows what happened in the factory... Ha! Yours looks great with black, and white would probably look great also, especially since you have both black and white in your houndstooth inserts.
#24 |
After seeing the sales brochures it's clear parchment is the right choice! Black would not look right. Kudos.....
#25 |
Moderator
Truck could have come with either black or parchment seatbelts. Both look good, but black won't get dirty
Tags |
highlander, plaid |
