#51 |
Knuckle Buster, Instructor
![]() Join Date: May 2010
Re: Parting out a 72 blazer
I'll take those rear seatbelts if you still have them.
Current classic fleet: 72 K5 Blazer CST, unrestored factory Orange paint...mostly 69 C10 factory SWB, 454, TH400, Saddle tan, Rust-o-ration 53 Studebaker M35 w/331 Reo gas I-6, Air Force Strata Blue |
#52 |
![]() Join Date: May 2011
dutchmanz belts still available pm sent
#53 |
tjsblazer I checked 3 frames it appears there is one long one and one short one on a crossmember if that is correct 25 for the pair plus shipping let me know.
#54 |
gpat@earthlink.net does not look bad will get a picture tomorrow and mark where I think you want it cut and you can confirm. Just so we are on the same page passenger side correct?
#55 |
That sounds right to me. Can you pm or post me a quick pic just to be sure. I will take them if they check out ok.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
#56 |
tjsblaser will get you pictures tonight
#57 |
gpat@earthlink.net attached is a photo of the a pillar with red lines where to cut if I understood you correctly. 40 plus shipping if still interested I will cut the windshield out and make sure it looks ok underneath the rubber. Let me know.
#58 |
correct picture
#59 |
Pictures for tjsblazer
#60 |
Do yo happen to have the gas tank straps?
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
#61 |
Yes the gas tank is still in it I will try and remove tonight and post some pictures of the straps. If not tonight then sometime this weekend.
#62 |
Actually I found a bought a minty set just after I posted. I am sure someone else will want them though, the repro straps are junk. Thanks anyways.
#63 |
No problem just glad you left me know before I pulled it. Thanks
#64 |
Those are the brackets but they seem pretty corroded. Not sure how a blast would leave them. I think I'll hold off for now. Thank you.
#65 |
No problem I think they would be fine blasted but you call thanks for letting me know.
#66 |
![]() Join Date: Sep 2007
I need the passenger side bracket for the park brake equilizer. Its a little further forward than mid-frame and is next to the transfer case and has 2 rivets attaching it to the frame ride behind the passenger side exhaust hanger bracket.
Let me know, please. |
#67 |
Will check tonight if it is not raining.
#68 |
Pic for BigCarl this is on the drivers side I do not have anything on the passenger side but a ebrake hanger which is just a rod with bent ends
#69 |
ttt
#70 |
![]() Join Date: Aug 2010
Wondering if the 4 inch lift is still for sale? Thanks
#71 |
![]() Join Date: Aug 2013
#72 |
Yes it is
#73 |
#74 |
They are cracked but not in two pieces they are definitely not perfect. I do have another roof rack if interested not sure of the shape of that one either. I can get better pictures of both roof racks and the steering box tonight.
#75 |
Does it have a gas tank skid plate? If so I might be interested.
1970 GMC 1500 stepside 1972 GMC Jimmy Custom 2004 Chevy Colorado 1989 Swb Silverado 1972 Aj's Stormer |
