#76 |
Re: power window regulators on the cheap
Mark ,,I used a hole saw
1971 Chevy C-10, 5.3, 4L60E,4.10 gears UNDER CONSTRUCTION Mid size bed conversion https://picasaweb.google.com/1114721...yC10MidSizeBed The basic buildup https://picasaweb.google.com/1114721...3/1971ChevyC10 |
#77 |
I just got my Ebay switches wired,,there real nice!! great deal on those,My local ecology pick a part wanted more $$
#78 |
![]() Join Date: Jun 2005
How do you remove the spring from the regulator?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#79 |
put the regulator in the up position and pry it off carefully. it might help to put a towel over it while prying off.
#80 |
Well, looks like I have a winter Project! I had been thinking about doing this.
#81 |
I finished mine a while back but just got around to installing them now that the doors are painted. They work great the window goes up nice and quick. No issues at all.
Thanks so so much for this great tip. Glad I found it on YouTube and then the pattern on the forum. thanks again
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
#82 | |
glad it worked out for you to.
#83 |
great write up! ford taurus (95) has 9 tooth gear also. work great for AD truck conversion. those 91 motors are cheap $16 rockauto!
#84 |
![]() Join Date: Dec 2012
sweet! defiantly doing this!!
1969 Chevy C/10 Stepside, Short Box. LQ4/4L80E swap in progress! (Donations being accepted!) |
#85 |
I cannot wait to do this mod.
Subscribed. |
#86 |
BlahBlahBlah
I was messing around with one of these power regulators out of an Astro van, be careful of those springs. I cut the heck out of my hand when it caused the arms to scissor on me .... sorry no pics =)
#87 |
at princess auto they have surplus motors im going to go buy a couple and do this
nice post love it anyway to get away from full retail im in lol |
#88 |
![]() Join Date: Oct 2012
VERY KOOL! need to save this info
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
#89 | |
#90 |
Thanks for the update, I'm working on a window switch that will allow you to keep the factory window crank in the same hole it was originally (like the aftermarket version currently available, but on the cheap, keeping with your theme
![]() Here are a few pics: |
#91 |
Great idea here. Thanks for reviving the thread or I'd have never seen it
![]() This should help on the wiring ideas:
Matt 43 Last edited by IADC43; 07-06-2014 at 12:20 AM. |
#92 |
i did it too just finished this mod is awsome
#93 |
another trick for the spring i clamp in vise cut tab with air hammer
release from vise |
#94 |
just did my other one figured out how to get the guide to work a little better in the pic below you will see that if you cut the guide out like below you can put it in the vise and flatten it a little only needs to be flattened the thickness of the metal then it can be put over the gear and tacked in place.. also i welded studs to the metal instead of grinding the bolts
btw i really love this mod i hope as guys figure stuff out with this mod they keep posting it one guy came up with this and as a team we are making it into a great mod go team go ![]() |
#95 |
oops i see someone else beat me to the welding stud thing
#96 |
I haven't had time to try (nor does it look like I will) this mod. I was thinking when I try it about using this switch and somehow affixing a stock handle to it instead of the switch handle that's there. I don't have anything to mock up with, so there may be clearance issues, etc. However, it seems a possible way to keep the stock look.
It's not that I am apathetic, I just don't care. If your life is a joke, it appears death will be your punchline. |
#97 |
Finally did this mod. Followed all instructions. Followed video on how to make a relay so you don't prematurely burn up the switches. Also got inspiration on the micro switches to keep the stock look. Here's a pic. It works great.
#98 |
Notice the springs keeping the unit centered. In the picture above.
#99 |
Do you have a schematic for wiring the relay?
#100 |
I actually used the schematics from the youtube video IA DC posted above and instead of going to the standard window switch it went to my home made switch. I will post a drawing of that. Check this video.... https://youtu.be/dLKuZeUe6is
