Old 07-11-2014, 09:21 PM   #1
Beaumont@
Bucket seat conversion using bench seat brackets how to
I've always liked the look of factory buckets so I decided to gut the bench seat interior in favor of bucket seats. After no luck trying to track down a decent set of 1970 buckets seats $$$$, I decided to go another route by using my old 1970 bench seat brackets for the drivers seat and some old beat up bucket seats from a 73 and up truck which are cheaper and easier to find. I was pretty happy with the results.
Before & After 1970 C10
Here's what I started with:
I found a local guy who had around 10 of these 73 and up seats lying around.
Pretty sure they were out of a 1975 truck. Once the brown seat had the nasty cover off there was the little chrome square in the center.
Here is the key to making bench seat brackets work on the drivers side bucket seat. 2 simple easy to make brackets
Beaumont@ is offline   Reply With Quote
Old 07-11-2014, 09:45 PM   #2
Beaumont@
Re: Bucket seat conversion using bench seat brackets how to
Here's what the seat frames looked liked after tear down. I doubt GM painted these back in the day judging by the amount of rust that came off of mine. I had to get new back rest springs, they had completely rusted and broke.
and after being sandblasted and powder coated, mocked up in the truck:
The passenger side seat brackets I just ordered from ECE (Early Classic Enterprises) They are direct bolt in.
Here's a good link for bolt hole locations:
http://67-72chevytrucks.com/vboard/s...d.php?t=516328
Restored pic after using the best parts from the 2 consoles I had.
Old 07-11-2014, 09:47 PM   #3
Beaumont@
More to follow....
Old 07-12-2014, 12:21 AM   #4
Beaumont@
Now for the driver' side. As you can see from the pic, the original 1970 bench seat brackets both required some light modification in order to work with the new bracket adaptors. The rear mounts were shortened and flipped "forward" and welded in place. Just use the original bench seat floor bolt holes for the driver's side seat bracket (one closest to the door) New floor holes will have to be drilled for the other bracket (closest to the console).
Pic of what a stock 1970 bench seat bracket looks like:
Pretty good write up of the different types of bench seat brackets by year:
http://67-72chevytrucks.com/vboard/s....php?p=5374820
This what the bracket adaptors look like once bolted to the drivers seat:
I had to mess around to get the right height that's what the wood blocks are for and notched the rear bench seat bracket mounts for clearance issues. I also drilled a new bolt hole on the bench seat bracket mount closest to the center console, again for clearance issues.
and what it looks like once everything is bolted in place. 5/16 holes were drilled and tapped into the bracket adaptors:
Attachment 1276817
Old 07-12-2014, 01:31 AM   #5
Beaumont@
For my seat foam I contacted a board member Tim aka "Truckseats" awesome guy to deal with. Good' ol made in the USA seat foam:
I should have got my Truckworld seat covers from Truckseats as well but I made the mistake of going with Classic Parts of America. They assured me that they were sending Truckworld covers but they sent me PUI covers instead . Anyways after they tried to deny it I provided them a transcript of the conversation I had with the salesman when I ordered them online. So they finally agreed to take them back and send me the correct Truckworld seats covers. It took 4 months all said to finally get them but it was worth it. It also allowed me to compare both the PUI cover and Truckworld covers. Glad I held out.
PUI Covers (left side) Truckworld Covers (right side)
Size:  68.7 KBName:  IMG_4292.jpg
Size:  57.2 KBName:  IMG_4289.jpg
As far as I can tell the scrolling on the Truckworld seat cover is more crisp and they use more stitching where needed.
Old 07-12-2014, 01:36 AM   #6
Beaumont@
Final product, clean buckets with no hidden rust on seat frames
Old 07-12-2014, 01:52 AM   #7
VA72C10
VA72C10
VA72C10's Avatar
nice work!
Old 07-12-2014, 02:00 AM   #8
Beaumont@
Thanks VA72C10! After this little project I understand why buckets seats and consoles bring in the prices they do.
Old 07-12-2014, 09:19 AM   #9
Lee H
Lee H's Avatar
Looks very nice.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 07-13-2014, 12:25 AM   #10
1969stepside
1969stepside's Avatar
can you tell me how and where you decided to drill your holes in the floor to go from bench to buckets? did u use the existing holes on the outside and then drill where the other ones would go?
Greater love hath no man than to lay down his life for a friend.
Members i Have met
Earl Slick68
1969 Stepside Build thread
http://67-72chevytrucks.com/vboard/s...=1#post4253546
Chevy Trucks the longest lasting most dependable trucks on the road
1969stepside is offline   Reply With Quote
Old 07-13-2014, 01:02 AM   #11
CCCC
CCCC's Avatar
Lot of planning - lot of work - well done. Looks very nice.
CCCC
67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison
Moved but still in the family
70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350
Recently sent to new homes
72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp
CCCC is offline   Reply With Quote
Old 07-13-2014, 05:55 PM   #12
Beaumont@
It wasn't bad at all. I just used the existing driver's side bench seat bracket holes. I had to drill 4 new holes for the drivers side bracket closest to the console. It was easy enough with the other bracket to reference from.
For the passenger side just a little correction, it was not direct bolt in. 3 new holes had to be drilled. Only the existing outside front could be used.
Old 07-14-2014, 10:22 AM   #13
You've done something I have only pondered. Thanks for getting out there and doing it so I can see it can be done! That came out great
Old 07-15-2014, 10:45 PM   #14
Beaumont@
Hey no worries special K, thought I'd give back a little since this site has helped me out so much already with my truck. Paying $200 for 2 used buckets and 2 consoles was a lot cheaper than the $600 + for used factory originals I was coming across.
Old 07-16-2014, 12:32 AM   #15
tommyd241
tommyd241's Avatar
Looks great!
'68 SWB Fleetside
'98 K1500 Silverado
tommyd241 is offline   Reply With Quote
Old 07-17-2014, 11:11 PM   #16
JonnyC10
That is sweet!
JonnyC10 is offline   Reply With Quote
Old 03-11-2015, 04:37 PM   #17
justin4260
justin4260's Avatar
how did you reinforce the holes you had to drill for the new brackets?
justin4260 is offline   Reply With Quote
Old 03-11-2015, 05:26 PM   #18
Husker
Husker's Avatar
Very Nice
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 03-14-2015, 01:08 PM   #19
Beaumont@
Because the bench seat floor pan doesn't have the bucket seat floor brace I just cut some lengths of c-channel to reinforce the holes underneath.
Old 03-14-2015, 01:37 PM   #20
tinsoldier
tinsoldier's Avatar
very nice.
tinsoldier is offline   Reply With Quote
Old 03-14-2015, 02:52 PM   #21
GOPAPA
"Tail Gate Best Seat In House"
GOPAPA's Avatar
Very good idea ,real good to add to search area ,,, looks good ,,works good ,,and it is good,,thx for sharing with the forum..
When you learn a thing a day you store up smart.
GOPAPA is offline   Reply With Quote
Old 03-14-2015, 10:12 PM   #22
9teen69
9teen69's Avatar
Nice job, they look really good.
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline   Reply With Quote
Old 03-15-2015, 01:59 PM   #23
va72longhorn
va72longhorn's Avatar
Just out of curiosity, is there anything special that has to be done to do the conversion in reverse? Ive got the original factory buckets, that I love, but I'd like to be able to switch out every now and then when I may have two passengers planned. I always thought it would be no more than a 30 minute switch over. I've got a parchment white vinyl with no tears, but I'd like to recover one day in the orange highlander plaid.
Any thing Ive overlooked ?
va72longhorn is offline   Reply With Quote
Old 03-15-2015, 02:18 PM   #24
mechanicalman
Nice job, nice truck, nice thread, WELL DONE.
mechanicalman is offline   Reply With Quote
Old 03-15-2015, 03:19 PM   #25
jjzepplin
jjzepplin's Avatar
That is one nice job you have done there!
How much did you shorten the bench brackets before you flipped them forward and how did you do such a nice job of flipping them?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
