Sum Old Parts -72- 2wd conversion
Mostly original 72 Blazer
Re: Sum Old Parts -72- 2wd conversion
Started tear down about 3 years ago. The Blazer was solid and complete,
Stripped Everything off the frame. Lots of rivets drilled and punched out. Removed all 4X4 springs, cross members. Sand blasted frame and started reconstruction.
Seconds tick by...or seasons in this case.
Frame Spec's help to find out how the original was built, a lot of Cleaning and sand blasting and repainting, some things got done more than once.
Not a lot of photo's of pieces going back together, tried to use as many original 2wd truck parts as possible. Couple teaser pic's of the color.
Looks good so far! Are those corvette ram horn manifolds or 4x4 ones?
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
Silver Manifolds in the photo were original 4x4 dump strait down. had to replace with Dorman 45 degree swept back.
Cleaned undercoating off everything, wheel wells, under hood radiator support and body. Used Mastercoat silver on bare metal and shot U-Pol Raptor bed liner tinted blue over it.
Top came off after body was bolted back on the frame, removed windshield and painted dash and cowl area.
Looking good!
66 el Camino 70 1/2 RS Z-28 71 C10 2wd 72 2 wd Blazer (2) 72 4 x 4 Blazers 88 24' Mirage 70 mph+ 08 Harley Night Train 08 Silverado 4d 4 x 4 |
Some Engine and drive train shots, after getting the whole thing together 327 didn't have good compression. (Bummer ) pulled that out in January and dropped in a crate 350. Drive shaft may have some history to it beefy 45" came from a motorsport engine builder outside Charlotte.
Parking brake cable was fabbed up out of a piece of frame rail. other bits copied from (Bruce's just a pickup)
I have been dreading the painting of the doors it took almost 2 weeks to get them prepped once started. After 2k primer, All pieces were painted bright silver,2 coats then topped with 3 coats of green.
#15 |
Some orange peel but over all I am very pleased with the way it came out
#16 |
A day late and $1 short...
Looking good! I'm going to follow along.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
#17 |
After 5 Coats of clear
#18 |
Painted original grille a few years ago, had a few holes and cuts in it. 67-72chevytrucks.com/vboard/showthread.php?p=5082961&posted=1#post5082961
#19 |
Good looking truck man, I see that you are local. Im down just south of the md/va line in temperanceville va. Hope to see you around.
-j-rod '06 3500 LWB CC 4wd, 8.1 Allison |
#20 |
Thanks jhama78, slowly getting a few things done, seats in.
#21 |
Side Panels made from 3/8 Aztek acrlic
#22 |
![]() Join Date: Aug 2005
Did using the garage door pully help as a multiplier for your rear brakes? Thanks
#23 |
No real mechanical advantage over the original hook and eye.
#24 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Wow! Excellent work! Any chance you have the any leftover parts to sell like some of the small stuff on the motor?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#25 |
