Old 06-19-2014, 10:28 AM   #351
Kim57
Kim57's Avatar
Re: 1958 Apache 38 Dually Dump Project
Looking good.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 06-21-2014, 04:04 AM   #352
RockTonka
RockTonka's Avatar
Thanks Kim!
Worked a bit on the steps tonight, got the drivers side done and a good start on the passenger side.
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 06-21-2014, 11:20 AM   #353
Kim57
Kim57's Avatar
Very slick looking.
Fits your truck design very well.
Kim
My build thread
Old 06-24-2014, 01:12 AM   #354
RockTonka
RockTonka's Avatar
Hey Kim, thanks again! We appreciate your encouragement!!
Got a few things in today to play with...
My build thread
Old 06-25-2014, 12:24 AM   #355
RockTonka
RockTonka's Avatar
Not much to add, but keep chipping away. We had an old 1350 CV shaft that we were hopeful would fall into place for the front...turns out it was just a couple inches too short. We had it re-tubed, swapped out yokes at the transfer case and axle, and front drive shaft is in!
My build thread
Old 06-25-2014, 06:25 PM   #356
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice work!
Ryan
1969 Chevy milk truck
Old 06-26-2014, 01:36 AM   #357
RockTonka
RockTonka's Avatar
Thanks again DW!!
Made a backing plate for the pedal assembly...we will tie that back into the dash and column mount for reinforcement. We hung the pedals where they seemed to feel the best and zip tied the column about where it's going to end up at...will try to get the upper/lower column mounts built out over the next few evenings.
My build thread
Old 06-26-2014, 10:28 AM   #358
Kim57
Kim57's Avatar
Those are nice looking pedals.
Kim
My build thread
Old 06-28-2014, 02:56 AM   #359
RockTonka
RockTonka's Avatar
Kim
I think they'll work well, makes for an easy install.
Got the upper/lower column mounts done...relationship between pedals/steering wheel/seat is near perfect for what we like.
My build thread
Old 06-28-2014, 10:46 AM   #360
Kim57
Kim57's Avatar
Very nice column mount.
Kim
My build thread
Old 06-29-2014, 01:06 PM   #361
cAlvis165
cAlvis165's Avatar
Sorry if this is an ignorant question, but are two of those reservoirs for the brakes. If so, is one for the front and the other for the back?
Looking good on the project . This is one of my favorite builds on the forum.
Chad
Success is not final, failure is not fatal: it is the courage to continue that counts. Winston Churchill
DD 2000 Chevy Suburban 4x4/5.3 Vortec/4L60E/4:10s, 18" Escalade rims, Electric fans
Project Dooley One-Ton 4x4 on 38.5s Corn-binder build
cAlvis165 is offline   Reply With Quote
Old 06-29-2014, 11:56 PM   #362
RockTonka
RockTonka's Avatar
Thanks Chad, and yes, one master each for front and back. We set them up with different bores, 1" for front and 7/8" for back, which when used in conjunction with the built in bias bar allows for more front/rear bias control than even a proportioning valve.
My build thread
Old 06-30-2014, 12:15 AM   #363
RockTonka
RockTonka's Avatar
Stripped the driver door down and rebuilt both hinges (after a bit of torching and hammering). We had to cut most of the very bottom of the door out, but the rest looked pretty good. We test fit the doors quickly to check fit...not perfect, but pretty close and no droop or looseness. We will patch the bottom next and prep for paint.
My build thread
Old 06-30-2014, 12:33 AM   #364
Rods57
Rods57's Avatar
Love the running boards,that's cool. How thick is the steel your using?
Rods57 is offline   Reply With Quote
Old 06-30-2014, 01:32 AM   #365
RockTonka
RockTonka's Avatar
Thanks Rod, using 10ga. for a number of different things...mainly because I picked up a couple strips at the salvage yard a few weeks ago
My build thread
Old 06-30-2014, 01:48 PM   #366
_Ogre
_Ogre's Avatar
looking good rocktonka
shop air compressor timer
Old 07-10-2014, 03:58 AM   #367
bigd126
subd
bigd126 is offline   Reply With Quote
Old 07-13-2014, 12:26 AM   #368
Fleet '66
Active Member
Fleet '66's Avatar
Just finished reading the whole thread! I really admire your Fab skills and like the use of the dimple dies on the various mounts and brackets. IMO that really adds to the level of craftsmanship on a build. I also like the way you built the front grill guard/push bar to the bumper. I have to admit though that I have a bit of bias for the 58-59 Task Force trucks. Keep up the excellent progress, I'm loving it.
Fleet '66
'66 C-10 SWB 350 w/3 spd OD 4:11's - driver/project...future T-5 trans upgrade
'64 C-10 LWB BBW near future project - "The Wife's Ride"
'58 "Apache"Stepside BBW w/'75 K-10 4x4 conversion 331 w/350TH and NP 205 transfer 3:73's - occasional driver/ show
Fleet '66 is offline   Reply With Quote
Old 07-22-2014, 01:22 AM   #369
RockTonka
RockTonka's Avatar
Thanks Ogre! I've drooled over your truck many times...wish I had the skills to produce such polished work.
Originally Posted by bigd126 View Post
subd
Glad to have ya along for the ride!
Thanks Fleet '66...really appreciate your taking the time to read through our thread!!
My build thread
Old 07-22-2014, 01:25 AM   #370
RockTonka
RockTonka's Avatar
Started working on fitting the bed into place...
My build thread
Old 07-22-2014, 01:29 AM   #371
RockTonka
RockTonka's Avatar
Also got some more parts in
My build thread
Old 07-22-2014, 09:54 AM   #372
Kim57
Kim57's Avatar
Sure is looking good.
Kim
My build thread
Old 07-29-2014, 02:40 AM   #373
RockTonka
RockTonka's Avatar
Thank you Kim!
We've been fooling with the bed, moving it back and forth and up and down a bit...we think we got it pretty much where we want and have a game plan on how to incorporate the tilt capability to the new chassis.
So far, we have built out the rear hinge/pivot on the frame by sliding a 3/8" x 4" strip down the inside of the rear frame rail about 18". Popped the rivets from the rear spring hangers and bolted/welded the strip in place. Hole-sawed a 1 3/4" hole through the frame/strip on each side and boxed in/welded a section of tube from side to side. A 1 1/2" dia. solid rod will slide through this, sticking out each side about 3" that will support bushings welded/gusseted up to the frame of the bed...hope to have the bed part done tomorrow night.
My build thread
Old 07-29-2014, 09:17 AM   #374
rambler
MOVE OVER
rambler's Avatar
havnt seen this thread in awhile,, amazing work !
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 07-30-2014, 02:13 AM   #375
RockTonka
RockTonka's Avatar
Thanks rambler, glad ya checked back in!
Still working on mounting the bed...ran out of steel, gotta make a run tomorrow. We did get the drag link welded up and in...crossover to a high steer arm on the pass side. Also ran the column to box linkage, it slid right under the headers just with joints at each end (had to massage the yoke at the column for a bit more angle).
My build thread
