Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 01-26-2014, 04:48 PM   #1
Campbel45
Under the seat subs
Ive got a 71 and I dont wanna take the gas tank out. I think its cool and I like the smell of gas lol. I've seen that pioneer and JL make a very shallow sub. Has anyone made there own under the seat sub box?
Campbel45 is offline   Reply With Quote
Old 01-27-2014, 09:27 AM   #2
panhandler62
Java Mechanic
panhandler62's Avatar
Re: Under the seat subs
Here are some threads that might be helpful:
http://67-72chevytrucks.com/vboard/s...d.php?t=264225
http://67-72chevytrucks.com/vboard/s...d.php?t=222093
http://67-72chevytrucks.com/vboard/s...d.php?t=296432
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 02-12-2014, 03:09 AM   #3
oldspowered67C10
I used 1 alpine swr-t10 and used a fosgate power 1000 to run it. Sounds good but there was barely enough room for it. Box ended up having to go up into the seat bottom close to the springs and still ended up being on the low side of air space but with some poly fill sounds pretty good. Theres not much room down there but its doable.
oldspowered67C10 is offline   Reply With Quote
Old 02-15-2014, 02:23 PM   #4
Kudzupatch
Kudzupatch's Avatar
It depends on what you looking for. Do you want to annoy the people next you or do you just want good sounding bass notes?
I installed a powered Sound Ordnance unit in my Suburban and I love it. Of course I am not into window rattling bass either. But it sounds much better than I expected and I well pleased with my choice.
http://www.crutchfield.com/p_777B8PT...ce-B-8PTD.html
Kudzupatch is offline   Reply With Quote
Old 02-23-2014, 04:15 PM   #5
dibbleg
I'll second that sound ordnance as well. have one in my 67 c10 and it's plenty for me
Chris Mead Tattoos
dibbleg is offline   Reply With Quote
Old 02-25-2014, 11:16 AM   #6
Billett
Billett's Avatar
I plan to once it gets warmer. There's enough space under there for one sub with plenty of air, maybe two but I kind of doubt they will get enough space. Pop on over to home depot, but a sheet of 3/4" mdf, measure twice, cut once haha. I'm looking at the RF P3SD4-10. Requires 0.4-1.0 cubic feet of space. Removing the seat adjuster cable and hardware would give more space, but I think I can make it work and keep the cable.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 03-01-2014, 10:36 PM   #7
1970/327/c10
1970/327/c10's Avatar
Built one that held two 12" powerbasses. Ended having to put the seat on 1" risers. It worked but only problem is i faced the subs up causing the seat to muffle the subs.
Drivin People Insane With my Classic Chevy!
1970/327/c10 is offline   Reply With Quote
Old 03-04-2014, 11:47 PM   #8
Bad70sbchevy
Bad70sbchevy's Avatar
Mine are behind the seat. They fit 2 12" Full size Pioneer Subs. The seat does also slide all the way back and require no modification to the seats.
1970 Chevrolet C-10 w/355sbc
2010 Silverado Daily Driver
1971 Mercedes 280sl project car
Bad70sbchevy is offline   Reply With Quote
Old 03-12-2014, 10:33 AM   #9
jjmiracle
I vote for the JL Audio CP106LG-W3v3 or it's counterpart JL Audio CP108LG-W3v3 if you're looking for something a little larger. These fit great under my 71s bench seat. I only went with one 6" under the passenger side but I tell you what. That thing produces some of the cleanest low end sound I've ever heard. Not a single person who gets in my truck can believe that that much bass is coming from that little 6" sub. I think if you went with 2 of the 8" ones (one under each side and powered it properly along with some serious highs to cut through the bass) you won't be disappointed. Like someone else said it's all in what you want. I am 100% satisfied with that 6" sub. It won't knock the rearview mirror off but it sure shakes the hell out of it and my passengers only notice a slight vibration underneath them. I listen to a wide range of music so I have to really turn down the low end on my equalizer for something like country but if a hip hop song comes on and that equalizer is up you can feel it in your throat. Hope this helps!
jjmiracle is offline   Reply With Quote
Old 03-12-2014, 03:47 PM   #10
Hugh Mongus
One 10" L7 is more than enough for the cab of a truck.
-Jason
USN Retired
Hugh Mongus is offline   Reply With Quote
Old 03-12-2014, 06:58 PM   #11
Billett
Billett's Avatar
That won't work for those of us with benches haha. Also, how do you like the L7? I wasn't a fan of the square MTX I had so I'm leery of square subs now anyway...
Will
2024 Toyota Sienna
Old 03-12-2014, 11:16 PM   #12
Hugh Mongus
L7s are awesome.
-Jason
USN Retired
Old 03-14-2014, 05:05 PM   #13
Campbel45
Nice set ups but I am keeping the bench seat and my tank. Ive heard L5s that I couldnt even believe the amount of bass they put it out. I'm impressed with their SPL. Ive never really been impressed with MTX, not bad but I think they lack in overall areas. My vote will most likely go with JL audio as I have had their 10" 3v3 and liked the quality of sound and had almost too much bass when I wanted it.
With an old 71 I'm going to guess that any sub that is designed for SPL is going to amplify the "tin can" rattles of these trucks. But thats what dynamat is for I suppose.
JL's TW5v2 has my interest right now as its only 2.5" deep but worried about the 13.5" diameter.
Decisions, Decisions..
Old 03-14-2014, 05:07 PM   #14
Campbel45
You dont happen to have any pictures do you?
Old 03-17-2014, 04:20 PM   #15
jjmiracle
Well the truck interior is sort of in shambles right now but here are a few pics I took the other day. In the midde of the bench seat is my amp and sitting on top of it is my equalizer which usually is attached to that little bracket you see mounted in front of the amp. I just have it moved because I was working under the dash and didn't want to accidently lay on it. You can see the JL sub in its little self enclsoed box. This is the 6" version but they make an 8" as well. That 6" is plenty for my needs though and like I said hits a lot harder than you'd think. It fits under the seat well and where you see it in the pic is where it actually stays. Also, the cab is lined with hushmat underneath the carpet which I think helps with the 'tin can' sound some guys talk about. I don't get any rattle or weird acoustics as if I was in a storage container. Sounds clean.
Old 03-18-2014, 05:51 PM   #16
Billett
Billett's Avatar
I kept the tank in mine and have no problems. 2 6.5" speakers under the seat right now and there's definitely room for at least one shallow sub. I suppose you could also do two forward firing 6" subs, but I'd rather have the shallow. Hell I even have the seat adjust cable still in there and working.
Will
2024 Toyota Sienna
Old 07-03-2014, 10:42 AM   #17
Underwoj
i got the Kicker Hideaway sub and very impressed with it! not crazy stupid bass but a nice punch sound from it. I got the 8 inch. fits perfectly under the pass side seat (or drivers) and you still have room to play.
Underwoj is offline   Reply With Quote
Old 07-03-2014, 10:58 AM   #18
Campbel45
Got any pictures?
Old 07-03-2014, 11:04 AM   #19
Underwoj
haha first is the madness of the wires and second is after (as you cldn't tell). everything sounds really good...also got an Alpine comp setup in the doors and some 3.5's kickers in the dash...
Old 07-20-2014, 12:17 AM   #20
Boyd
Resident Lurker
Boyd's Avatar
I used a Boss 8" 800w slim line sub. I'm happy with it.
The Rotten Mule: '72 Chevy Short Step Project- http://67-72chevytrucks.com/vboard/s...d.php?t=417252
"Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats."- H.L. Mencken
Boyd is offline   Reply With Quote
