Swap Issue
Hi All,
I am having a problem with my truck after swapping in a 03 5.3L. I have around 700 -800 miles on it now and this issue showed up in the last 100 miles or so. The truck will not start on the first try it just spins and doesn't act like it is firing. I can shut the key off and then try again most of the time it won't start again but will backfire out of the exhaust. On the third time it will usually start. I am getting a code for cam position sensor(P0343) and lean condition(P0171,P0174). I have replaced the cam position sensor and it acts the same. I have done some research and seen were some people were having problems with the cam bolts coming loose. I took the cover off and check them and they are tight. The timing chain seemed a little loose but from what have read that is pretty normal. Just wondering if anyone has any ideals on what it could be? After it starts it seems to run just fine. Sorry for the long just trying to give as information as I can. Thanks John |
Re: Swap Issue
I would check the wiring and connectors. Sometimes they can be getting a bad connection and cause problems.
Re: Swap Issue
Ok I was thinking about doing that. It is a new harness but I will check it out and make sure they look ok. Thanks for the reply!
meowMEOWmeowMEOW
Re: Swap Issue
Is the engine cammed?
Try doing a CASE relearn. Search here or on LS1tech for the procedure. It puts the cam and crank sensors back into phase with each other, and should clear the code. The lean condition may just be a side effect from the backfire. When you clear the codes and do the CASE relearn, I'm guessing it will go away on its own. If not, you may have 2 unrelated issues, but don't fret about that until you try the above first.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#5 | |
Re: Swap Issue
![]() Join Date: Apr 2005
Re: Swap Issue
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#7 | |
Re: Swap Issue
