Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 08-11-2014, 03:46 AM   #1
1960chevypanel
1960-1962 4x4 tank?
Does anyone make repop underbed fuel tanks for 4x4's? The tank in my truck isn't original and I'd like to find the right one... Any leads would be appreciated!
1960chevypanel is offline   Reply With Quote
Old 08-12-2014, 12:11 AM   #2
Captainfab
60-66 Nut
Re: 1960-1962 4x4 tank?
No one repops the fuel tank for the '60-'66 Suburbans and Panels. Since yours is a 4x4, the frame width should be the same as a '63-'72. In which case you could use the '69-'72 Blazer tank with a 0-30 ohm sender. You just won't be able to carry a spare tire underneath.
Old 08-12-2014, 02:27 AM   #3
1960chevypanel
Thanks Fab, I'm trying to find the "correct" tank to keep the truck all original... But that info might prove useful on another project.
Old 08-12-2014, 02:31 AM   #4
1960chevypanel
I found a tank locally but I'm not sure if it's the right one. Does anyone have a 60-62 4x4 Panel/Suburban that still has the original tank? If so I could really use the measurements.
Old 08-12-2014, 04:31 PM   #5
60-66
60-66's Avatar
Heres the one from my 1961 4x4 panel. Same as my 60 and 61 4x4 Suburbans.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
