Old 08-11-2014, 08:17 AM   #301
pimpston65
pimpston65's Avatar
Re: 1963 C-10 SWB BBW Fleetside in NC
Originally Posted by 1963c-10 View Post
Nice stash of parts pimpston65....did you get the two rear end mounts for the overload springs?
Haven't gotten to do anything with the seat yet, but I knew it would be a few months out. I need to order some more material from SMS. I think I have enough vinyl left over to take care of the color.
Did you still need the spiral shocks I have? No problem either way, just let me know and I'll get them off this week.
yup plates are there, just not in the picture. no worries on the shocks as i have a full set of NOS ones now. im done buying parts for awhile,, im lying if something catches my eye, and i have the $$$ its on!!!
pimpston65 is offline   Reply With Quote
Old 08-11-2014, 08:23 AM   #302
1963c-10
1963c-10's Avatar
Is your truck a short bed or long? I found that some minor work is required to fit the auxiliary springs on the short bed. Just a little trimming on the end of the outer bumper brackets where the mount to the frame. Think it was around 3/8" I had to trim off...but other than that they are bolt and play.
1964 Short bed trailer
Old 08-12-2014, 11:51 AM   #303
1963c-10
1963c-10's Avatar
Found a NOS 63 farm truck plate still in the matching original envelope today for the fleetside. These plates are very tough to find and especially in NOS. Will be a nice addition to the fleetside.
Old 08-12-2014, 05:22 PM   #304
WhippinSaw
WhippinSaw's Avatar
Score on the plates, very nice
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle.
WhippinSaw is offline   Reply With Quote
Old 08-13-2014, 07:47 AM   #305
TheBlueBomber
TheBlueBomber's Avatar
Going with stainless bolts?
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
Old 08-14-2014, 10:20 PM   #306
1963c-10
1963c-10's Avatar
Yeah probably.
Old 08-15-2014, 11:21 AM   #307
TJ's Chevy
TJ's Chevy's Avatar
Nice score on the plates!
Old 08-15-2014, 11:35 AM   #308
1963c-10
1963c-10's Avatar
Thanks man....the farm truck plates are hard to find here in NC....especially NOS
Old 08-15-2014, 10:31 PM   #309
Ta2Don
Ta2Don's Avatar
Those plates are
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 08-16-2014, 12:02 PM   #310
1963c-10
1963c-10's Avatar
Thanks, here some better detailed pics. Was never issued and has the matching nc dmv paper envelope. Nc lets us run year of make plates at no cost. Just have to be able to produce registered plate if asked. I keep the registered plate in the glovebox with a copy of the nc statute. Have had to show it 2x in 5 years.
Old 08-21-2014, 09:55 PM   #311
1963c-10
1963c-10's Avatar
All interior cab prep done on the stepside and it got dark, so figured id build a vacuum gauge for the fleetside gauge cluster. Used an older pontiac vac gauge and a 60-63 delete plate
Took 20 minutes total and had the parts on hand so no extra cost
..minus decal. I will have to order a new vacuum gauge decal.
Took the needle of using two spoons apply pressure under the base of the needle on the sides. They always pop of great this way. Removed the cover of the gauge by the two tiny bolts. Took the back side of the rivet off using a small phillips head screwdriver. The back of the rivet is soft.
.maybe 7-8 turns and it'll let the delete face free. Used the old gauge as the template and drilled a 3/16" hole for the needle. Bolt the new face on & thos is where the decal will apply....but you guys get the idea. I see these vac gauges go for $20 all the time if I had to purchase one on ebay. With a delete plate, gauge & decal and maybe 20-25 minutes...it'll make a nice addition to the truck and save $200.
The gauge itself is identical to my original gauge in my stepside. The delete is the same size plate..so once redecaled it'll look oem
Old 08-21-2014, 09:59 PM   #312
1963c-10
1963c-10's Avatar
Some more pics
Old 08-21-2014, 10:05 PM   #313
1963c-10
1963c-10's Avatar
Last few
Old 08-21-2014, 10:12 PM   #314
1963c-10
1963c-10's Avatar
Ill have to fix the pics tomorrow...my phones flipping pics. Will set the needle once the decals in. Put it in the cluster for now.
Old 08-23-2014, 04:56 PM   #315
TJ's Chevy
TJ's Chevy's Avatar
Gauge cluster looks good!
Old 08-23-2014, 05:27 PM   #316
1963c-10
1963c-10's Avatar
Thanks bud. Cant get to far into this build until the stepsides done, but cant help do some smaller projects
Old 08-24-2014, 08:14 AM   #317
PowerdbyChevy79
PowerdbyChevy79's Avatar
looking good brother...
1966 C10 Mary
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1976 C35 Sierra Grande "Mr. Harvey"
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
1982 C10 Silverado "Lucy"
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 08-24-2014, 09:16 PM   #318
1963c-10
1963c-10's Avatar
Thanks for the kind words and for checking the build out.
Old 08-24-2014, 09:44 PM   #319
pimpston65
pimpston65's Avatar
those vac gauges are going up in price, glad i snag'd mine i may just leave it and not change the face...
Old 08-24-2014, 09:50 PM   #320
1963c-10
1963c-10's Avatar
Thats a nice gauge...I dont blame you.
Old 08-24-2014, 09:52 PM   #321
1963c-10
1963c-10's Avatar
How will that mount to the cluster housing? I imagine the back of the housing plate will have to be modified?
Old 08-24-2014, 10:14 PM   #322
pimpston65
pimpston65's Avatar
i took it out the housing and it sets in there, but it was just a test, havent get too deep into it. i just add it to my to do list
Old 08-24-2014, 10:17 PM   #323
pimpston65
pimpston65's Avatar
found a sun tach for 12V 6cyl also. ima leave em with their faces kinda like the non original look. fricking repop vac and tachs are $200 apiece !!! but u already know that. paid less the $200 for both...
Old 08-24-2014, 10:23 PM   #324
pimpston65
pimpston65's Avatar
my latest project took me bout 30 mins to get it str. it was broke and twisted, but i got it
Old 08-24-2014, 10:24 PM   #325
pimpston65
pimpston65's Avatar
added to my to do pile
