4L60 Shift Linkage
I'm looking to hook up the tranmission linkage. Ive got a 77 Blazer 2wd with a 4.8 4L60 swap. What are the options that I have? Any pics would be great. Thanks
![]() Join Date: Aug 2004
Re: 4L60 Shift Linkage
locar cable or shift rod assembly. You could go either way
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
If I can get the factory linkage to hook up , will I be able to go through all the gears? I checked and it is lined up with the old bar linkage and I removed the factory cable shifting part and the linkage from the t350 fit right on
Has more rust than truck...
Some members have trouble getting down to 1st even with aftermarket linkage. I'm using the Lokar ACA-1800 linkage and have no problems, took a few tries to get the adjustment right though.
I cant think of any reason (other than grade braking) to "manually shift" a 4L60E. They shift just fine leaving them in 4th gear.
on my 68 I used an original 3speed linkage, and welded a bracket on the 4l60e gear selector that is 1 in. lower and 1 in. foward, it works great and engages every gear.
High School Project I ---http://67-72chevytrucks.com/vboard/s...d.php?t=639174 High School Project II ---http://67-72chevytrucks.com/vboard/s...27#post7290427 High School Project III ---http://67-72chevytrucks.com/vboard/s...d.php?t=715832 High School Project IV (Tyler) ---http://67-72chevytrucks.com/vboard/s...d.php?t=780186 |
very good info.. i have been wondering about this subject myself.
I'm gonna be running longtubes on my swap, and
by the looks of it, the factory rod-linkage is not going to function properly because of the header collector. I'm still trying to find a solution... |
Any updates?
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
3 on the tree to 4L60e in my 1966 C10
$11 (3/8" HRS rod, rod end, and heat/bend/tap it myself) after a few heat/bend/fit cycles.... ![]() my own shift linkage arm made at work...(next to rusty OEM one) ![]() ![]() ![]() ![]() ![]() ![]()
1966 C10 SWB Fleet 5.3L LM7 Vortec / 4L60e Swap 1966 C10 w/ 5.3L/4L60e Build Thread 2012 GMC Sierra 5.3L 4x4 CCSB |
Interesting, I'm thinking of trying to use the stock cable as well
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck ![]() My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
![]() Join Date: Sep 2005
I used the stock linkage on mine
When I installed everything I just made sure the transmission shift arm was in the same location as it was on the turbo 350. I also took the shift bracket off the turbo 350 and removed the one off the 4l60. Then put the 350 one on the 4l60. It fit perfect with no mods. They used the same d shaped shaft The. Just bolted the orignal shift rod up Worked perfect. Since this post I also pulled everything out of the blazer it was in and installed it in a 91 suburban. It installed the same
On my 76 2wd i used a shift arm from the frame to the transmission and the u shaped bracket on the shift shaft of the transmission from an 84 700r4 diesel. I found that the shift arm from the frame to the transmission is a different length between the 76 th350 arm and the 84 700r4. The initial adjustment and has the linkage working ok so far. My column is not set up for an o/d transmission and I cant get manual 1st. The short arm is from the 84 diesel 700r4.
#15 |
Just did the Lokar set up on a buddies swap. Only issue we had was it had a stock auto column in it and we had to grind the engagement tab off the stock column.
Brandon Instagram: DRVFSTR Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691 |
#16 |
Moved the pin up the frame to match the position of the 700r4 shift rod, adjusted all factory stuff, worked like a champ. Now with the 4l60E, the PRNDL sensor makes the trans package 3/4" thicker, so I took 3/4" out of the center of the crossover bar, bolts right up.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#17 |
Slots go on anything!
1974 Jimmy- 5.3/4L80e/NP241 |
#18 |
id like to see potos of this setup, i bought this item, and its pivotal limitations are too restricted to even come close to my needs.
