Old 07-03-2014, 02:09 AM   #151
andrewmp6
Re: 73-91 8-lug 19.5 22.5 24.5 Pics
Have you guys heard of http://nashvillewheelcompany.com/ they will custom cut a dually rim any size and bolt pattern.
Old 07-03-2014, 05:57 AM   #152
anubisani
anubisani's Avatar
Originally Posted by slimneverdies View Post
22.5???
24.5 having them cut to 24s
anubisani is offline   Reply With Quote
Old 07-03-2014, 08:05 AM   #153
watahyahknow
watahyahknow's Avatar
they all are untill you mill them
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 07-10-2014, 07:07 PM   #154
anubisani
anubisani's Avatar
my new wheels
Old 07-16-2014, 07:49 PM   #155
anubisani
anubisani's Avatar
Change decided to go matte black looks much better
Old 08-08-2014, 07:13 PM   #156
tobytuttle
tobytuttle's Avatar
heres a new shot of my 19.5's with my smooth caps
[IMG][/IMG]
[IMG][/IMG]
70 SS 454 Monte
69 355 C-10 Shortbed
90 454 Crew dually 4x
76 454 Dually 2x
75 454 K5
77 468 Kona
tobytuttle is offline   Reply With Quote
Old 08-20-2014, 07:40 PM   #157
anubisani
anubisani's Avatar
put the fronts on today.
Old 08-20-2014, 08:33 PM   #158
watahyahknow
hubcaps look nice havent seen those before only the ones inside the wheelnuts
Old 08-21-2014, 02:04 PM   #159
SCOTI
SCOTI's Avatar
What size tires?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-21-2014, 04:49 PM   #160
anubisani
anubisani's Avatar
Originally Posted by SCOTI View Post
What size tires?
305/35/24 tires
Old 08-21-2014, 07:59 PM   #161
watahyahknow
personally i think the 24's are a little to big for a squarebody the sidewall on the tires you need to fit under the square tires just dont look right , they do look good on the newer trucks though with a bit more sidewall
still have a set of 22's i need to put on mine
Old 08-21-2014, 08:23 PM   #162
slimneverdies
slimneverdies's Avatar
305/35/24 tires
Attachment 1291878
I like it... Is your suspension completely stock? I'm going to go with a 295/30/24 but with a drop
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 08-21-2014, 09:00 PM   #163
anubisani
anubisani's Avatar
yes its 2wd post some pics of how it is now
Old 08-22-2014, 03:09 AM   #164
slimneverdies
It doesn't have the 454 in it anymore. It's 2wd also...
Long live SLIM
Old 06-12-2016, 05:45 PM   #165
rickywideglide
rickywideglide's Avatar
Got 3 wheels on of course last wheel has two froze lug nutsName:  20160612_125008.jpg
rickywideglide is offline   Reply With Quote
Old 06-12-2016, 05:47 PM   #166
rickywideglide
Another shotName:  20160612_124951.jpg
Old 05-20-2018, 08:07 PM   #168
dieseltech619
Originally Posted by rickywideglide View Post
Another shotAttachment 1542626
Where did you find those center caps? I got a set 19.5s id like to put on my 88 1 ton but i want to run centers like yours
dieseltech619 is offline   Reply With Quote
Old 05-20-2018, 08:39 PM   #169
rickywideglide
Those were the stock caps off old chrome covers,then I added the chrome lug nut covers
Old 06-02-2020, 01:14 PM   #170
theastronaut
theastronaut's Avatar
Just put a set of P30 wheels on the shop truck.
theastronaut is offline   Reply With Quote
Old 06-05-2020, 08:03 AM   #171
Pontiac1976
Pontiac1976's Avatar
Great looking truck eye catching. That mirror must be all most out of mirror side clamp, or you extended your mounting rod
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 06-05-2020, 08:48 AM   #172
Nice clean look
Old 06-08-2022, 11:34 AM   #173
skippie69
Where you guys finding the p30 steel 19.5s????
Todd
skippie69 is offline   Reply With Quote
Old 04-20-2023, 02:08 AM   #174
Rocketogre
Todd
I second Todd's question. Especially ones in good shape!
Rocketogre is offline   Reply With Quote
Old 05-10-2023, 04:11 PM   #175
Android04
Android04's Avatar
22.5" cut to 22"
Android04 is offline   Reply With Quote
