Old 08-21-2014, 08:16 PM   #176
gottattooz
gottattooz's Avatar
Re: Captain America 68 short/fleetside
Originally Posted by Operatorfailure View Post
If the fronts work without spacers I would be tempted to get some nice late model wheels and run to pick n pull and get a 99+ disc brake rear end. I think they are under $200 out the door. That would put the back spacing right and get disc brakes on the cheap.
Here's the specs on the rims I bought. 20X8.5 with 22MM back spacing.
-Josh
1967 Buick Special wagon
1968 Jeep Wagoneer
1958 Chevy Panel Truck
2017 Suzuki M109R
gottattooz is offline   Reply With Quote
Old 08-22-2014, 12:00 AM   #177
colgad
colgad's Avatar
Originally Posted by gottattooz View Post
And here are pics of the inner and outer sidewalls off the tire with the suspension up (first two pics), and suspension down. There's quite a bit of travel side to side when the suspension drops. I'm thinking I might have to get the adjustable panhard bar that goes from the frame to the passenger trailing arm. I have the adjustable bar for the stock location, but it's allowing too much lateral movement I guess.
-Josh
The long CPP adjustable bar is only 109 with the forum discount
My rims are 0 offset and are 10" wide but the size is only 275x45x20 and I have no issue with clearance with the full travel of the bags.
Here is a great calculator for offset and clearance issue.
https://www.customwheeloffset.com/ti...et-calculators
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 08-22-2014, 12:05 AM   #178
colgad
colgad's Avatar
-Josh
Remember that 22mm is offset not backspacing the backspacing will be 5.62"
The calculator is great for figuring that out and for current wheel / tire size compaired to new wheel / tire size. It will tell you that a different offset or size will increase or decrease the distance of the rim to the inner wheel well and outer wheel well.
Handy stuff
Old 08-23-2014, 04:13 PM   #179
gottattooz
gottattooz's Avatar
Thanks for clarifying, Dave. I do know the difference between back spacing and offset, even though I worded it wrong. That calculator for the wheel offset is pretty cool.
I must say, the company I got the spacers from is super fast when it comes to delivery times. Got the correct spacers in today, and there's a considerable difference between the two.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 08-23-2014, 09:33 PM   #180
colgad
colgad's Avatar
So how does the new ones fit? Does it fix the issues?
Old 09-24-2014, 11:29 AM   #181
gottattooz
gottattooz's Avatar
I haven't tried anything else with the wheels since getting the new spacers. The wheels are on hold because I can't afford new tires. The tire that are on the truck are fairly new and it seems wasteful to replace them before I need them.
I did, however upgrade the headlights. I bought H4 housings and LED bulbs. Man, what a difference. I have to wait until it gets dark before I can adjust them, but I love them already.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 09-24-2014, 02:38 PM   #182
BigDaddyV
BigDaddyV's Avatar
I've checked out your thread a few times and I do love the direction you have taken the truck. Eveything is starting to come together. Keep up the good work.
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase
1955 Chevy Stepside "Dudley"
My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288
1972 Chevy C10, Project "Chevro~Layed out" Nether Storm
Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523
BigDaddyV is offline   Reply With Quote
Old 09-24-2014, 04:17 PM   #183
bruceman1968
bruceman1968's Avatar
Truck looks Great! Love the taillights. Looks like the new headlights got rid of the yellow cast. They look Great. Nice and white/bright. Can't wait to see it in person. Nice work!
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 09-24-2014, 08:28 PM   #184
colgad
colgad's Avatar
How much were the led bulbs?
Old 09-24-2014, 09:48 PM   #185
gottattooz
gottattooz's Avatar
Housings were $40.00, LED bulbs were $65.00.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 11-13-2014, 09:36 PM   #186
gottattooz
gottattooz's Avatar
I've been working on my Tonneau cover for the Captain. It's been a week of building, but I wanted more pics to present for better footage. Using 2 inch aluminum angle, 5 inch trailer railing which holds the side panels of dry box trailers for the cross braces. I used 2 inch angle for the frame and for the supports for the cross braces. I'm working on making a bracket to hold the lockable latch at the back of the cover. Once we figure out the latch bracket, we'll rivet the skin across the top and finish it off with "J" moulding on the edges. More pics to follow......
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 12-03-2014, 05:51 PM   #187
gottattooz
gottattooz's Avatar
With the Tonneau cover on hold, I decided to swap out my front turn signals. I has to trim the mount brackets to fit inside the grille shell. I also trimmed the excess that stuck out past the chrome trim rings.
Here's some before and after pics.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 12-03-2014, 05:53 PM   #188
gottattooz
gottattooz's Avatar
During and after pics.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 12-27-2014, 09:06 PM   #189
gottattooz
gottattooz's Avatar
I installed the power bucket seats and center console from a 99 Silverado I'm stripping for my 65 Buick Wagon.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 12-28-2014, 01:01 AM   #190
colgad
colgad's Avatar
Do you have more room with the new seats or less. I always thought these seats with the built in seat belts were the way to go.
Old 12-28-2014, 03:53 AM   #191
70LonghornCST
Moderator
70LonghornCST's Avatar
Keep up the good work!
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 12-28-2014, 12:00 PM   #192
gottattooz
gottattooz's Avatar
I definitely have less room Dave. But the bench seat from the 65 wagon was killing my back. At least these have lumbar support and, as you mentioned, the built in seat belts. I'm very happy with the installation and overall fit. I definitely sit higher, and i have to squeeze my leg past the steering wheel to get in but once I'm in, it's fine.
I finally got tires for my factory 20 inch wheels. I hope i can get them mounted Wednesday so i can install them on the truck and post more pics.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 12-28-2014, 01:14 PM   #193
colgad
colgad's Avatar
-Josh
Are you home any this coming week? I may attempt to get the bed. I think we gave up on the whole swap cab idea. Oh what size tires did you end up with?
Old 12-28-2014, 04:50 PM   #194
gottattooz
gottattooz's Avatar
I know I'm of Wednesday, but that's going to be a crazy day. I might be off Thursday.
I went with 245/40r20 tires. Found some online for $85 each. With shipping, it was less than $400.00.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 12-31-2014, 07:05 PM   #195
gottattooz
gottattooz's Avatar
Ok, I finally got my tires mounted and balanced (245/40R20). Correct 2 inch spacer adapters push the wheel out into the center of the wheel well. Rims are 20x8.5 with 22mm offset. Total back spacing is 5 inches. I like the look of the front wheels in the fender. I think I need bigger tires in the rear next time. I"ll have to relocate my exhaust tips for that, but it'll do for now.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 01-01-2015, 09:55 AM   #196
colgad
colgad's Avatar
-Josh
Josh, I think I have 2 275x55x20's I took off my GMC Denali if you want to try them. There Goodyears. I just have to find them.
Old 01-01-2015, 12:16 PM   #197
bruceman1968
The Captain is looking good!
Old 01-01-2015, 12:35 PM   #198
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looking good bud
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 01-15-2015, 12:15 AM   #199
gottattooz
gottattooz's Avatar
Got some progress on the Tonneau cover today. Last week, Dad and I figured out how to mount the cover to the bed via hinges bolted into the front top rolled edge of the bed. Today, I mounted the rear "T" handle latch that locks the cover to the tail gate, Mounted the hood springs (1999 Chevy Silverado hiid springs) and attaching brackets. Now, I have to take the cover back off to have it skinned and install weatherstripping.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 01-15-2015, 09:34 AM   #200
colgad
colgad's Avatar
What a perfect use for the hood springs! Its looking great. How did you get the hings mounted on the rolled part of the bed? I couldn't tell in the pics
