Buddy Bucket Console/Center Seat Dimensions
Can any of you buddy bucket owners out there take some measurements for me?
I wanted to see if I could get the dimensions of the "box" (length, width, height) including the dimension from the bottom to the centerline of the hinge. Also, the thickness of the material it is made of. Also the dimensions of the seat and backrest. Same thing; length, width, and height. Thanks in advance for any help!
Super Blue - 1968 C-10 Short Stepside
Fastburn 385, 4-Speed Sag. on the Column, Coleman 9" Floater w/Detroit TrueTrac |
Re: Buddy Bucket Console/Center Seat Dimensions
Can somebody help this fellow out??
I'll try to get some measurements and pics tomorrow if no one else beats me to it. Nate
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers |
Thanks guys, I appreciate it!
Let me know if this helps, I don't know how to make the dimensions on the photos. 16 gauge .0625 thickness All measurements are from inside of bends. Inside dimension is 12 5/8" wide and 16 5/8" long. The sides and front are 3 5/8" deep and the rear is 7 3/4" deep. The return lip on the sides and front are 7/16" The front corner angles are 15/16" x 15/16" x 3 5/8" high. The rear Z support is 9/16" x 7/8" x 15/16" x 7 3/4" high.
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers Last edited by nds1968; 11-16-2012 at 08:44 PM. |
Hinge width measurements. 1 7/8"--1 3/16"--5 1/4"--1 3/16"--1 7/8"
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers Last edited by nds1968; 11-16-2012 at 08:49 PM. |
The outside diameter of the hinge is 3/8" The center hinge bracket bolted to the seat measures 5 1/4" wide by 4 3/16" from center of hinge with a 1 1/2" return that has the screws.
Hope this helps and not confuses you
That's AWESOME Nate, thanks a ton! Could I ask another favor, and get you to measure the seat and back pads? Then I should have everything I need.
Thanks again! Posted via Mobile Device
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Did you ever get the remaining dimensions you needed?
Moderator
![]() Join Date: May 2007
14 5/8" wide.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Moderator
17 3/4" long.
Moderator
The top cushion appears to be 14 5/8" square
Thank you
#15 |
![]() Join Date: Aug 2005
Getting ready to take a Slosh Tub buddy bucket console to the upholstery shop. Any chance anyone can post the thickness of the seat bun and armrest portions as my upholster will do the foam as well. Thanks, Chris
