#526 |
Re: Porterbuilt Dropmember
Mine looked the same way. Trans crossmember was at the top portion of the frame. I also have the body drop so I had to rework the trans tunnel and back part of the floor. I still need to get a driveline. I imagine that Dave or Nate will get back in touch with you on Monday. I know they have been extremely slammed with business. Once you get it figured out please post up your outcome to resolve. Thanks
LIFTED OR LOW THE ONLY WAY TO GO!!!! Check out my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=517346 Projects 56 Chevy pickup Porterbuilt FR/RR dropmembers |
#527 |
![]() Join Date: Feb 2010
I most definitely will post what makes it all works. I'm confident new mounts will do the trick.
#528 |
Ok, I used the mounts sent with the dropmember. After reading the driveline guide from porterbuilt a few times it all started making sense. I'll admit in my mind it wasn't adding up but once I put it to paper it all worked out. After a trip to the metal yard for some odds and ends I started playing around adding different stock here and there. After a few hours working through the proper equation it all worked out and everyone lined up perfectly.
Here's what I have. Please excuse the crude drawing, I went through a stack of paper getting it right. Basicly I ended up putting a 2" spacer under the cpp transmission cross member. Added a 2 3/8 spacer under the carrier bearing and set the trailing arms in the second hole from the top. I hope it's right. Right now I'm using square tubing to space the trans and carrier. I'm gonna try to find someone to make me something a little nicer to use. |
#529 |
just want to post a few pics and get feedback? these pics are when aired out and the upper shock mounts where suggested to place. Against the original upper shock mount bump.
#530 |
Not to that part of my project yet, but almost looks like it could move fwd on the frame a little more... Im sure more peeps that have done this already will pipe in. looking good though!
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase 1955 Chevy Stepside "Dudley" My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288 1972 Chevy C10, Project "Chevro~Layed out" Nether Storm Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523 |
#531 | |
I sent an email this morning offering this information, however failed to realize that the bump in the frame where the original shock stud is located will stop the bracket. On occasion we find some pretty big tolerance differences from frame to frame on these trucks. This might be what we are running into. Do me a favor and send me a new email at tech@pbfab.com and we will see if we can't figure out a solution that gets the angle more desirable without cutting or redrilling on your freshly painted frame. I would like to see the angle a little better than what you're showing. Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#532 | |
Again thank you for your great customer service. |
#533 |
JRods Garage
Ok, Im having trouble, hopefully someone can help!!!
I have an "extreme" DM and installing an LS/4L60E combo. I am installing it with the cab on, front clip off. Im having interference issues with both the cylinder heads hitting the firewall, and the trans hitting the pinch welds in the tunnel. Anyone have some insight into what might be my problem??? |
#534 |
Do you have any pictures? Are you running a high hump trans tunnel?
-Rus |
#535 |
JRods Garage
I dont, but I can get them... Im running just the standard trans tunnel. Am I going to need the high hump??
#536 |
Yes. The high hump is a must with a dropmember/Ls combo. As far as your heads hitting the firewall we will need to see pics. I have a 6.0 in my dually with the extreme dropmember and I ordered engine mounts from Nate that were shorter. You may need those too.
-Rus |
#537 |
JRods Garage
Here are the pics of what im running into...
Trans to pinch welds ![]() LH side. I got 1 bolt in, this is how the rest line up ![]() ![]() LH rear head to firewall ![]() RH rear head to firewall ![]() Engine mount height ![]() I dont think that a high hump would really resolve this issue, but then again, I wasnt expecting this bad of fitment |
#538 | |
JRods Garage
Overall, Im pretty much regretting this purchase :/ |
#539 | |
Shoot me an email tech@pbfab.com and we can discuss an easy solution to take care of the motor to firewall clearance. In regards to the large hump, I apologize if you feel that it wasn't properly communicated to you. It's all over our instructions, website, and every build thread on the forum. Nate
#540 |
I'm just glad to be here!
From looking at your pictures, NIBS, it looks like if you get the high hump trans tunnel, your firewall issues should go away. It looks to me if you get the trans to move up higher, the cylinder heads will move AWAY from the firewall.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#541 | |
JRods Garage
Thanks for the help again Nate! You are a stand-up business owner, you will continue to receive my business |
#542 |
I wanted a PB front end in the worst way, and I ordered the parts, but after 8+ weeks and no parts, I gotta go elsewhere.
#543 |
A day late and $1 short...
Yep, it does take a while for your kit to be built, but the quality and performance are worth it. No worries though, if you must step out of line another guy will get his kit sooner. No harm no foul. If I were in your shoes... Oh wait I have been (mild front and rear w/coilovers)... I'd talk with the folks at PBFab moving up the chain until you get a satisfactory outcome. Just my 2¢. No matter how you proceed, good luck with your build.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
#544 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Well worth the wait. I'm sure there are other things you can be doing on your build. Its all in the planning when you order Porterbuilt products. They are SUPER busy for a reason. QUALITY products.
#545 |
![]() Join Date: Apr 2007
Nibs ,can u tell me what pan that is ......looks deeper in the front than the f-body pan...and unless Nate has changed his format u will need that xtra clearance over the rack....It looks way high now and that's what has me puzzled.....maybe because you've got the tailshaft way low because of hump...anyway when u get rear up and lower brackets pay close attention to the area above rack.......been there........jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 |
#546 | |
TNT-MOTORSPORTS
If for some reason you dont get something figured out give me a call at 918-845-1935 . |
#547 |
Squarebody guy
Picked up my PB stuff today, haven't even had time to un-box anything but definitely worth the wait. Waited just over 10 weeks but I had C30 parts with extras.
#548 |
![]() Join Date: Dec 2006
Keith nailed it on the head. I knew going in I was going to have to wait but wasn't a big deal because I had plenty of other stuff to work on with my truck. Porterbuilt is worth the wait as the products are super nice and high quality.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#549 |
In 25 years of ordering parts by mail order, PBFAB and Nate are by far hands down the best company I've ever dealt with.
I think every person building a Porterbuilt truck has run into a problem or two, given the different variables in the process, (different motors, trans, brakes, wheels). However, Nate is the only person I can send a text to at 8pm on a Sunday night regarding a problem I was encountering and get a response to address the issue.
///Relaxed Atmosphere |
#550 |
![]() Join Date: Jun 2006
Every piece of my PBFAB extreme dropmember suspenision with inner frame stiffener is top notch quality I waited about 12 weeks and Nates customer service is second to none.
