Old 09-04-2014, 01:21 PM   #1
Doobie1
re power steering for a 69 gmc
Hi all
I am in the process of swapping/building my truck , i have a ls3 and a 6 sp from a 2010 ss camaro that are going in. My truck has a manual steering gear that has to go, what are my options? I found a stock replacement power box and a kit form summit racing 'SUM-G3160" that i think will let me hook up the new style gm power steering/hoses pump to the old style power box, any tips would be greatly appreciated, thanks sean
Doobie1 is offline   Reply With Quote
Old 09-05-2014, 09:01 AM   #2
Xeen
Xeen's Avatar
Re: re power steering for a 69 gmc
Since you don't currently have a power steering box you can use the truck one from like 1979-87 that already has the 0-ring style hoses and you won't have to adapt anything.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 09-05-2014, 11:30 AM   #3
Doobie1
Do any early c10 in the 80" s 2 wd will work?
So for example, if I order a power box for
A 84 2wd pickup, it will bolt on and work?
Old 09-05-2014, 11:49 AM   #4
Xeen
Xeen's Avatar
As far as I know it will bolt right up.
I have a 1970 power steering box on mine and I had to adapt it from Flare to O-ring which was super easy, but the 1979-87 power steering box is O-ring style so it should bolt right up.
