09-02-2014, 08:02 PM | #1101 |
Re: What did you do to your truck today? Chapter II
Out with the low and in with the high..about 40 minutes.
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother |
09-03-2014, 11:07 AM | #1102 |
Carpet and kick panels finally going in!
1970 Chevy swb, project UGHH! 1987 Grand National http://s168.photobucket.com/albums/u.../1970%20Chevy/ |
09-04-2014, 06:41 PM | #1103 |
Tommy @ Tnt Motorsports put new wheels and tires on the beast. (bad cell phone picture) Thanks Tommy!
-Jason USN Retired |
09-04-2014, 10:12 PM | #1104 |
Installed procharger bracket and P1SC head unit.On my 71 shortbed
1971 c10 custom deluxe fleetside swb LS3 w/BTR stage IV cam,4L85E w/3600 stall 67-72chevytrucks.com/vboard/showthread.php?t=558024 |
09-04-2014, 11:59 PM | #1105 |
I started my project to cover the radiator to grill gap. Started with a nice radiator given to me by a fellow member here. I've test fitted it so far. There are gap panels on the way. along with silver powdercoated hood latch and radiator upper brackets.
Before: Test Fit:
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
09-05-2014, 08:53 AM | #1106 |
Looks like your running a GM serpentine drive setup? Is that a pro charger kit? If so it it pretty complete?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
09-05-2014, 03:10 PM | #1107 |
Yeah Lee its a 88-92 Iroc/Firebird bracket for passenger side and 90-95 gm truck bracket driver side.I would of used Truck bracket for whole setup but would not work with intake tensioner was in front of throttle body.I had to space out driver side bracket 1/2" inch.I did it this way because I wanted to run a single belt and procharger kit for Iroc serpentine setup runs its own belt and is a lot more money.If you want to see more pics let me know,now I am trying to find belt to fit its around 112"inch belt.
Brian
09-05-2014, 05:09 PM | #1108 |
Thanks Brian, I'm running the truck setup on mine. One of the best mods I've done. Which procharger kit are you using!
09-05-2014, 06:01 PM | #1109 |
Lee this is the kit I'm using 90-95 chevy truck bracket kit.I already had procharger and pulley.
I also am going to run a intercooler. Brian
09-06-2014, 07:46 PM | #1110 |
RAT1968 '68 Cab/'71 Parts
Small local show. Rat was there. But not too many truck lovers.
Fancy tri-five stepper was the big hit. Fun day, though.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
09-06-2014, 08:14 PM | #1111 |
Straightened out the front bumper a little bit and through some paint on it. Also repainted the gmc on the grille. The bumper and grille still needs some work but looks better then it did.
09-07-2014, 02:59 AM | #1112 |
What's crackin'? Today? Well, lets see…
This wasn't actually "today" but on August 21st I hit 41,000.0 on the big girls tire turn counter. And it's not yet a rolled over specimen. "As The Odometer Turns" (At About 20MPH) Then on August 22nd I scored some JB8 dually brake parts and wheels. I got 2 serviceable 3-1/2" 14BFF rear brake drums, 2 Complete front spindles with serviceable rotors and calipers, a hydraulic brake booster with a truck firewall bracket, a proportioning valve and 3 good steel dually wheels to go with my 4 Alcoa's. All this stuff came from a 1988 "R" series C3500 I found on CL. After a 100 mile round trip I thought it was a pretty good deal for $120.00. A Pick-A-Part yard would have been double that. So including the petrol I figure I saved about $70.00 over the junk yard prices. CL is the trucks and my friend. A Little Bit Of Parts Grab In My Life During the afternoon of Aug 25th the postman didn't ring twice but he did leave my registration tags for my approved YOM plates from the DMV. These plates were once on my step fathers truck, he kept them for man cave wall art when his truck spun out and slammed broadside into the center divider on the freeway in 1986. The accident totaled the truck but didn't damage the plates so now their on my truck. The only thing better is if they read 71 402 G Then it would match the year as well as the engine and color. Oh well, still is slick to have them on the truck, I really like 'em, their a nice tribute and a big shout out for the man who was my male bonding mentor when I was growing up from a little 3 year old tyke. Now Y'all Know It's Got To Be A 402 Rat Motor, Right? But Really, What Year Is It Again? There Are Three Clues Present In The Picture Of This Original Truck. Can You Spot Them? Quite by surprise on August 28th I scored even more JB8 dually brake parts. This time around I got the upper control arms, spindles, calipers, rotors, hydraulic brake booster, rear drums, rear backing plates, proportioning valve, master cylinder, JB8 (2 fluid return inlet tubes) power steering pump with BB brackets, 7 wheels with 1 brand spankin' new tire and 6 great tires, a factory GM 40 gallon side fill fuel tank with sending unit that fits between the trucks frame rails (exactly what I wanted), the tank hangers, a 454BB fan with cooling fan clutch, a single wire 60 amp alternator and a set of 14BFF axles and hubs. These all came from a 1984 P30 based, 10,000lb. GVW MHC with 86,000 miles. Everything appears in real good condition. The fuel tank is clean as a whistle inside and the master cylinder and calipers have reman stamps. Now I've got some extra parts I may need to find either a new box or dually for. An Even Bigger Parts Score. Bigger Is Better Right? The Upper Control Arms, 14BFF Axles, 14BFF Hubs And The JB8 Prop Valve Were All AWOL For The Photo Shoot. They Are Now All Present And Accounted For! This deal cost me, well… um, let's see... I gave the legal owners agent… $100, then his boss (another of the legal owners agents) gave me... $100… and I got... 7 wheels with tires times… that plus… more accounting jargon… plus… multiply by... minus fuel expense... divide that by... carry the denominator... equals… are you ready… wait for it… yep… that's right… a… big… whopping… ZERO pennies… it was ALL free! Yes!!! It's true!!! It was all… F-R-E-E ! ! ! Wow, an even better deal than the week before. But not only were the parts all free for the taking, this vehicle was actually abandoned property carefully hidden behind the foreclosed house directly across the street from mine! I could literally catch a faint narrow glimpse of the vehicles corner across the street over the top of my trucks stake side gates and thru the wind swept overgrown vegetation behind the houses chain-link fence gate while literally sitting on my front porch. My step fathers high power binoculars definitely enabled a clearer view. I'm so fortunate the legal owner wanted that monster off the property instead of in their own personal dilapidated car collection and as such first allowed me to take what I wanted. A big thank you is in order to the former property owner Juan who abandoned it there in the first place. It was missing the top end of the engine and didn't run. I think it was too big for Juan and his displaced housemate boarders to carry off the property before the foreclosures July 2nd abandoned property forfeiture deadline. With desirable needed parts so close to home and up for a free-for-all grab fest I was flabbergasted… not to mention hungry (I actually responded more like I was starving!). That day was truly a Motor City Madhouse. So yep with no petroleum expenditure, defiantly a great deal and well within my meager budget. The Backyard Brake Bonanza Blues, Part Deax, The Aftermath!!! Featuring "A Big Ole Tree Stump" In The Best Supporting Arbor Category. Ladies and Gentlemen, We Have A Winner. And The Oscar Goes To... Well… since this "is" the what did you do "today" thread I better get to that! Well… I walked by the truck a few times, I stared at and admired the truck while sitting on the front porch a few times (no, I didn't use the binoculars), I posted in this forum about it a few times and then I finally went out and between green and red traffic signals dodged a few caravans of cars on my busy street as I took twilight time pictures of the big lady to post on this here wonderful topic. What I Actually Did "Today"? Does It Really Qualify For The Topic? Or Is It Just Another Thinly Veiled Blatant Attempt To Post More Pictures Of My Currently Big "Dirty" Girl? You Be The Judge! Ssssh, between you and me, I just wanted to babble some more on the forum. But please, don't tell the moderators, some of them admit they got mean nasty FANGS! Thanks everybody for reading my ramblings and making this here forum what it is. Lots of great work in here and some wonderful ideas in this topic alone. Please be well. Cheers
1971 Chevy C30 Custom Camper Cab Chassis Dually 402 TH400 4.10:1 Eaton HO72 1969 Ford Mustang "Mach 1" 428CJ 4 speed "R Code" 1970 Mercury Cougar "Eliminator" 351C-4V C6 1972 Ford Ranchero GT 351C-2V C6 1974 Honda XL-350 Member of the "6 C's and a D" 1-Ton Fun Club! Last edited by 71Dually; 09-07-2014 at 03:11 AM. |
09-07-2014, 09:56 PM | #1113 |
Put some new shoes one my 67 today. It's crazy the difference wheels and tires make.
Here's some before and after pics. |
09-07-2014, 10:07 PM | #1114 |
09-07-2014, 10:12 PM | #1115 |
There it is brother.
09-07-2014, 10:48 PM | #1116 |
09-07-2014, 11:53 PM | #1117 |
Ya those emblems came on it stock. It came stock with a 305 v6 also.
09-08-2014, 11:37 PM | #1118 |
Finally got some wheels and tires!
70 SWB 454/TH400 |
09-09-2014, 04:06 AM | #1119 |
Took off some old primer and brought back what was left of the original paint..gonna give the whole truck a patina look
09-09-2014, 06:58 AM | #1120 |
Looks really good! Nice stance. .....what did your old ones look like?
1970 C10 Short Stepper with 71/72 front clip. |
09-09-2014, 10:17 PM | #1121 |
Rebuilding my kick panel vents. Soaked them overnight in Evapo Rust...I'm in love with this stuff. Removed all the rust and most of the paint. Evapo Rust is so awesome. Also cleaned up the single pulley I plan on selling just for grins...even removed the grease.
Ready for some paint and then I have to figure out how they go back together
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
09-09-2014, 10:25 PM | #1122 |
FYI if anyone plans on buying the gasket material between the vents you can get it at a local art supply store. They call them "foamies" and sell for 45 cents a sheet, they even have different colors. Same stuff you ...I paid $5.00 bucks for in the parts catalogs.
09-09-2014, 10:37 PM | #1123 |
Thanks. It's been a long time coming. They were just old steel wheels for rolling it around.
70 SWB 454/TH400 |
09-12-2014, 08:45 PM | #1124 |
Installed rad support,rad,shroud,and wiring harness. Next is my tranny lines and cooler..
09-13-2014, 10:38 PM | #1125 |
Old member
Finally got the new LS engine cover installed. I think I may need to clean up the weld a little though but I don't want to make it weak either.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
