01-12-2014, 12:59 PM | #126 |
Re: 1970 swb c-10
Great build! You got a ton of work done in a very short time, I'm jealous of how fast you got it done and how great it looks. Hope mine turns out as good. The comments from the kids at the car show I am sure just like a lot of kids they say stupid things without any concern of what it means to someone else. (I know when I was a kid I said a lot of stupid things) I like the line-ex floor at least you can use it for a truck if you need to without feeling guilty about scratching something you put so much work into. Hope to see it at a show sometime soon, hopefully I'll have my truck there so people can nit pick it, because at least that means it's done.
01-26-2014, 11:14 PM | #127 |
Re: 1970 swb c-10
Great build, truck came out beautiful. It is really inspiring to see somebody else who has never painted before pick up a paint gun and do that good of a job. Gives me hope for mine.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
01-27-2014, 07:35 PM | #128 |
Still Learning
Re: 1970 swb c-10
Awesome truck! You made this build look too easy. Love it
01-28-2014, 12:08 PM | #129 | |
Re: 1970 swb c-10
However, there were times that I thought I would probably die holding a dura-block Thank you very much! I'm very proud of the fact that I built this truck from top to bottom. The only things I paid someone to do were, rebuild the trans, and put the seat cover on.
1970 SWB Build |
01-28-2014, 12:25 PM | #130 |
Still Learning
Re: 1970 swb c-10
That's my thinking too. I am doing everything I can possibly do on mine. It's a PITA but I think it will be worth it in the end.
01-28-2014, 12:27 PM | #131 |
Re: 1970 swb c-10
here here. Well said!
03-27-2014, 08:27 AM | #132 |
Re: 1970 swb c-10
Wow! Great job. You build one of these to please yourself and your family, but it is nice to be complimented by someone outside of your immediate circle. I have learned to ignore the comments that used to bother me and only remember the ones that have appreciation for all the hard work and passion that I have for my trucks. Don't stop taking your truck to shows as the one person that sees it and has a fond memory of something in their past was worth it. Your truck is a work of art!
09-14-2014, 10:19 AM | #133 |
Re: 1970 swb c-10
Getting ready to make some changes and improvements over the next few months. I'm going to address the engine bay ( I was never satisfied with how it looked) And put a new engine in it. Just cant decide if I want a crate, or build my own. There will also be a few other small changes. Anyway, here are some pics.
1970 SWB Build |
09-15-2014, 10:55 AM | #134 |
Re: 1970 swb c-10
The first thing I'm doing while the motor is out, is cleaning up the firewall and painting it gold. While I've got all of this apart, I figured it was a good time to upgrade to a tilt column. I bought this one several months ago. It was already in great shape, but I cleaned it up and put new bearings in it. I switched my steering wheel over to the tilt column and got it ready to go in after the paint work is done.
1970 SWB Build |
09-15-2014, 10:59 AM | #135 |
Re: 1970 swb c-10
Nice plan. Making an already nice truck just that much better. It's going to look great with the gold firewall.
09-15-2014, 11:59 AM | #136 |
Re: 1970 swb c-10
Thanks. It's funny how this all started because the heater core started leaking! Then I got the dreaded "while that's apart I might as well..." disease.
1970 SWB Build |
09-24-2014, 03:48 PM | #137 |
Re: 1970 swb c-10
Well, the firewall is done and the front end is back together. While it was apart, I painted the inners and other black pieces with Eastwood under hood black. When I went through everything the first time I put new p.s. hoses on that I got from LMC. They were already starting to dry rot after about 1.5 years. So I ordered some stainless ones from member PICKMUP. They are much better and made in the U.S. I also got the tilt column in. So far i'm very happy with how the new engine bay is going to look. I think I am going to really like having a tilt also. Here's a few pics from today.
1970 SWB Build |
09-24-2014, 04:06 PM | #138 |
Still Learning
Re: 1970 swb c-10
Engine bay looks brand spankin new! Very nice
I love the new steering wheel too. |
09-24-2014, 04:24 PM | #139 |
Re: 1970 swb c-10
Congrats! Beautiful work.
09-25-2014, 08:20 AM | #140 |
Re: 1970 swb c-10
Nice job on the engine bay, looks really good
10-01-2014, 04:14 PM | #141 | |
Re: 1970 swb c-10
Thank you Chris! Thanks Keith. It would look a lot better with an engine in there again so I could drive it again. I've been going crazy without it
1970 SWB Build |
10-15-2014, 07:39 AM | #142 |
Re: 1970 swb c-10
Very Nice Build!!
12-23-2014, 02:03 AM | #143 |
Re: 1970 swb c-10
Finally got a motor put in and running again. Its a fresh 350 that is pretty mild. It was a motor that was originally intended for my CJ7. I decided to put this one in and see how I liked more of a stock setup. I was starting to get tired of the big cam, gear drive, high stall thing. Anyway, I still need to do a bit of tuning after I swap out the distributor once the new one comes in. Then I can put the hood back on and move on to the other small plans I have before spring.
1970 SWB Build |
12-23-2014, 02:09 AM | #144 |
Re: 1970 swb c-10
Looks like the pics off my phone came over sideways But you can get the idea. I'll get some better ones that wont leave you in a neck brace after I do the distributor swap and do a good detailing.
1970 SWB Build Last edited by jmking9; 12-23-2014 at 11:02 AM. |
12-23-2014, 08:33 AM | #145 |
67-72 parts collector,…
Re: 1970 swb c-10
Your engine bay looks a 1000 times better!
Everything you did is perfect!!!
12-23-2014, 09:16 AM | #146 |
Re: 1970 swb c-10
12-23-2014, 10:35 AM | #147 |
Re: 1970 swb c-10
Thanks Chris!
1970 SWB Build |
12-23-2014, 10:38 AM | #148 |
Re: 1970 swb c-10
No problem. I wanted to see 'em but was too lazy to lean my head over.
Looking good! |
12-23-2014, 11:00 AM | #149 |
Re: 1970 swb c-10
Thanks Keith! I appreciate the compliment coming from someone as knowledgeable about these trucks as you. It came out really close to the way I had it pictured in my mind. This "look" is my favorite on any old truck or muscle car. I considered an LS swap, but just couldn't make myself do it. I love old cars and trucks for two reasons: style, and simplicity. I'm not knocking anyone for doing an LS swap, they are GREAT engines. But for me, a nice clean, uncluttered small or big block engine bay is hard to beat.
1970 SWB Build |
01-27-2015, 08:51 PM | #150 |
Re: 1970 swb c-10
We've had some really nice weather here the last few days. I've had the chance to go for a few drives and put some miles on the new engine. My wife and son went with me for a ride this evening. I took a couple pictures in the driveway after we got home.
1970 SWB Build |
