Old 09-15-2014, 04:29 PM   #1
backwoodsK20
backwoodsK20's Avatar
Need some direction for a '68 K20 build
I bought a 68 Chevy K20, 292/SM420/Rockwell transfer case. Truck runs and drives but is mechanically rough. I got a '79 K20 for parts, which i'll be using the diffs from to transfer to the '68. Here's my plan, any advice on the flaws would be appreciated.
-Remove springs and diffs from parts truck, including mounting shackles, and make them fit on the '68 (frames are the same width so why not, the original '68 springs are cracked anyway).
-Parts truck suspension has a 3" block in the rear, none up front. Is it a good idea to add maybe a 2" block to the front?
-I bought a pair of 36" Swampers on 16x8" chevy aluminums. with the mild block lift, would these fit? Rims have 0 offset. Would I need spacers for the front to allow clearance for steering? are spacers even a good idea?
-Lastly I decided to swap the front clip over to the '70 style.
-Truck needs all new brake system, I picked up a master cylinder and booster from an '86 chevy. brake lines will have to be brand new.
The goal of this project was the to make it an inexpensive build, but at the same time I don't want to take shortcuts that would compromise safety while driving. Truck on top is what I have now. The pic below is what I want it to look like.
backwoodsK20 is offline   Reply With Quote
Old 09-17-2014, 03:34 PM   #2
72 Copper C-10
72 Copper C-10's Avatar
Re: Need some direction for a '68 K20 build
I think it would be cool idea. From what I understand 68 k20s are pretty rare, especially in decent condition. If it was my truck I would keep it factory and numbers matching as possible. If you were going to continue with your plan I would keep all of the parts you take off, and don't change or modify anything thats hard to undo. in the end its your truck, so have fun with it!
72 Copper C-10 is offline   Reply With Quote
Old 09-17-2014, 11:34 PM   #3
andrewmp6
You never use a lift block in the front and in the back they are not really the best thing to use for a lift.
Old 09-18-2014, 12:23 AM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
x2 on never, ever using lift blocks in the front. If it needs lifted, it needs to have lift springs. Not so critical on the rear springs, plenty of guys run blocks. Probably a good idea to use your donor axles, it's a good way to get front discs. As to the '69-'70 style front clip, it's your truck and it's a matter of taste, but a lot of us think the '67-'68 style is the best-looking ever made. So you're keeping the 292? I like that -- it's plenty torquey from what I hear, plus it's the stock setup and there's probably not a lot of them around since so many were changed to a V8.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 09-18-2014, 07:39 AM   #5
Your41Plague12
Your41Plague12's Avatar
X2 on keeping the 68 front clip. That's a really sharp looking truck! I'm all for swapping the axles and springs though, that's a good upgrade. I'd keep the stock ones though, for selling purposes down the road. Other than that, a small block in the rear is fine. Any more than a 4" block in the rear might be questionable though, due to excessive axle wrap. Never use a block in the front either.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 09-18-2014, 09:11 AM   #6
72 Copper C-10
I agree with everyone about the lift springs, you shouldn't use a block. Check out Offroad design they have awesome front spring set ups, they might be alittle more money wise but its definitely worth it
Old 09-19-2014, 02:43 AM   #7
andrewmp6
With the truck as old as it is i would think hard on lift springs front and back.The rear springs are probably factory and sagged over the years.So if you put 3 inch lift springs in the front even with a 3 inch block in the rear it will sit front end higher probably.Which front clip to use is up to you,I would leave it alone or maybe go gmc and get the quad head lights to be different.
Old 09-21-2014, 02:21 AM   #8
Spartan
Spartan's Avatar
I would keep it as stock as possible. If you want a lifted 4x4 go with a 72. I see too many butchered 67's and 68's.
That's my opinion but it is your truck to do what you will with and since I value choice I say follow your vision.
'69 K20 350/4 speed/Rockwell/D44/HO52.
"orange rhymes with door hinge"
Spartan is offline   Reply With Quote
Old 09-21-2014, 03:26 AM   #9
argonaut
argonaut's Avatar
in my opinion the 67-68 front end looks WAAAAAAAAAAY better than the cheesy plastic 71-72 stuff. but as others have said, to each his own.
As far as the suspension, you can adapt the later model stuff without too much difficulty. I'd say with a 4" lift you could fit thin 36" tires in there.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 09-21-2014, 09:14 PM   #10
duallyjams
duallyjams's Avatar
X2
and never use blocks on the front
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 09-22-2014, 11:51 PM   #11
CanadianK10
Active Member
CanadianK10's Avatar
Welcome from Southern Ontario
Nice truck, heres my 67 K10 with the same powertrain, got it back a couple weeks ago from paint and have been having a great time with it. Put about 500 miles on it since I got it back.
I may do a smaller lift on mine down the road as well
- Adam
1967 K10 292, SM65 Transmission & NP205 Transfer Case
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=605048
CanadianK10 is offline   Reply With Quote
Old 09-23-2014, 08:36 AM   #12
backwoodsK20
Thanks for all the opinions; the tires i have are 36x12.5/16 swampers. Ill just have to see how they fit and if no good ill go down to thinner 35's. Yes i will be keeping the 292 under the hood, and im keeping everything original to the truck except the springs. The rear springs are literally split in two and held together by the u-bolts. Unfortunately the box is shot (the pic is decieving) but its getting a clean donor box from another '68.
Old 09-23-2014, 08:24 PM   #13
sboris
sboris's Avatar
IMO the 68 clip rocks!( But the 70 would look great too). That pic you have of the 70 looks to be at least a 6 inch. Just wanted to show you a 4 inch with 315/75r/16, close to 35s I think on 10" wheels. When flexing in a turn, I get a SLIGHT rub on the bottom front corner (front fender). These are wider than yours I'm sure, but maybe a little reference point for ya.
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 09-23-2014, 08:36 PM   #14
backwoodsK20
That looks awesome! Where did you get those rims?! I need a set
Old 09-23-2014, 08:49 PM   #15
sboris
sboris's Avatar
Thx. Ordered them through summit. They are wheel vintiques brand..
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
My build.
Old 09-28-2014, 04:40 AM   #16
Gobuffalo
Gobuffalo's Avatar
X2 on Off Road Designe they have a lot of good suspension upgrade parts for your truck. I used their shackle flip kit on my 70 suburban. It's good for 4" of lift on a stock spring. I added a 2" lift spring for a total of 6" of lift.
Gobuffalo is offline   Reply With Quote
Old 02-21-2015, 03:11 PM   #17
El Dorado Jim
Beautiful truck!
El Dorado Jim is offline   Reply With Quote
Old 02-21-2015, 03:34 PM   #18
coopdog
coopdog's Avatar
i put a 4 inch lift aswell, its the perfect hight, alot of people tell me it looks stock
.................._____
__________//___{\____
/__---____//____/__---/
.....(O). ..................(O).
BUILD THREAD K20 http://67-72chevytrucks.com/vboard/s...d.php?t=651601 pages 2-4
coopdog is offline   Reply With Quote
Old 02-21-2015, 03:38 PM   #19
Bladeboy1998
I'm actually kinda glad this thread got brought back up, this is the same route I want to go when I do my build. If you don't mind me asking, about how much did all this cost, and about how much time did all the swapping take?
Bladeboy1998 is offline   Reply With Quote
Old 02-21-2015, 04:01 PM   #20
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Coop, that is a drop-dead gorgeous truck.... but there's no way it looks stock. People telling you that just don't remember what stock looked like. Now some of the old 3/4T 4x4 Fords often rode at about that height...
- Mike -
RIP El Jay
Old 02-21-2015, 04:35 PM   #21
coopdog
coopdog's Avatar
Thanks man, ya people that say it looks stock must have just throught the 3/4 4x4 chevys of the seventys sat really high like the 70s Ford highboys. In this pic you can see the height better
