Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-24-2014, 05:40 PM   #1
68racer
Yeah baby!
68racer's Avatar
Trans Shield?
Can you fit a trans shield to a TH400 while it is in the truck? It's a 1968 low hump. I'd prefer a shield over a blanket due to heat on the street.
11.37 @116
68racer is offline   Reply With Quote
Old 09-24-2014, 06:51 PM   #2
PGSigns
PGSigns's Avatar
Re: Trans Shield?
Will depend on the shield and the height of the trans. Some fit closer than others. You may be able to drop the cross member and slide it up from the back. Do you know how much room you have between the trans and the floor?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-24-2014, 06:58 PM   #3
71Dragtruck
71Dragtruck's Avatar
Re: Trans Shield?
Not sure about a TH400, but I had to lower my TH350 on the back to do mine the time it was in the truck still, also low hump.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 09-25-2014, 12:23 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Trans Shield?
With my 4l80e, I think a blanket would fit since it can hug the irregular shape, but I don't think the shield would fit just based on eyeing it.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-25-2014, 05:01 PM   #5
68racer
Yeah baby!
68racer's Avatar
Re: Trans Shield?
I've not measured it yet but I like the look of this one:
http://www.hughesperformance.com/pdfs/hp9800.pdf
11.37 @116
Old 09-25-2014, 09:54 PM   #6
71Dragtruck
Re: Trans Shield?
I run a TCI, pretty much the same as that Hughes.
Sponsored by:
Hard Candy Customs
Old 09-26-2014, 08:24 AM   #7
regan wilson
regan wilson's Avatar
Re: Trans Shield?
I don't have a stock tunnel but I have slid mine on from the rear.
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 09-26-2014, 05:47 PM   #8
68racer
Yeah baby!
68racer's Avatar
Re: Trans Shield?
There is about an inch and a quarter between the floor and the trans. How much space do I need?
11.37 @116
Old 10-02-2014, 02:40 PM   #9
vin63
It's Better With Nitro
vin63's Avatar
Re: Trans Shield?
I've never been able to install a trans shield without either dropping the trans down, or have a full access removable trans tunnel. I install trans blankets routinely for customers without removing the transmission. I just need to make sure I can access the top two trans/engine block bolts to secure the tabs.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
