#1151 |
Re: What did you do to your truck today? Chapter II
Had my inline 6 resealed, cleaned and painted and then I added the decals for that clean from factory look..I'm happy with the results..
Before and After.
_____________________________________ Dennis 1969 C10 250 w/3 on the tree - project/weekend warrior ![]() 2010 Subaru Impreza - daily driver |
#1152 |
![]() Join Date: May 2012
#1153 |
Drastic differance. In like it. Nothing like a clean motor in the bay.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
#1154 |
Engine looks really good!
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
#1155 |
Installed new green glass, weather-stripping and rebuilt vent window on passenger side. My stainless trim was in good enough shape for a daily driver.
Now I see why people buy new ones or get rebuilt from RogerKoop. They were a PITA but turned out nyce. One more to go.
#1156 |
![]() Join Date: Oct 2013
Found out had a vacuum leak, and it wasnt brake booster or pcv... P.O.E. determined intake was at fault. Pulled it and this is what I found... Its funny how the saying "hindsight is 20/20." Rings so true. I'm new to everything as far as putting together an engine goes.the gasket did last a month I must say. I have since learned the correct way of installing an intake on a rebuilt motor. And now am pulling a steady 19.5hg straight from intake.
1972 C/10 LWB - Mine 1964 C/10 LWB - My Dad's Instagram: Mike_The_Grad |
#1157 |
Finshed installing Vintage Air Sure Fit A/C system, new 4 core radiator, new March pulleys and 100 amp alternator. Get the A/C charged up next week.
1970 C10 Short Stepper with 71/72 front clip. |
#1158 | |
"Now all I need is a shop to go with my shop vac!" ![]() |
#1159 |
I showed it off today to a contractor who needed to store some tools in my garage. He was immediately impressed with it, even though it's up on blocks! That might help motivate me to get back on it as soon as I have the time.
#1160 | |
It's also in my build thread.
1969 ![]() 2015 GMC 2500 Duramax (Daily Driver) 1999 Jeep TJ 2010 Harley Street Glide Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981 |
#1161 |
![]() Join Date: Jun 2012
Changed the valve cover gaskets to felpro-1635 and Installed my Track-bar.
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker ![]() |
#1162 |
![]() Join Date: Feb 2011
Just ordered my new Hughes torque converter and Lokar kickdown cable and Lokar throttle bracket from Summit.
#1163 |
#1164 |
Installed a new servo piston sleeve and piston, plus got the valve body back in and tail shaft back on..
#1165 |
Old member
Well I got the brakes al swapped out. It didn't go as smooth as I had hope but I gotter done!
The original booster and master cylinder was all standard fittings, the new one was all metric fittings. Had to put new lines down to the a arm also. While I was doing it I went a head and swapped the rear rubber hose tee out for the stainless one I've had now for over a year. Everything is tight with no leaks so far. Going for a short ride and check everything again. Had to use the old valve since the brake switch wouldn't fit the new one. I may order one if I can find one. O-Reilly's didn't have it and couldn't order it. If anybody has a lead on one LMK. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 09-28-2014 at 05:51 PM. |
#1166 |
Old member
Here is a couple more of the S/S rear hose and Clear gear rear housing cover.I tie wrapped the hose away from the muffler also.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 09-28-2014 at 08:08 PM. |
#1167 |
[QUOTE=Andy4639;6859700]Well I got the brakes al swapped out. It didn't go as smooth as I had hope but I gotter done!
The original booster and master cylinder was all standard fittings, the new one was all metric fittings. Had to put new lines down to the a arm also. While I was doing it I went a head and swapped the rear rubber hose tee out for the stainless one I've had now for over a year. Everything is tight with no leaks so far. Going for a short ride and check everything again. Had to use the old valve since the brake switch wouldn't fit the new one. I may order one if I can find one. O-Reilly's didn't have it and couldn't order it. If anybody has a lead on one LMK. ![]() Very nice set up and nice and shinny.... |
#1168 |
I painted the rear bumper with Rust-Oleum® truck bed coating.
Before & after;
"Now all I need is a shop to go with my shop vac!" ![]() Last edited by texjake; 09-29-2014 at 02:01 AM. |
#1169 | |
Old member
[quote=ole dollor;6860125]
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#1170 |
Bought it drove to muffler shop then Drove it home.
#1171 |
![]() Join Date: Sep 2010
Got My Steering Wheel Yesterday... man this thing is NICE!!!!
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 |
#1172 |
![]() Join Date: Aug 2009
#1173 | |
noyce!!!!
#1174 |
Thank you..Today I pulled the side airbags out of my new seats and off to the auto upholsterer tomorrow..
#1175 |
I have been thinking of getting a Con2r wheel for my 56. keep me posted on how you like it! Looks great
----------------------------------------------------------- Erik My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626 1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647 RUST!? Thats just mother natures way of telling all of us.....MINE!!!! |
