10-13-2014, 10:44 PM | #1 |
help! truck making a ticking sound.
Hello my 72 chevy pickup is making a ticking sound while driving. The faster I go the faster the ticking sounds. When I'm parked I can barely hear it, even while I rev the motor. I think it's coming from my transmission which is a th350. Any suggestions would help, thanks.
10-13-2014, 11:44 PM | #2 |
Re: help! truck making a ticking sound.
Check U joints in your drive shaft.
10-13-2014, 11:52 PM | #3 |
20' Daredevil (Ret)
Welcome to the board!
If it's ticking when parked, it won't be u-joints. I'll guess either a collapsed hydraulic lifter, or an exhaust leak at or near the manifold. Could be transmission, I don't know. Another possibility is cracked flex plate. They'll sometimes crack between the bolt holes.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
10-14-2014, 12:36 AM | #4 |
could even be a rock in the tire
tubbed 1984 gmc jmmy http://67-72chevytrucks.com/vboard/s...d.php?t=639738 Alice Hombre http://67-72chevytrucks.com/vboard/s...d.php?t=808454 |
10-14-2014, 01:02 AM | #5 |
20' Daredevil (Ret)
But not if he hears it when parked...
10-14-2014, 01:13 AM | #6 |
Thanks guys, I'll definitely check and keep you posted!
10-14-2014, 02:45 AM | #7 |
Moderator
I was also thinking valves, lifters, or exhaust leak.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
10-14-2014, 09:27 AM | #8 |
Years ago I had a 350 that ticked. I poured in a bottle of Hyperlube and the tick went away. Its only about $12 bucks to find out. If it does fix the problem then you know its valve train related.
1971 Longbed BB Cheyenne Super 1972 Longbed SB Cheyenne Super 1972 Longbed Highlander Custom Deluxe 1975 K5 4x4 full convertible Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165 Greg Smyrna TN |
10-14-2014, 01:30 PM | #9 |
Sounds like an exhaust leak. It sounds louder while driving because your working the engine. does it go away when you stop accelerating and coast???
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
10-14-2014, 02:04 PM | #10 |
US Army Veteran
Reach up under the dash and make sure your speedo cable is tight. Do the same thing for the connection at the transmission. Optional - disconnect cable from speedometer, pull through firewall to engine bay, and add some lubrication.
1972 C10 Highlander - The making of a daily driver |
04-02-2015, 10:38 PM | #11 |
I believe it was an exhaust leak. When I unmounted the driver side exhaust from the header I found that the gasket was broken. I've since then, had hooker headers and flowmaster 44's installed. Gettin' her ready for summer. (*o*)/
Thanks guys, sorry about the lateness of this post. I've been busy with school and work. Cheers! |
Tags |
chevy 350, th350, ticking |
