Catchy title goes here..
![]() Join Date: Mar 2002
What did you do with your truck today, take 2
Yall have grown so much, you were crashing the site! Way to go !!
So here is your new and improved WDYDT thread. What did you do with your truck today? |
Re: What did you do with your truck today, take 2
Drove it with the new T5 conversion and enjoyed as many roads as we could find
GOD BLESS AMERICA! |
A320 Pilot/USAF Retired
Sweet Georgia Peaches!! Nice job Russell.
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
Thanks Liz! That's Awesome that there is getting to be so much activity on here.
Looked at pictures of my truck progress. I was missing her because she is 1100kms away from where I'm working but all the awesome builds and pics on this site keep me going until I can get some more build hours in
Repainted the cab in an attempt to match the "Patina". Next week will "age" the paint by sanding and rusting it.
---Shawn Cecil-1953 5 window build thread Skymangs..Chris of Old Sarge customs had a shop fire and was severly injured. To help with the medical bills and expenses a fund has been set up here....http://gofundme.com/c49h5mjx8 More details are here...http://67-72chevytrucks.com/vboard/s...=1#post7253189 |
I have a big oil leak to the back transmission (SM420), so have ordered a new out put shaft seal.
In an attempt to replace the seal, I have removed the propeller shaft, parking brake drum and band, expecting to be able to remove the oil seal from the outside but I didn’t succeed. So I have removed the case rear casting. Just to discover that the rear main shaft bearing had a lot of play so needs replacement. I have so decided to remove the transmission from the truck, just to have a look at the other bearings. The main shaft front bearing is worn out too. Ended by an order for a bearings and seals kit. I had the plan to replace the clutch throw out bearing as it is a bit noisy. The transmission being removed, I took the opportunity to have a look at the clutch so removed it just to discover that the disk is worn out and it is missing a part of it. A good day! Had to order a new clutch too! I have an oil leak at the rear axle. Am just wondering if I will have a look at it ! Cheers Michel
'55, Chevy 3600, 2nd serie, 3/4 ton, 235, 4 speed Muncie SM420, 4.57:1 rear axle |
"Aged" the Cab by sanding and rusting to match the original patina and get the desired "Rusto-Mod" look.
With winter on its way I thought this might be a good time to make some tire/wheel covers. I used scrap material that was saved for something just like this.
You have to have patiences or you'll be one. |
Finished welding my seat mounts now I just have to paint them. 1 more box checked off the to do list hanging on the wall, Woo Hoo!
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
Scored carpet for $5 at church fundraising sale. I love them no emotional attachment to any of the stuff so deals can be made. I paid full price! Now just need to cut and get edging put on. Enough to cover it 2-3 times so will not have to worry about day to day damage. From 76-2000 I just tossed in indoor outdoor stuff in what ever pattern caught by fancy at the time.
Really crappy picture, but I put the front fenders on!! Looking like a truck!!
nice!
Nice truck Denny55!
#15 |
Got the front chrome back on and then the bed! Tomorrow is bed wood and door glass...
#16 |
Don't know how to reduce the size of those photos...sorry about that
#17 |
Removed the steering wheel on the 58 and installed the new fuel sending unit. Replaced the fuel fill hoses on the 59. Now I need to learn to add pictures :-)
#18 | |
![]() The truck looks great.
Jimi J from I-Oh-Way '57 Panel 3105 Met this deer... Roof Swap on my Panel Jim's Bread Truck |
#19 |
put the Dirtbag away for the winter
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
#20 |
Too late to turn back now......
#21 |
Continued filling holes and smoothing the frame rails. Man there's a lot of holes!
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 ![]() |
#22 |
![]() Join Date: Jun 2011
Moved the projects into my new building I finished last weekend...good thing the door is 14' tall....I was able to get everything in my signature in there plus the 36' fifth wheel camper and the tractor....
___________________________ 1959 Apache Short Fleetside, 1959 Apache NAPCO Long Stepside, 1957 3100 with 59 fleetside bed 1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370 1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF 1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker Big Bertha Build |
#23 |
Installed my restored 46 Harrison accesory heater with new brassworks core and spal fan in mine.
#24 |
So, Fisher, it replaced the stock heater, in the stock location, under the passenger dash?
#25 |
Kinda....its in my 46. Never had a heater. I found a 46 Harrison Chevrolet heater, restored it and grafted in a newer style core and fan. Turned out better than I expected. Some of the 47-54 trucks were heater delete and these accesory heaters work well. You can even find them with defrost tubes. I modified the brass works 47-54 deluxe heater core and fan replacement for this one.
