Old 09-14-2014, 08:34 PM   #51
SCOTI
SCOTI's Avatar
Re: My 89 CC Dually: Double Wide
Originally Posted by bluex View Post
What thickness of plate did you use to "cup" the arms? Does the pocket hang down further than the lowest point of the arms? I'm thinking of doing that to mine when its apart for the frame swap. Might have the crossmember sectioned as well. The only problem with that is then the front will drop lower than the rear lol. If you can could you post a picture of the bottom side of the arm?
Bottom & sides are 3/16" steel. The bottom is flush w/the outer edges of the OE arm. The sides tie the bottom into the sides on the top.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 09-15-2014, 11:13 PM   #52
hot trux
'85 Stepside
hot trux's Avatar
looking good!
hot trux is offline   Reply With Quote
Old 09-15-2014, 11:41 PM   #53
SCOTI
SCOTI's Avatar
New lower shafts arrived today & were dropped off @ my neighbors business to get the dowel hole relocated .750" back.
The new sway bar shows it will arrive tomorrow so the OE unit was plucked tonight.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-16-2014, 04:07 PM   #54
aggie91
I'm just glad to be here!
aggie91's Avatar
Looks like good progress is being made on this one. Hope to see it soon.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 09-17-2014, 10:35 AM   #55
SCOTI
SCOTI's Avatar
I didn't get the shafts back yesterday so I worked on getting the arms drilled for lower bag hardware & played around w/shock relocation possibilities. New sway bar is BIG (the 2nd pic of the bushing is the new bushing on the old HD 1.25" bar)....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-17-2014, 04:22 PM   #56
Hankster
Hankster's Avatar
Just found this thread! I love your truck man! Keep up the good work!
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 09-24-2014, 10:39 PM   #57
75Dually
75Dually's Avatar
Scoti,
Hmm this looks very familiar! Keep up the good work bro!
75Dually is offline   Reply With Quote
Old 10-09-2014, 02:03 PM   #58
SCOTI
SCOTI's Avatar
One step forward..... 3 steps back.
A-arm mock up & measurements were done using the larger C30 spec'd dbl convoluted Firestone bags. Once everything was tacked together I test fit one of the bags w/50psi of air to verify clearances.
With the arms almost done now, I assembled the pass side so I could set it down on its full weight to allow disassembly of the drivers side. When I did this, I noticed my margin of clearance was reduced more than I cared for. I could not wedge a yard stick between the bag & F/R 'pocket' edges on the a-arm. It doesn't touch; but it's also just sitting still....
So I looked up alternative bag choices & decided to change directions. A call to AZ Perf was made & I now have a set of Porterbuilts lower arms on order. Nice thing about these is I get the caster benefit, bag clearance, & they already have the sway bar bracket that I'll need so that means fab work on the front should be done.
At least the a-arm mod put the bag & ride heights right where I was expecting (~6" @ 100psi). I'll prob go ahead & finish them out & use them on a 1/2 ton since the smaller diameter 7" bags would clear w/o issue.
Now I'm working on air leaks. It seems my compressor feeding the tank for the rear bags is leaking down. Tank is good (submerged/leak tested @ 50psi) but when connected to the compressor only, it will bleed down over night (enough to kick the comp on).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-11-2014, 09:42 PM   #59
cable666guy
cable666guy's Avatar
Custom wiring hazards !! Nice build !!
cable666guy is offline   Reply With Quote
Old 10-11-2014, 10:48 PM   #60
SCOTI
SCOTI's Avatar
This air system is pissin me off. I removed the fittings @ the compressors for re-sealing. I removed the teflon tape & sealed them w/Loctite thread sealant. Same results..... the tanks will bleed down enough to require kicking the comps on after sitting overnight. I guess I'll cut new airlines to eliminate them from the list.
Not sure what it can be other than possibly the drain valves for each tank (they passed the leak test though).
The bags are holding fine so the lines from the valves to the gauges are ok (all leak tested as well prior to installation).
Oh well.... if it was easy, everyone would have custom stuff.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-11-2014, 11:22 PM   #61
IowaHooch
IowaHooch's Avatar
I like where you are going with this. Looks great!
IowaHooch is offline   Reply With Quote
Old 10-13-2014, 12:12 PM   #62
aggie91
aggie91's Avatar
Scoti - do you have a check valve in the line between the compressor and the tank?
Karl
The LST Challenge:
Old 10-14-2014, 10:23 AM   #63
Low Elco
Scoti- check here- havin similar trouble about halfway down the page, may help.
http://67-72chevytrucks.com/vboard/s...563833&page=52
Low Elco is offline   Reply With Quote
Old 10-14-2014, 10:56 AM   #64
SCOTI
SCOTI's Avatar
No check valve....
That being said, the set-up used in my 68 was done (plumbed) the same way. It could go weeks (months) before the comp cycled & used a Thomas comprssor as well.
The main diff I see between our systems is mine is all manual paddle valves.
Currently (for isolation purposes) the 'supply' lines from the tanks to the paddle switches are not connected to the tanks. My bags are aired up & holding so from the paddle valve forward there does not appear to be a problem. The 'leak' or where the bleed down is occurring is between the tanks & comp's. The comp's are plumbed to feed the tanks & I have inline PTC plugs in the discharge ports of the tanks (again, just for isolation purposes while investigating the leak).
I might try the check valve approach suggested by Karl.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-14-2014, 03:40 PM   #65
SCOTI
SCOTI's Avatar
So I did some looking @ lunch..... Where is a good source for a check valve?
My comp's have an 1/8"npt female outlet; tank ports are 1/4"npt female; & using 1/4" DOT airline.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-14-2014, 08:48 PM   #66
lolife99
67-72 parts collector,…
lolife99's Avatar
I bet member way2lo2 could set you up.
Boris has all kinds of air ride stuff.
Keith
Convert to disc brakes.
Old 10-14-2014, 08:49 PM   #67
lolife99
lolife99's Avatar
http://www.viaircorp.com/checkvalves.html
Keith
Old 10-14-2014, 10:50 PM   #68
SCOTI
SCOTI's Avatar
I found some @ a local bolt, fastener, & fitting place. I pulled the supply lines to each tank. The 'front' tank had very little remaining pressure; the rear had alot more.
I re-plumbed the comps w/the check valves inline. I checked on them @ a 3hr dwell time & the comps didn't come on. The pattern has been the 6-12hr mark so I'll follow-up tomorrow am.
The feedback has been appreciated....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-15-2014, 08:19 AM   #69
SCOTI
SCOTI's Avatar
As of 12hrs, the comps didn't come on when powered up. That's a good sign.
We'll see how things are after work tonight.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-15-2014, 11:13 AM   #70
tintbox
Looking good sir.
tintbox is offline   Reply With Quote
Old 10-16-2014, 06:31 PM   #71
SCOTI
SCOTI's Avatar
48hrs & comps still not kicking on. Looks like the check valves solved the issue. Now I'll do some shop cleaning/rearranging & get back on the bed fabrication while waiting on my PB lower arms.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-20-2014, 12:55 PM   #72
aggie91
aggie91's Avatar
Good to hear it was a simple fix. Sometimes the compressor is the source of the leak since they are designed to compress the air and not hold the air, hence the need for a check valve.
Ever notice when your shop compressor finishes pumping up the tank that there is a little relief of air that it makes as it stops turning? That is the pressure bleeding the read valve in the compressor so that there is not a high head pressure on the next start up.
Karl
Karl
The LST Challenge:
Old 10-22-2014, 04:09 PM   #73
monte0185
monte0185's Avatar
Looking good. How much are you going to have to cut out of the bed floor with that 4 link setup? When you get to that point pics would be awesome.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 10-22-2014, 05:45 PM   #74
SCOTI
SCOTI's Avatar
The notch cover slopes from approx 32" @ the base to 12" @ the top. Above the C/L of the rear end, the floor is effectively 6.5" higher than the rest of the floor.
Something like this:
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-22-2014, 05:48 PM   #75
SCOTI
SCOTI's Avatar
The cross sill directly above the front 4-bar mounts will be relieved as necessary for clearance.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
