Old 10-23-2014, 12:17 PM   #1
502ms
502ms's Avatar
Bagged C10s: QA-1 Shocks?
Hey guys! I'm looking at upgrading the damping on my C10. I've already driven on it for close to 15k miles. Now I want to take it up a notch. Occasional track use (LS Fest Autocross), maybe to drag strip before and after the twins are installed. But overall, just fun driving. Spirited driving. Cruising.
Anyone use the QA-1 shocks? My truck is bagged. Staying bagged. Want to explore these shocks for adjustability and toss ability. If not QA-1, what do you use? No-Limit? KYB?
I have Z'd front, custom 4-link rear. Outboard trailing arms. Lays frame. Nearly stock height at full lift. Nice low ride height.
Thanks!
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 10-23-2014, 07:09 PM   #2
oldman3
oldman3's Avatar
Re: Bagged C10s: QA-1 Shocks?
I have QA-1 coil over single adj. shocks on my 50 pickup, really like them, much better that the old coils over set up before. This is for the front only, have leafs in the rear and haven't changed those yet...Jim
oldman3 is offline   Reply With Quote
Old 10-23-2014, 07:23 PM   #3
slowcpe
slowcpe's Avatar
Interested in this thread as well. I have the KYBs that come with the Porterbuilt kit but thinking about swapping them out with the Ridetech HQ shocks. They are adjustable and come with great reviews.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 10-23-2014, 08:29 PM   #4
Rochlow
I've been thinking of upgrading from the kyb shocks to the Ridetech hq shocks, also.
///Relaxed Atmosphere
Rochlow is offline   Reply With Quote
Old 10-23-2014, 10:58 PM   #5
SCOTI
SCOTI's Avatar
Ride Tech is the number 1 company for shock 'tunability' w/air suspensions. Check w/Chris @ Smittys!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-24-2014, 07:12 AM   #6
502ms
502ms's Avatar
Thank you everyone!
Best Regards,
Leon M.
Old 10-24-2014, 08:41 PM   #7
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
I'm a big fan of the QA1's I installed on my car. The adjustability is sooo nice and I'm surprised how much the adjustments change ride characteristics.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 10-24-2014, 09:37 PM   #8
Hart_Rod
Hart_Rod's Avatar
Has anyone used the QA1's on a static dropped truck?
Hart_Rod is offline   Reply With Quote
Old 10-25-2014, 10:41 PM   #9
502ms
502ms's Avatar
Talking Re: Bagged C10s: QA-1 Shocks?
Hart_Rod,
http://instagram.com/p/ulLRx_oDwq/
I imagine they'd be awesome. Dialed the rears in at 6 clicks and drove 40 miles. Wow! Gotta play with fronts tomorrow. Bought the DS502 and RS502. They are car porn.
Best Regards,
Leon M.
Old 10-25-2014, 10:43 PM   #10
502ms
502ms's Avatar
Smashingchuck I totally agree. Amazing.
Best Regards,
Leon M.
Old 10-27-2014, 03:34 PM   #11
Custom 68
Custom 68's Avatar
I have them on my static truck. I have Qa1 coilovers on the front and regular spring/qa1 rear. They are only 1 way adjustable but I like them I usually don't mess much with them but I softened them for a road trip and got them too soft. I adjusted them and got a great ride. I can adjust as needed.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 10-27-2014, 03:57 PM   #12
Hart_Rod
Hart_Rod's Avatar
Originally Posted by 502ms View Post
Hart_Rod,
Dave
This might be a dumb question, but why would you use coil over shocks, when you have coil springs? I thought coilovers replaced the springs?
Old 10-27-2014, 04:23 PM   #13
Custom 68
Custom 68's Avatar
Sorry Rob I may not have been clear.
My front is converted to coil overs with Qa1. The rear uses the adjustable shocks but 4 inch drop "factory" style springs.
Dave
Old 10-27-2014, 07:11 PM   #14
oldman3
oldman3's Avatar
I have the same set-up, switch stock springs for coil-overs with QA1 shocks, much better ride and you can adjust the shock for ride. Haven't changed the rear shocks yet, but it's on my to do list...Jim
Old 10-27-2014, 11:25 PM   #15
502ms
502ms's Avatar
I got all four installed. Still bag suspension and QA-1 RS402 up front, QA-1 DS502 out back. Night and day difference. I tried it with the fronts at 0... I changed them to 6 clicks each. Same for rear. Perfect!
Best Regards,
Leon M.
Old 10-28-2014, 08:35 AM   #16
Hart_Rod
Hart_Rod's Avatar
I still have coil springs front and rear of my 68 SWB and plan on keeping them. I'm currently running KYB "lowered" shocks, but would like something better that is tuneable. How did you guys determine which shocks you needed? DS or RS? Why single adjustable instead of double adjustable? Thanks for the help.
Old 10-28-2014, 09:16 AM   #17
Custom 68
Custom 68's Avatar
good or bad cost was the factor for me. I am sure the double would be better once you got it dialed in.
Dave
Old 10-28-2014, 10:19 AM   #18
blazer2007
Is it a fairly easy job to put the coilovers in the front of a 78 ?
blazer2007 is offline   Reply With Quote
Old 10-28-2014, 11:57 AM   #19
knomadd
knomadd's Avatar
What do you have for shock relocators up front? I think I want to run adjustable shocks too.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 10-28-2014, 12:33 PM   #20
SCOTI
SCOTI's Avatar
Just for reference..... what shocks were you running? Age?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-28-2014, 05:19 PM   #21
502ms
502ms's Avatar
I am using the stock locations for the front, CPP upper & lower control arms.
Best Regards,
Leon M.
Old 10-28-2014, 05:22 PM   #22
502ms
502ms's Avatar
Great question - I tried different shocks over the last few years. Was using the Rancho 7000s. They were comfortable, but I wanted a more aggressive feel and bite to go with the new power that I have. What I like about these is they can be clicked from drag racing settings to a comfortable setting to a very aggressive setting. (18 way adjustable). These shocks were only a year old.
Best Regards,
Leon M.
Old 10-28-2014, 05:27 PM   #23
502ms
502ms's Avatar
I went with:
(1) what was available and in stock - I hate driving to Summit to buy something and have to wait any time for it #instantgratificationrequired.
(2) what was adjustable, worked with my ride height, laid out height and has the proper compression and rebound at ride height. My DS and RS are both 18-way adjustable. The DS have the collars for the coilovers/spring setup. I assume the DS are coilovers and RS are just the slick shocks.
Best Regards,
Leon M.
Old 10-29-2014, 12:12 PM   #24
Hart_Rod
Hart_Rod's Avatar
I went with:
Thanks for the info Leon. I'm trying to figure out how your shocks compare to these:
http://www.ridetech.com/store/shocks/
Old 10-29-2014, 12:19 PM   #25
502ms
502ms's Avatar
My pleasure, buddy!
Here are the facts on QA-1 Street Star Shocks:
http://www.qa1.net/suspension/street...ks/street-star
Custom Mount Rebound Adjustable Smooth Body Shock Absorbers
QA1’s Street Star shock gives you that smooth ride and smooth look for your vehicle. With a comfortable compression setting and 18 valving options of rebound adjustment, you are sure to find your preferred suspension setting.
Bright Anodized Lightweight Aluminum Body
Rebound Adjustable with Comfortable Fixed Compression
Smooth Body
100% Dyno Test and Serialized
Revalveable and Rebuildable by the QA1 Factory or QA1 Authorized Service Centers
American Made
Precision Machined Aluminum Piston with PTFE Piston Band
5/8” Centerless Ground, Hard Chrome Plated, Solid Piston Rod
Three Step Sealing System
NEW! QA1 has expanded its offering of Street Star rebound adjustable shocks to include eyelet mounts on both ends of the shock in 7”, 8” and 9” shock lengths.
Best Regards,
Leon M.
#dirtydianah, bagged, lsx, qa-1
