Old 10-24-2014, 07:45 AM   #76
nlped
nlped's Avatar
Re: 1960 chevy parkwood wagon!
Originally Posted by 68basket View Post
Got the axle housing stripped down. The gears and bearings appear to be in god condition so i am going to run them for now. They are 3.08 and will probably get changed out after i drive it a while to better perform with the 700r4 overdrive. Rear end will get all resealed and the disc brakes installed.
Just my .02, but I'd recommend going ahead and putting a lower gear in it now so you don't have to snatch it back out again soon. With a 700r4 a 3.08 gear and that low profile 20" tire, you'll never get to take advantage of the overdrive unless you're runnin' like 90mph . And it's a LOT easier to do the diff/gear swap on a bench vs. under the car. I'd say 3.73's all the way too, assuming a 27" rear tire height...that should put the 700r4 at a happy gearing to pull at highway speeds without lugging or shift out of OD to 3rd all the time.
On another note...Love the strong arms and the floor board repairs. Watching this one makes me want one of these so BAD. Even my wife loves it... That's HUGE!!!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 10-24-2014, 08:59 AM   #77
Advanced Design
Advanced Design's Avatar
Progress is looking really good. Love this build. What are you using for the air suspension controls?
Advanced Design is offline   Reply With Quote
Old 10-24-2014, 09:40 AM   #78
fun in dirt
fun in dirt's Avatar
That's a super cool project...next car we do is gonna be something along those lines...low, long & cushy party wagon!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 10-24-2014, 11:19 PM   #79
68basket
I was thinking the same thing, but i am running short on funds to be able to do everything this go round. I have done numerous gear sets as i work on cars for a living. It will not be hard work for me to take the car to work and put some gears in it at a later date. I will probably do 3.73 but want to put some miles on it first to see what i think. It is getting 255/35/20 rear tires.
Car is getting full accuair e-level setup from Travis at properformance. Cant wait.
Thanks!
Tonight i got the last floor pan welded in and started laying out how the air management is going to fit. I was going to put it all under the car but didnt like how it was looking. I am liking this layout and just ordered a bracket for the accuair valve and module. I will clean and paint the spare tire well before i mount it all, May line with sound deadening also.
68basket is offline   Reply With Quote
Old 10-27-2014, 10:37 PM   #80
68basket
Having a little issue with my rear bag setup. Take a look at the pics and see what you think.
The brackets seem a little off and maybe not the correct height. Its hard to see in pics, but the part of the bracket that sits up in the old spring pocket is not sitting fully in there. The locating bracket coming off the side is stopping the bracket from going fully up to touch where the spring use to touch. It appears that a lot of the weight of the car is going to be resting on that small bracket that is welded on the side.
Has anyone bagged an x-frame car and run into this??
Old 10-28-2014, 07:18 PM   #81
Advanced Design
Thinking wrong upper bracket, wrong strong arm or incorrect mount location on the strong arm...assuming rotating the upper bracket makes no difference. Of course, Ride Tech can probably help.
Compressor and tank location looks great.
Old 10-28-2014, 07:26 PM   #82
HemiChallenger71
HemiChallenger71's Avatar
Arms backwards?
Post 74 they look fine but post 80 they dont.
HemiChallenger71 is offline   Reply With Quote
Old 10-28-2014, 07:34 PM   #83
68basket
I think part of my problems here is that the arms are from ridetech but the bags and brackets are not theirs. I think maybe a different upper bracket will be what i need.
Right now i have this problem in to Travis at properformance and waiting to hear back from him. Hoping something can be figured out.
Originally Posted by HemiChallenger71 View Post
Arms backwards?
The arms have not come off the car since post 74 and 80. the arms appear to be exactly the same except strong arm is stamped on opposite sides. It seems that the whole problem is in the upper bracket, it will not sit fully into the upper spring pocket, the locating tab on the side holds it about 1/2'" from going all the way up, and it holds it about 1/2 to the side.
Thanks for looking and your help!
Old 10-28-2014, 07:50 PM   #84
68basket
http://bcfab.blogspot.com/2012/07/19...uspension.html
If you look at the install on this 64 you can see that the rear upper bracket fits all the way up into the spring pocket, and the locating tab may be longer, allowing the mount to center in the spring pocket. Maybe i should try a pair of these brackets...
Old 10-28-2014, 08:21 PM   #85
68basket
Just heard from Travis, He is sending some pics of my setup to the makers of the brackets to find a solution. Will be waiting to hear back from them.
Well i have plenty of other stuff to do to the car while the bracket situation gets figured out.
Old 10-28-2014, 08:30 PM   #86
lolife99
67-72 parts collector,…
lolife99's Avatar
Talk to members way2lo2 or crawdadfox.
They both have bagged many x-frame cars,...
Keith
Convert to disc brakes.
Old 10-29-2014, 09:43 AM   #87
crawdadfox
crawdadfox's Avatar
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
Sent you a PM.
Down......with the sickness!!
crawdadfox is offline   Reply With Quote
Old 10-29-2014, 07:13 PM   #88
68basket
Got it fixed thanks to crawdadfox and Travis.
I found out i did not have the hole in the upper spring pocket in the correct location. Drilled a new hole in the center of the pocket.
Also the manufacture of the bracket said there is a variance in frames and i needed to cut and re weld the locating tab. Wasnt super excited to cut up new brackets but went ahead and a little while later it all looks better. You can see from the pics i had to move the tab 1/2-3/4" to allow the bracket to seat fully up into the spring pocket. Oh well, the spring sits much nicer now.
Also picked up my driveshaft today. Had to have the front shaft re tubed, and new cpp carrier support and slip style rear shaft.
Old 10-29-2014, 07:27 PM   #89
crawdadfox
crawdadfox's Avatar
Cool deal...now hurry up! I never get tired of looking at the old 58-64 Chevys dropped over a nice big set of wheels.
Old 10-29-2014, 07:31 PM   #90
68basket
LOL, i know. Me too.
This one still has a way to go, engine is on a stand, trans sitting under the stairs. no interior in it..... the list goes on.
I do have a Goal to drive up to indy where some of my friends live for the motorama 1962 on feb 13-15 even if it has interior in it or not!!
Old 10-30-2014, 12:22 PM   #91
Hickup pickup
Hickup pickup's Avatar
I just had the same problem with my 59 Elcamino. Seems this is a common problem as I was forewarned by a buddy with a wagon, you'd think the manufactures would solve this problem by locating the tab further down and including a simple spacer for the higher tab requirement.
2-20, 2-21 whatever it takes!
Hickup pickup is offline   Reply With Quote
Old 10-30-2014, 12:35 PM   #92
68basket
wow thought maybe i had an oddball or something? i have a feeling its the 59-60s only, and maybe only wagons and elcos? Oh well, looks like we did exactly the same thing to fix them.
Old 11-23-2014, 08:39 PM   #93
68basket
Took a few weeks off cause i got sick, then i had 2 of my apartments i had to turn over. now they are done i am back at it. Got the floors seam sealed and coated with hammerite. Hope it holds up well enough. Installed the firewall insulation pad. Kevin rebuilt my column and it looks great!! My youngest son loves opening all the boxes i get!!
Old 11-23-2014, 08:42 PM   #94
68basket
Got that sweet column installed, and the unisteer linkage all hooked up. Installed the power brake booster and got the brake lines finished. Started installing the american autowire harness. SO far i am very happy with the harness kit.
Old 11-23-2014, 09:31 PM   #95
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Lovin it, keep up the good work!
Zoomin is offline   Reply With Quote
Old 11-23-2014, 10:44 PM   #96
TBONE1964
Cluster King
TBONE1964's Avatar
Subscribed
I am curious to see what you do with the gauge cluster. Will you have an air gauge in the cluster?
Looks very nice so far. Keep up the good work.
Take care,
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 11-23-2014, 11:05 PM   #97
68basket
Thanks!!
Originally Posted by TBONE1964 View Post
Subscribed
Take care,
Tom
Thanks for taking a look.
Honestly i had not thought about an air pressure gauge yet. But now that you bring it up, i believe dakota digital does make an add on module fir displaying air pressure in one of the digital displays on the cluster. I will have to look into it.
One last pic for the evening. STarted setting up the accuair stuff and running the air lines into the spare tire well.
Old 11-24-2014, 09:56 PM   #98
68basket
Kept my oldest son up past his bed time to help me install the tanks and compressors!! He also went with me over to one of my apartment buildings to cut up a tree that fell in the crazy wind we had here today. Its always a fun time when he wants to be involved in the car build. He loved helping out with the wiring harness install i started yesterday because he could read all the directions to me!!
Old 11-24-2014, 10:00 PM   #99
nlped
nlped's Avatar
Those are going to be the best times spent building this bada$$ wagon. I love when my daughter helps work on any of my projects.
Carter
Old 11-24-2014, 10:40 PM   #100
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
I'm really lovin it all, The car, the column install, the unisteer and especially the kids involvment.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
accuair, bagged, elevel, parkwood, wagon
