Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 11-01-2014, 03:18 AM   #2426
swamp rat
swamp rat's Avatar
Re: PO has me PO'd
Thanks for posting the wire wrap site, got it saved.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-01-2014, 12:58 PM   #2427
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
You re welcome, just thought i d pass along some interesting product data...
Sorry to read about some of your pitfalls in your build, but like the rest of us, it were easy, everyone would be doing it
Sitting here on a rainy, chilly, saturday....heat cranked up. Man, i love my workshop!
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-01-2014, 09:16 PM   #2428
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Started to work on all my 12V switched (pink) wires to the OEM distribution block, when i was done i wanted it covered so no one hits it with a tool and shorts it out. So, i used a old regulater and took out the guts, just ground down the rivets, and it all popped out
[url=https://www.flickr.com/photos/97391199@N06/15684395921/]20141101_134004[/
20141101_205000 by [url=https://
SAFETY FIRST
AS usual, off topic
Jim
Old 11-01-2014, 09:22 PM   #2429
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
With old cover, some day i ll paint it
20141101_205445
Another step closer......
Found out from FAST what the step1 step2 and step retard wires are for....something to do with the ignition while sitting at the christmas tree, sorta like lineloc, i was told. Since the only trees i will be seeing are pine, oak, maple, and a dogwood sometimes, i ve tucked them outa sight
SAFETY FIRST
AS usual, off topic
Jim
Old 11-02-2014, 09:05 PM   #2430
Big J
Its lookin' like a Blazer!
Big J's Avatar
Re: PO has me PO'd
Just got through flippin' through a few of your pages, Jim I gotta say that is a lot of wires, you are a better man than me. Its lookin' good man.
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 11-03-2014, 09:34 PM   #2431
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
J, thanks for stopping by....hope life is treating you well, how s the truck running? Yeah, i thought it was alot of wires when i first started, but it s starting to make sense. Just one wire(flash) that is unaccounted for....gotta work on that.
Main issues now, are dist. wiring and crank trigger, gotta find 50 degrees BTDC to set both them up
SAFETY FIRST
AS usual, off topic
Jim
Old 11-11-2014, 11:44 AM   #2432
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
OK, my brain hurts from the electrical system.....need a break, so i m going to work on the coil mounts, the OEM brackets are getting in the way every time i turn to the next part of the build. So, i m building my own sooner than latter, but i want to retain OEM chase
Pretty simple....1/4-20 set screws, drilled and tapped into the vertical aluminum piece, whichis drilled and tapped to the hoizontal mount on the v/c, with spacers on the coils to maintain proper offset. I ve also rotated the coil 90 degrees
Coil mount is backwards, for clarity. But actually this is for number 7 cylinder
20141109_114511
20141109_114344 by james_jaros, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 11-11-2014, 04:06 PM   #2433
mtully79
mtully79's Avatar
Re: PO has me PO'd
Pretty slick.
mtully79 is offline   Reply With Quote
Old 11-12-2014, 12:39 PM   #2434
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Originally Posted by mtully79 View Post
Pretty slick.
Thanks Tully, the vertical piece is held on with 6-32's, not really trusting that. So, after i take a welding class i ll tig a fillet along that seam
SAFETY FIRST
AS usual, off topic
Jim
Old 11-20-2014, 02:22 PM   #2435
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Final variation of CNP using some of the OEM bracket and electrical chase. I can now go back and use my PCV and oil fill cap
20141120_125504
SAFETY FIRST
AS usual, off topic
Jim
Old 11-21-2014, 10:42 AM   #2436
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: PO has me PO'd
Your workbench looks like mine. lol
Tom Vogel is offline   Reply With Quote
Old 11-21-2014, 12:03 PM   #2437
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Yeah Tom, neatness takes time, and that is in short supply i guess we d lose the work bench of the month contest. Funny thing is, i know where everything is located....
Your truck is amazing, lots of nice work there
SAFETY FIRST
AS usual, off topic
Jim
Old 11-30-2014, 01:00 PM   #2438
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Had a couple hours to play with my truck this morning.....wanted to re-loom and re-pin coil connector, went pretty smooth! Now to work on passenger side
Trying to firgure out if i want to anodize or polish coil mounts
20141130_114941 by [url=https:
SAFETY FIRST
AS usual, off topic
Jim
Old 12-20-2014, 07:14 PM   #2439
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Two steps forward, one step back.....poor planning on my part. BFH or speed bump?
Hard to tell from the pic., but, the snout of the coil is an 1/8" from firewall. Well, noone ever said it would be easy
20141220_175711
At least i m past the crank trigger, now on to the distrib. or at least what s left of it. Just using it for cam referance and to drive my oil pump
20141220_175839
SAFETY FIRST
AS usual, off topic
Jim
Old 12-20-2014, 07:43 PM   #2440
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Re: PO has me PO'd
Jim,
Couldn't you slide the coil pack towards the radiator on the valve cover rail to clear the firewall or would that put the coil packs to close together?
Seeing what you are going thru is why when it comes time for my motor I will just stick with rebuilding the 307 lol.
Richard
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 12-20-2014, 08:04 PM   #2441
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Originally Posted by richard2717 View Post
Jim,
Richard
Yes i could, but, there is my v/c breather that goes forward of the coil, so that eliminates that. Could put the breather in the forward position, but i didn t leave myself enough room for lenght of adjustment on my spark plug wires. Could buy one spark plug wire.....
I hate to whack into the body work at firewall, but i don t think i m left any recourse
I m still thinking....but, i m leaning towards a speed bump
BTW, how are you feeling?
SAFETY FIRST
AS usual, off topic
Jim
Old 12-20-2014, 08:32 PM   #2442
richard2717
Re: PO has me PO'd
Its kinda hard to tell from the pics and all but maybe leave it in the same location but offset towards the intake? Don't mind me though just bored and thinking out loud even if not clearly
I am doing somewhat better. thanks for asking. I have my business moved back home now so that takes up a lot of the shop space but I am still collecting parts.
Richard
Members I have met.
Old 12-20-2014, 11:42 PM   #2443
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Richard
Actually Richard, that may work. You should try not to think clearly more often I ll have to look into it more closely tomorrow when i have more time, but sure beats ripping the heater box, all my electronics, exhaust manifold, inner fender out and buggering up the firewall. And having a future owner complain about the PO
Glad things are looking up
Today was the 1st day of retirement, gotta luv an afternoon nap
SAFETY FIRST
AS usual, off topic
Jim
Old 12-21-2014, 01:24 AM   #2444
JJH Jimmy
JJH Jimmy's Avatar
Re: PO has me PO'd
Looking good Jim. Congratulations on your retirement!
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 12-21-2014, 08:33 AM   #2445
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks JJ, your paint came out awesome, i think greys and silvers work the best on our trucks. Not to bad, only a month in paint prison
Back in the 70 s my Dad had a gun metal Chevy, really liked it then, still do
When you re retired, every day is a Saturday.
SAFETY FIRST
AS usual, off topic
Jim
Old 12-22-2014, 12:47 PM   #2446
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
With a combination of Richards idea of moving towards intake 1" and rotating to 80 degrees rear coil pack is mounted
Nice to have motorheads looking over your shoulder
20141222_114019
Used a holesaw on the drill press to bore a hole to mount K&N breather....careful with holesaws, they tend to grow from the designated size. Make a test touch on the aluminum and measure, this will be your final bore size
SAFETY FIRST
AS usual, off topic
Jim
Old 12-22-2014, 01:17 PM   #2447
richard2717
Re: PO has me PO'd
Looks like it worked out pretty good.
Oh and congrats again on the retirement
Members I have met.
Old 12-22-2014, 03:44 PM   #2448
skorpioskorpio
Re: PO has me PO'd
Are you running a cam trigger too, or is this a wasted spark setup?
skorpioskorpio is offline   Reply With Quote
Old 12-22-2014, 05:54 PM   #2449
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[quote=richard2717;6967328]Looks like it worked out pretty good.
Yeah Richard, sometimes you get to eat the bear
Oh and congrats again on the retirement[/QUOTE
Thanks, first day of not reporting to work, spent the day buying presents for the wifey, grandson....plus one from santa, BRIDGEPORT
Spent some time reading up on wasted spark, but i couldn t fully grasp the concept. I think it had advantages....
I m using a FAST dual sync distr., but, i m only using the distr. to get a cam referance to my XIM, which had to be repinned for the crank trigger
SAFETY FIRST
AS usual, off topic
Jim
Old 12-22-2014, 05:56 PM   #2450
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
You guys were soooooo close to getting the prize for 200,000 views
SAFETY FIRST
AS usual, off topic
Jim
